02-19-2015, 06:49 AM | #1 |
Rep 149
X5M Calliper on M3/4...?
Obviously the OEM standard brake setup for the F8x platform is. Steel rotor 380f and 360r.
Thats all well. But the Callipers are 4 pot front and 2 pot rear. Whereas the CCB upgrade is 6 pot front and 4 pot rear. That being said could you swap the front 4 pot steel Calliper be moved to the rear and the X5M front 6 pot steel calliper be used on the front of the F8x? In theory this gives the same piston setup as the CCB but not being CC... Are the brackets the same? Weight? Rotors don't need up sizing? Thoughts? |
02-19-2015, 09:17 AM | #3 |
Rep 20,742
Drives: 2021 911 turbo
Why would you want to do this ?
The base iron rotor setup on the F8X seems plenty sufficient to me.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
02-19-2015, 09:35 AM | #4 |
Rep 202
02-20-2015, 03:15 AM | #6 | ||
Rep 149
tbh I wasn't aware the CCB could be used.... Am I right in thinking the calliper doesn't dictate the CCB factor? Its the rotor?
I imagine (need to check) that the Calliper is very expensive just because its classed as CCB. But I'm not looking to upgrade rotor size. Quote:
02-20-2015, 07:56 AM | #7 | |
Enjoying driving
388
Rep 1,169
Calipers are built for specific size rotors, since the CCB rotors are larger in diameter, you would have to use 400 mm front and 380 mm rear rotors. The benefit maybe with the BMW CCB calipers that you may keep the warranty on them If it is for looks, I'd recommend not to waste money of course, but that's an individual choice. Last edited by FTS; 02-22-2015 at 08:50 PM.. |
02-20-2015, 09:03 AM | #8 | |
Rep 3,152
And besides, have you seen the size of the calipers on X5/6M? They're the same as a size 18 men's boot. Way overkill.
02-22-2015, 11:41 AM | #9 |
Rep 149
