BMW M3 Forum (E90 E92)
      02-11-2015, 09:01 AM   #1
mikusk
Drives: e92 m3
So i just purchased 2007 M3.....
And just found out about this rod bearing issue....
Anyways,I am new here and wanted to say Hi !
I got couple of questions :
1. i have 58t miles on my e92 M3 and i dont think that previous owner changed those bearings,should i do the change asap ? if yes,Should i go for BMW stuff or order custom like VAC ones ?
2. There is castrol engine oil in it and i read that its terrible oil,i was reading about this one even on these platforms and ppl said its good to go :
http://www.amazon.com/Liqui-Moly-202...qui+moly+10w60
Should i go for it guys ?
I am in love with this car but this rod bearing issue dissapointed me
Thanks for your feedback on this matter,i look forward for any response,
with regards,
mikusk
      02-11-2015, 09:03 AM   #2
gallian93
gallian93's Avatar
Drives: 18 M3 cs/72 tii
2007 M3?
      02-11-2015, 09:09 AM   #3
Yes, a 2007 M3. OP is in Slovakia. In European countries cars are designated by the year purchased so an M3 purchased in in late 2007 is a MY '07 there. Here in the US we have a system of model years beginning long before the calendar year. An M3 purchased here would have been called a MY 2008... Hell, BMW started selling MY 2011's in the US in March of 2010!
2021 X3 M40i
      02-11-2015, 09:09 AM   #4
mikusk
Drives: e92 m3
Yeh VIN says 2007,one of those first i guess,lets just say 2008 if u like
EDIT : kscarrol knows it all
      02-11-2015, 09:50 AM   #5
Honda
Honda's Avatar
289
You got the car on March 2010 and it is 2011 model? Why BMW is using this way?
      02-11-2015, 09:57 AM   #6
No, I took delivery of my MY 2011 in early October 2010 but BMW was selling MY 2011 M3's starting some time in March 2010...
Edit: Check out this thread showing production dates by model year...
http://www.m3post.com/forums/showthread.php?t=542482
2021 X3 M40i
      02-11-2015, 10:00 AM   #7
Tracyis300
Tracyis300's Avatar
Drives: 09 E90 M3
If you feel the need to change them? Then get the WPC treated bearings or the VAC. They are both just as good as the other, so there's no need to "flame war" over it!
So go with what you like best?!
      02-11-2015, 10:09 AM   #8
Helmsman
Helmsman's Avatar
Sweden
4486
Drives: 2011 AW E90 M3 ZCP
with regards,
mikusk
Congrats and welcome onboard!
Regarding the rod bearings you need to read in on the issue and make your own judgment before you make a decision. There is plenty of material to study on M3Post.
To add some balance - cause after all most S65's do run for a long time - don't forget to also read in the 100k miles + link.
Good luck!
      02-11-2015, 10:25 AM   #9
Petros
I just find it absolutely ridiculous how you can buy a car of a certain model year up to 9 months before that year begins! IMO a car's model year should be the year it is built and sold.
      02-11-2015, 10:30 AM   #10
I don't disagree! Just the messenger...
2021 X3 M40i
      02-11-2015, 12:05 PM   #11
Harry Da Hamster
Harry Da Hamster's Avatar
86
Drives: The Bus
Castrol TWS is one of the best racing oils you can get. The problem is not its quality. What people hypothisise the problem to be is its too thick for street use, short trips to the grocery store, low speed stop and go driving. The reason BMW recommends it is most likely because 1) Castrol bought into it and 2.1) so it doesn't sheer down* 2.2) and can still lubricate with excessive blow-by with racing for long periods of time at high RPM's.
*it does sheer down from its original viscosity but stabilizes at a slightly lower viscosity.
      02-11-2015, 12:08 PM   #12
Harry Da Hamster
86
Drives: The Bus
So what if production date is Nov 2007 and it reaches the dealer in Jan 2008?
      02-11-2015, 12:20 PM   #13
mbox
mbox's Avatar
Drives: ///M
Your rod bearings may or may not need changing.
Getting an oil analysis during your oil change will help you decide if you need your rod bearings changed. I have the same miles as you and my oil analysis is still ok.
      02-11-2015, 05:20 PM   #14
mikusk
Drives: e92 m3
I am few days before oil change,I am from europe,what should i look for in the analysis ? Can u guys recommend me any good labs for this outside blackrock since that is US company ?
      02-11-2015, 06:24 PM   #15
mxa121
mxa121's Avatar
226
Drives: M
I can't recommend a lab, but look for very high lead ppm. Of you see abnormally high lead content and/ or copper, might need consider changing the bearings. This is because the bearings have lead outer surfaces with copper inner surfaces. High lead high copper then big problem. Low lead low copper no problem.
m3post
