04-06-2015, 10:47 AM | #1 |
Rep 1,479
Drives: 2017 F80 M3
Failed Searches for Quality Wheel Repair Shops in Houston
Finding a good wheel repair shop in Houston is quite a challenge. Below are two shops that I will never use in Houston.
1.) Houston Wheel Repair 7070 SW Freeway This is the infamous place that rips people off by selling old used tires to mothers. I went to check them out because their website was impressive. They quoted $225 - $250 a wheel to refinish a 19" ZCP. No thanks. 2.) Warehouse Tire and Auto 6760 Rampart The sales person was trying to sell me his experience in wheel repair and how they service a lot of dealers including Lamborghini of Houston blah blah blah. His reputation quickly went south when he told me my stock ZCPs had a powder coat finish. I questioned him several times and he didn't back down on his statement and always referred back to his years of wheel repair experience. ZCPs for the record are painted and clear coated. He actually quoted me a fair price of $150 per wheel for powder coating, but I only had one wheel that needed to be refinished and I knew it wasn't going to match the other 3 so I walked out. Any one who has found a good shop please post in this thread.
_______________________
1991 E30 M3/Brilliantrot 2017 F80 M3/AW |
04-06-2015, 10:58 AM | #2 |
PAZUZU
545
Rep 2,058
Drives: '15 M4
I've tried stripping three different models of bmw wheels and all are powdercoated. it is very difficult to get the finish off a bmw wheel unless you sand blast. how certain are you that the zcp are painted?
2009 M3 DCT ESS625+ SOLD 2015 M4 BSM/Silverstone F4LCON @texasMclub IG @jagemoets |
04-06-2015, 03:20 PM | #3 |
Rep 1,479
Drives: 2017 F80 M3
It has a powder base coat, painted color coat, and then a clear coat. The clear coat is extremely durable. What type of solvent are you using to strip it with? Most wheel manufacturers don't recommend powder coating because heat degrades the strength of steel/metal.
04-06-2015, 04:44 PM | #4 |
Rep 3,387
04-06-2015, 09:39 PM | #5 |
Rep 1,052
Drives: 2022 X3MC; 2012 M3 Cabriolet
Unfortunately I've had to get curb-rash fixed twice...
But I had it done at IMC Automotive, 5616 Schumacher Ln, Houston, TX 77057. +1 (713) 266-7239 They charged $100 each time, and I swear that the original damage was imperceptible. (and I am positive my OEM wheels came back because I marked them.) They even gave me loaner wheels for the day while they did the repairs. Not exactly what you're requesting, but they might do more services than what I've had to utilize. - V .
2022 ///X3M Competition; São Paulo Yellow
2012 ///M3 Cabriolet; Le Mans Blue Metallic. >177k miles and still rocks! |
04-07-2015, 08:34 AM | #6 | |
Rep 1,479
Drives: 2017 F80 M3
04-07-2015, 08:35 AM | #7 |
Rep 1,479
Drives: 2017 F80 M3
I would assume so. I believe powder coating requires more heat and for a longer period of time.
04-07-2015, 09:39 AM | #8 | |
Rep 3,387
More heat, yes, but for longer periods of time, I don't think that's correct. http://www.diamond-wheels.net/powder-coat-process.php Those guys do paint and powder, and the powder portion is 200 degrees @ 20 minutes, whereas the paint portion is 40 mins, temp unknown. I know when I had things powdercoated, each bag of powder (I brought my own to the shop that I had do the work) comes w/a cure schedule. For example: https://www.powderbuythepound.com/SO..._CHROME_TRANS/ = 400 degrees @ 10 minutes. https://www.powderbuythepound.com/SU...EAR_STARLIGHT/ = 400 degrees @ 10 minutes, as well. |
04-07-2015, 09:42 AM | #9 | |
PAZUZU
545
Rep 2,058
Drives: '15 M4
i've only been able to remove the clear layers. non of the color is stripped because it's powder coated on. the only way it comes off is with acid dips for a period of time and the risk there is the timing.
04-07-2015, 10:01 AM | #10 |
Rep 3,387
Easiest way to remove powder coat is by Permatex Gasket Remover. I learned about it from reading this a long time ago and tried it out. Works like a champ. Spray it on and let it sit and it'll peel right off. In my experience, I had to wait 40 mins or so for it to activate, and there were a couple times I had to respray some parts, but in the end, it worked like a champ. I have some pics somewhere, I have to dig them up.
04-07-2015, 10:04 AM | #11 | |
PAZUZU
545
Rep 2,058
Drives: '15 M4
04-07-2015, 10:14 AM | #13 |
Rep 3,387
I'll have to recommend http://www.wheelsamerica.com/Wheels-...an-Antonio.php They have a place in Houston and a place in Dallas. I contacted both locales, but since a lot of my family is in SA, I went w/them. I dropped them off w/my dad, and he dropped them off @ the shop and picked them up when they were finished 2 days later.
I picked up my wheels used and a couple of them were curbed something horrible. Wheels America fixed the curbing (and slight indention on one of the wheels) in 2011 and I haven't had any trouble at all. They say they powder all of their wheels, but I had them strip all 4 of them and return them to me raw, as I had already lined up a powder coater. I highly recommend them, at least the SA shop. The price was VERY reasonable. |
04-07-2015, 01:35 PM | #14 | |
Rep 1,479
Drives: 2017 F80 M3
If the information is completely accurate, then they are doing a powder prime coat, then a wet color coat, and finally a powder clear coat which to me makes no sense. If you do powder coating, you go all the way and not include any wet coating.
04-07-2015, 01:38 PM | #15 | |
Rep 1,479
Drives: 2017 F80 M3
04-07-2015, 02:01 PM | #16 | |
Rep 1,479
Drives: 2017 F80 M3
http://bbs.com/en/technology/quality.php
04-07-2015, 05:36 PM | #17 |
PAZUZU
545
Rep 2,058
Drives: '15 M4
are you doing one or two wheels only? wheels america actually does great work and the paint should match almost perfectly.
04-08-2015, 08:16 AM | #18 |
Rep 1,479
Drives: 2017 F80 M3
Unfortunately, I'm only doing one wheel which is why I've been so picky.
04-08-2015, 11:22 AM | #19 |
Rep 3,387
I didn't have OEM wheels done. I picked up some TE37 Time Attacks and refinished them, so I don't have a comparison. I can understand why you'd be picky. My boy recently had one of his wheels repaired (didn't have it done @ Wheels America) and it came back just a hair off the color of the rest of the wheels. Barely noticeable, but when it's your car, you notice.
04-08-2015, 01:12 PM | #20 |
Rep 1,470
Anybody try Auto Masters in Spring?
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
04-08-2015, 01:21 PM | #21 |
Rep 1,479
Drives: 2017 F80 M3
I think they went out of business.
04-08-2015, 02:34 PM | #22 |
Rep 1,470
Caliber Collision just used them on a wheel for me.
