04-07-2015, 10:15 PM | #1 |
Rep 487
Swift springs on a E92 with ZCP - won't lower as much?
I want to lower my car, but want to try and keep as much suspension travel as possible. I also have a E92 ZCP, which I know has 10mm lower spring perches. So I'm not too sure what to expect in terms of lowering.
I had the stock ZCP wheels, but recently got in on the APEX EC7 group buy, and with the 18s the car has more fender gap. After lots of research, I think I've settled on the Swift Spec-R springs here: http://www.redline360.com/swift-spri...e92-e93-4X903R It says it lowers the front 1.0" and rear 0.7". But I assume this is for non ZCP? What about with ZCP? Should I expect more or less of a drop due to the spring perches? I assume it'll be 10mm lower than this? Also, do I need to get E36 bump stops front and rear, or just front? With this amount of lowering, plus these bump stops, do I retain about the same amount of suspension travel as stock? Do I need to worry about rake? Any other recommendations?
2004 M3 E46 LSB 6MT
2008 M3 E92 6MT 2024 M4 Competition xDrive |
04-08-2015, 08:17 AM | #2 |
Grown Azz Man
430
Rep 3,021
The Swift springs are definitely the way to go. The E36 bump stops are optional and not a must have. Rake will not be a issue so no need to worry about that. The amount of drop is spot to what Swift advertises. My car actually looks lower when I have my 18" track wheels on. Just had someone ask me over the weekend if I got my car lowered (still have my track wheels on from a recent track day)........Phil
http://www.m3post.com/forums/showthread.php?t=1075755
2016 GT4.....Sapphire Blue Metallic, Platinum stitch Leather/Alcantara interior, Carbon Fiber Trim, PCM w/Nav, Guards Red Belts, 2 Zone Climate, Sport Chrono, LWB, Smokers Pack, Big Gas Tank, Light Design Pack, Bi-Xenon w/PDL, Auto Dim Mirror, Clear Side Markers, GTS Clear Taillights
04-08-2015, 04:31 PM | #4 |
Rep 487
So considering the ZCP has lower perches, won't it bit a bigger drop?
2004 M3 E46 LSB 6MT
04-08-2015, 04:32 PM | #5 | |
Rep 487
2004 M3 E46 LSB 6MT
04-08-2015, 07:19 PM | #6 |
Grown Azz Man
430
Rep 3,021
Yeah my car is ZCP and I got the advertised drop........Phil
