02-01-2015, 02:12 PM | #1 |
Rep 888
Drives: 08 135i M Sport 6MT, 15 X3 35i
Best Angel Eye Bulbs for Matching LCI Eyebrow LED
Hey guys,
I searched around and discovered that 5000k seems to be the best colour temp for matching the angel eyes to the LED strip. The thread ended with LUX V3 being the best option. Seeing as LUX V3 is no longer in production and V4/5 has trouble fitting in our headlights due to the oversized ballast I'm looking for other suggestions (Been there, done that with V4. Sold after getting constant ADH errors from the motor jamming when the headlight tried to turn left/right but the ballast was in the way. This could just be me, others have been able to get them to work) I picked up some LCI Xenon/ADH headlights to replace my pre-LCI Xenon/ADH headlights and would like the angels to match as closely as possible (pics below for reference) Currently I'm looking at Mtec's (4750k/7000k), Top Gear Solutions HPBs (80W or 160W, 6000k), or even some 5000k or 6000k halogens and coding the output higher. From those of you with LCI xenons, please share your recommendations. Thanks in advance!
2015 Cosmic Blue Metallic Wrapped X3 35i ///M Sport Full 3M Vinyl Wrap | Flat Black Grilles Last edited by 6MT_Addict; 02-09-2015 at 01:43 PM.. |
02-07-2015, 05:53 PM | #2 |
Rep 888
Bump - anyone able to help?
2015 Cosmic Blue Metallic Wrapped X3 35i ///M Sport Full 3M Vinyl Wrap | Flat Black Grilles |
02-07-2015, 07:26 PM | #3 |
Rep 1,410
Drives: X3 M40i
I'm interested in this as well
02-08-2015, 02:02 PM | #4 |
Rep 888
Looking at Dtec V9.5's right now through E92 Lighting:
02-09-2015, 10:31 AM | #5 |
471
Rep 4,938
We have actually sold tons of sets of our LUX H8 V5 angel eyes to uses with 1-series cars and have not had any issues with them. Since they are adjustable color you can set them to a 5000K which will match the eyebrow nearly perfect, or you can choose a cooler color to accent it. all of our lights come with a 1-year warranty and if you run into any issues with installing them i can assist or you can also return them for a full refund.
02-09-2015, 11:47 AM | #6 |
Joint Chiefs of Staff
24406
Rep 191,281
Our V1 fit the 1 series with no problems here are couple pics (6000k color temperature)
We also have V2 which are double the wattage with a fan built inside for better cooling ( but no pics on a 1 series yet ) V1 pictures:
02-09-2015, 01:29 PM | #7 | ||
Rep 888
I did find several threads illustrating where to place the ballast to avoid the errors, but for the life of me I could not get it to fit correctly. After looking at the LCI headlights when they arrived (with the units out of a vehicle) I can see a few spots where they would likely fit. Regardless I found the ballasts to be too large for my liking and given how difficult the passenger side headlight cover is to re-install correctly I gave up after the 7th try, and several bloody and bruised fingers lol. Now, with that said I was very impressed with the LUX V4 build quality, flexibility (color changing) and absolutely loved how they looked. Like I said though I just got frustrated with how small the 1er headlights are, and ended up selling the product to a buddy with a 3 series. In hindsight I should have contacted you regarding installation, it slipped my mind. Regardless I would prefer to stick to a system with a smaller ballast similar in size to the V3's as I know these will go in smoothly the first time round. I'm fed up with that passenger side headlight cover haha.
2015 Cosmic Blue Metallic Wrapped X3 35i ///M Sport Full 3M Vinyl Wrap | Flat Black Grilles Last edited by 6MT_Addict; 02-09-2015 at 01:45 PM.. |
02-11-2015, 12:00 PM | #8 | |
24406
Rep 191,281
No 1 series daylight pictures but here is how it looks on the e92
02-12-2015, 03:31 PM | #9 | |
BMW Master Tech
587
Rep 850
Drives: E30, E36, E82, E90, F10, F80
Garage List 2015 Aston Martin V ... [0.00]
2010 Lamborghini LP ... [0.00] 1985 Alpina C2 2.7 [0.00] 2017 BMW M3 [0.00] 2008 BMW 128i [10.00] 2013 BMW 135is [0.00] 1992 BMW 325i [0.00] |
135is #502 of 586
BMW LED Performance Wheel | OEM FULL Carbon Fiber | E9X M3 Gauge Cluster | E9X Exterior Mirrors | E9X M3 Full Suspension | E9X M3 Diff | PT-CAN2 Enabled | Bilstiens | Michelin PSS's | NBT Navigation Retrofit with Touch Pad |
02-13-2015, 11:38 AM | #10 |
471
Rep 4,938
No these will not flicker on start-up and as well there are no codes with them. Since we design all of our products we have put a lot of time into the design of these to make sure this would not happen.
02-14-2015, 03:12 PM | #11 | |
Rep 888
02-16-2015, 08:52 PM | #12 | |
Recovering 1addict
Rep 50
02-16-2015, 11:01 PM | #13 |
860
Rep 35,253
thanks for the support guys, our DTECS fit "perfectly" inside the headlight housing, no cutting, no modifying, no drilling, 100% plug and play which is how it should be designed from the ground up, extremely user friendly
02-17-2015, 10:55 AM | #14 |
471
Rep 4,938
Good to know. The power supply nearly identical to the size as others out there as well so once its installed it shouldn't be an issue at all
02-17-2015, 05:20 PM | #15 |
Rep 1,297
so the V5 doesnt have the flicker the v4 did and they're brighter?
what about all the nightmares of AHL errors? =/ that addressed?
2022 M3 xDrive Comp
2020 M2 CS (retired) 2018 M3 Comp (retired) 2015 335i (retired) |
02-17-2015, 05:32 PM | #16 |
Rep 1,297
call me crazy tho the dtech 9.5 ballasts looks better than the v5
also couldnt u theoretically install the lux with the headlights off the car to make sure u close everything up properly
2022 M3 xDrive Comp
02-18-2015, 10:50 AM | #17 |
471
Rep 4,938
How do they look better? just curious
02-18-2015, 09:14 PM | #19 |
471
Rep 4,938
Oh, ha ha. Not sure the size of the others but ours are 2.2 x 1 x 1.25 inches in size so they are really not large. The older V3 power supplies were early identical at 2 x 1 x 0.75 inches
02-19-2015, 03:15 PM | #20 |
860
Rep 35,253
our driver modules since DTEC V4 can be installed with both plastic covers on for all 1 series.
02-24-2015, 09:41 AM | #21 |
471
Rep 4,938
Just wondering if you ever made a decision on the lights or if there are any other questions i can help answer for you
02-24-2015, 01:17 PM | #22 | |
Rep 888
I'm still looking into a few but I'm planning on purchasing some of the HPB 160W bulbs from Top Gear Solutions. I'm not in a rush since my vehicle won't be out of storage until early May so I will be unable to actually test them/post results until then.
