03-01-2015, 08:10 AM | #1 |
Rep 2,672
Stock brakes - quick pad swap windows or openings?
Does anyone know if the stock brake calipers have the quick pad swap windows/openings? This allows you to swap pads by removing a pin, bracket, or bridge(Stoptech) on the backside of the caliper, and doesn't require the removal of the caliper itself. I used to have these on the brembos that came on my Porsche and they made pad swaps before and after track days a breeze.
(For the CCB's this is currently under discussion in the 'Steel Rotors for CCB?' thread.) Any info is appreciated! |
03-01-2015, 09:25 AM | #3 |
Rep 5,678
Yes. You can swap your pads in about 30 - 40 minutes including jacking the car once you get good at it.
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 |
03-01-2015, 09:45 AM | #4 | |
Rep 20,742
Drives: 2021 911 turbo
Is it relatively easy to do with calipers still in place?
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
03-01-2015, 10:31 AM | #5 |
Rep 4,002
For the pistons I still got the Lisle 29100 Quick Quad Pad Spreader from when I had the stoptechs on my E92. No need to remove anything, I just hope it fits the opening.
Grigio Telesto M4, 6MT. Coyote 5.0 F-150 991 GT3 |
03-01-2015, 11:04 AM | #6 | |
Rep 20,742
Will be getting one
03-01-2015, 11:10 AM | #7 |
Rep 5,678
I use the pad itself to push the pistons back in... the weights on the top of the pad make it easy and I found with careful force it is pretty easy. When I took the track pads out (without the weight on them), I used a flat head screw driver in a cloth between the pad and rotor to very carefully push the piston back. Both worked well.
03-01-2015, 01:02 PM | #8 |
Rep 4,002
03-01-2015, 02:53 PM | #10 | |
Rep 1,789
Drives: wife crazy
Garage List 2019 Ford Raptor [0.00]
2016 Porsche 991.1 ... [0.00] 1987 Chevy Camaro I ... [0.00] 1972 Chevy Corvette [0.00] 1999 BMW M3 race car [0.00] |
I've changed my pads at least a half a dozen times already and the pad change really only takes a few minutes per corner. Actually takes longer to put the car on stands and take wheels off than the pad change. Anyone taken the calipers off yet for a rotor change or resurfacing? It looks like it should be pretty easy, same as Brembo?
Road course laptimes for BMW M4 2015 6MT
WHP East Track: 1:04.880, Arizona Motorsports Park: 1:54.352 Road course laptimes for Porsche 911 991.1 GTS 7MT WHP East Track: 1:02.770, Arizona Motorsports Park: 1:48.889 |
03-01-2015, 02:53 PM | #11 |
Rep 20,742
Just the slow ones: the ones that use the brakes too much
03-01-2015, 04:44 PM | #12 |
Rep 4,002
03-01-2015, 06:19 PM | #13 |
Rep 5,678
To be honest, I don't see much reason unless you are tracking an excessive (i.e. 30+ days a year). The stock system... with track pads... is very capable and all the brakes the vast majority of track rats will need IMO.
03-02-2015, 03:11 AM | #14 |
Rep 321
Just a hint to those talking about pushing the pistons back. Remember to open the lid on the brake fluid reservoir (or alternatively attach a bleeder hose and crack the bleeder screw). When you are pushing the pistons back the fluid has to go somewhere, and it is much easier with the lid open.
03-06-2015, 10:31 AM | #15 |
Rep 2,672
03-06-2015, 10:32 AM | #16 |
Rep 2,672
This is great to know, thanks! My BBK budget is now my suspension budget!
03-06-2015, 11:40 AM | #17 | |
Rep 4,002
