BMW X5 and X6 Forum 2014-Current
      03-04-2015, 12:10 AM   #1
batmanken
Drives: 2018 540i Msport
Jump starting with the F15
so recently, my mom's car wouldn't start at a shopping mall parking lot, so I had to drive over there with jumper cables to jump start the car. as soon as I opened the hood of my F15, I freaked out lol, I couldn't locate where the battery was, and where to connect the cables lol. being really confused, I opened and started reading the manual and figured out where to connect the cables. so strange how one end is easy to locate but the other one is a weird looking bolt on the right side when you open the hood. just thought if any of you guys had funny incidents like this, trying to jump start someone's car. most cars I had before were japanese cars so battery location was obvious.
      03-04-2015, 12:30 AM   #2
Wobbles
Singapore
298
Drives: F02, F13, F15
Waitaminit... You mean, there's a battery under the hood? I thought it was in the trunk!
      03-04-2015, 12:58 AM   #3
pdawg
Drives: 2015 X5 XDrive 35i
Positive post is pretty easy to identify. I've always usually ground to the block or chassis regardless of vehicle. Better connection.
      03-04-2015, 01:46 AM   #4
opasha
opasha's Avatar
1331
Drives: 2014 BMW X5 50i
The front engine connection point of the battery for ease of access is located (at least for the 50i) closest to the driver's side. The positive terminal is located under the red cap with the big PLUS sign. Just a few inches below this positive red terminal exposed wide open on a piece of grounded metal is the negative terminal all by itself. I'll take a picture tomorrow to show it since I'm removing my RaceChip anyway. Here is a picture of where both the main battery (left) and the accessory battery (right) are located in trunk compartment:
2014 X5 50i X-Line // Mineral White
      03-04-2015, 02:18 AM   #5
pdawg
Are you reMoving it Because you're taking it in for programming?
      03-04-2015, 02:27 AM   #6
opasha
opasha's Avatar
1331
Yes . Hopefully, this will make me an expert in taking apart my engine bay area and installing my chip in record breaking time...haha, jk .
      03-04-2015, 05:36 AM   #7
MysticBlue
Drives: '20 M5C, '09 M3 DCT Coupe
This is why I come here... I didn't realize we have a separate accessory battery. Makes sense considering how much electronics there is and how much of it operates both before the engine is started and after it is shut down.
M5C 20% tint, Xpel full front, partial sides and rear. Spacers, 15mm front, 12mm rear. Turner Motorsport Oil Cooler Guard.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra.
      03-04-2015, 06:17 AM   #8
NPickles
United Kingdom
71
Drives: F15 40D SE Space Grey/Terra
I know, it's great isn't it, you learn something new every day
      03-04-2015, 08:49 AM   #9
Jerich0
Love to Drive
197
Drives: X4 & M4
I have a 50i and dont have the secondary battery... I wonder why!
      03-04-2015, 10:44 AM   #10
retx
Drives: '18 F15 40e
The owner manual is talking about the jump-start by using the battery of another vehicle. It doesn't specify the detailed step by step process of how F15 helps others jump-start.
Is there the official procedure for this? Just curious. Thank you.
      03-04-2015, 10:46 AM   #11
retx
Drives: '18 F15 40e
This makes me wonder if I need to check my 35i, and if Diesel has the same setup.... :roll eyes:
This info is good. I can't imagine the batteries are hidden out there.
      03-04-2015, 11:32 AM   #12
Taran.J
Taran.J's Avatar
Drives: BMW, LEX, MBZ, RAM, TESLA
I have a storage bucket to the right of my battery in the trunk
      03-04-2015, 01:26 PM   #13
Gilly1964
Drives: F15 30d MSport
Ditto
      03-04-2015, 03:04 PM   #14
opasha
opasha's Avatar
1331
I've jumped other cars and had my car powered by my Infiniti FX35 when I had to do DME coding with Shawn. This manly procedure works/worked for all of my cars :
      03-04-2015, 05:12 PM   #15
retx
Drives: '18 F15 40e
The last car I personally jump-started was from Chevy to Ford in 1993, and it's operated directly from the real "battery" of the good car to the POSITIVE of the battery of the bad car and the engine of the bad car...
This "corresponding starting aid terminal of the vehicle" (= POSITIVE) and "the special nut of the body ground" (=NEGATIVE) are the fancy things to me, aren't they?
      03-04-2015, 05:49 PM   #16
opasha
opasha's Avatar
1331
It's really easy after you watch the video. It makes jump starting cars a piece of cake.
      03-04-2015, 11:52 PM   #17
MysticBlue
It's the same either way.
      03-05-2015, 01:34 AM   #18
ocman
Drives: 2015 X5
Last month my van needed a jump start and x5 was the only car around. I was gonna unscrew the plastic cover in the back but gave up. Called road side assistant instead. I didn't know there was a connectors in the front. Please post a photo where plus and minus connectors are. Thanks
      03-05-2015, 04:03 AM   #19
1230vani
1230vani's Avatar
Drives: G05 40i LCI
I will need to jump start my wife's car in a month using my car. Please post photo and mark where. Thanks a lot!
      03-05-2015, 03:09 PM   #20
opasha
opasha's Avatar
1331
I will post a picture with arrows shortly in 15 minutes or so .
      03-05-2015, 03:39 PM   #21
opasha
opasha's Avatar
1331
Ok, here are pictures of the positive (red) and negative (black/ground) connection terminals in the engine bay on the driver side area:
      03-05-2015, 05:11 PM   #22
ydchoe
Drives: BMW X5 F15
Interesting topic. What if I want to jump start OTHER car? Would I still connect to same terminals?
xbimmers
