02-11-2015, 04:17 PM | #1 |
Rep 303
Drives: 2024 Black M4 Convertible
Low gas indicator
When does this indicator come on for the M4? Is there an ability to code it to come on later?
02-12-2015, 08:27 AM | #5 |
Rep 1,199
Drives: 2015 M3
50 miles to go. Which is about 2.5 gallons. I don't know this for sure, but one of the reasons that BMW might have set the light level with a higher fuel level is because they want to ensure that you fill up before you run the tank level below the point needed to cool the fuel pump, which is located in the tank. It could be their thinking is "we need at least X to cover the fuel pump under normal operating conditions. Let's set the warning light at 2X,"
Best Regards, Robert (BMWCCA #471893)
Loreley 2015 / //M3 6MT SO over full SO, Exec,Susp & Lighting, HK & Blk 19's - ED 15 May 2015, Redelivery 23 July 2015 My photography: WWW.PBASE.COM/VONMAYR My ED Adventure http://www.vonmayredadventure.blogspot.com |
02-12-2015, 03:51 PM | #6 |
Commander-In-Chief
2196
Rep 8,947
Low fuel warning
Mine comes on a little under 1/4 tank; E92 was a little over that mark. It is codable to a lower level, I believe.
02-12-2015, 04:04 PM | #7 |
King Cobra
109
Rep 450
That is exactly correct. With direct injection if it goes dry the components will overheat extremely quick and be damaged. Even if you let ran out of gas just one time it will shorten the life of those parts vastly.
02-12-2015, 04:05 PM | #8 |
King Cobra
109
Rep 450
02-12-2015, 04:10 PM | #9 |
Rep 680
