03-22-2015, 05:55 PM | #1 |
M4-SAHD
512
Rep 611
Alignment done wrong by dealer. Fuming
Help does anyone knows the stock cambers spec for alignment, dealer did my alignment 4 months ago after I install H&R sport after 4500 miles this it's how my right side tire looks.
03-22-2015, 05:59 PM | #2 |
Rep 606
Drives: 2018 F80 Atlantis Metallic
Whoa, that sucks!....when I take delivery of my M3 I plan to have a local garage that I trust do a 4 wheel alignment. I've only used my dealer for the scheduled maintenance during my 335 lease, not sure if I can trust them for anything other than oil changes.
Past: 2018 M3 Atlantis Metallic/SS, Comp Pkg, 6MT
Past: 2015 M3 Austin Yellow |
03-22-2015, 06:00 PM | #3 |
Rep 3,397
Wow, that's pretty brutal.
They should have given you an alignment sheet with it... Never leave from an alignment without a sheet.
2019 Ruby GT350 - Gen 5 Whipple on corn making 855RWHP.
Sold: 2018 F80 Part Deux /DCT /YMB /Full SS /CF Trim /ZCP /ZEC w/Black 666M Sold: 2015 F80 /DCT /YMB /Full SS /CF Trim /ZEC /ZLP /HK /S&TVC- 18''///M |
03-22-2015, 06:20 PM | #4 | |
Rep 4,986
03-22-2015, 06:27 PM | #5 | |
M4-SAHD
512
Rep 611
03-22-2015, 06:29 PM | #6 |
Rep 868
Did the dealer happen to be in Jacksonville, Florida?
2022 BSM G80 Comp X-drive |
03-22-2015, 06:33 PM | #7 |
M4-SAHD
512
Rep 611
03-22-2015, 08:16 PM | #9 |
M4-SAHD
512
Rep 611
03-22-2015, 08:32 PM | #11 |
M4-SAHD
512
Rep 611
03-22-2015, 10:46 PM | #12 | |
Rep 3,397
I've been through this before, and I always just took the specs to a reputable shop and had them do it. You should have Factory specs, what it was when they put it on the rack, and what it is when they finish. Be sure to monitor tread wear or anything seemingly unusual to ensure your car is aligned properly. Sometimes they can not tighten something up and can cause it to come out of alignment as well.
03-23-2015, 12:24 AM | #14 |
Rep 210
Man, looks like they completely screwed up your toe. Even ridiculously negative camber wouldn't kill a tire like that after only 4500 miles. Toe is what really shreds tires.
03-25-2015, 05:16 PM | #15 |
Rep 1,191
If your car is as low as it looks in your avatar, even a good static alignment is going to have screwed up toe and camber curves. There is a reason people recommend not to slam your car into the weeds.
2015 M3, 2005 330i ZHP, 2015 228i 6MT Track Handling Pack, 2007 M Coupe (Sold)
03-25-2015, 05:33 PM | #16 |
Rep 2,818
You realize once you change the right height and affect camber there's no way for them to correct it into factory specs right? You lowered your car. The dealership did their BEST to bring it into spec (which isn't even 0 degree camber btw.) This is something you should've been expecting after lowering your car.
03-25-2015, 07:31 PM | #17 | |
M4-SAHD
512
Rep 611
03-25-2015, 08:41 PM | #18 |
Rep 1,191
My point still stands.
03-25-2015, 08:43 PM | #19 |
M4-SAHD
512
Rep 611
Good for you bro, your point has no meaning to me. To each their own. It does look good.
03-25-2015, 09:04 PM | #20 | |
Rep 1,191
Your case seems a bit extreme, so I'd guess that toe was out on that tire, but don't expect stock-like tire wear with that setup. I'm pretty sure there's some irony to be found here.
03-25-2015, 09:15 PM | #21 | ||
M4-SAHD
512
Rep 611
03-25-2015, 09:22 PM | #22 |
BimmerPost Supporting Vendor
8295
Rep 18,866
Our Clubsports on our M4 may be up for sale soon, let me know before pulling the trigger.
