04-13-2015, 03:55 PM | #1 |
Rep 39
My M3 not shifting properly - DCT - Video
So, my transmission on my 2009 M3 was leaking, and took it back to the dealer for them to fix it under warranty, which they did. Since then, I have had an intermittent problem, where the car is not shifting properly. It happens mostly between 3rd and 4th, and 6th and 7th. It is most notable when I go to shift the car with no throttle applied, and the shift does not happen. You can see the shift happen, but you will notice that the revs don't change. Once I then step on the gas, the shift occurs, as you can see with the change in revs.
I have taken it back to the dealer for this, and they were unable to repeat the problem (which is why I took the video), and now I have to take it back to them, but was hoping some might have an idea what this might be, since the dealer can't seem to be able to figure it out. Last edited by PeteV; 04-13-2015 at 04:00 PM.. |
04-13-2015, 04:30 PM | #3 |
Rep 39
04-13-2015, 04:31 PM | #4 |
Rep 39
The transmission worked flawlessly, until the dealer touched it.
I agree with you about the leak, a transmission should not leak after 30,000 miles, but fixing a leak should not suddenly cause the transmission to go batty. |
04-13-2015, 05:22 PM | #5 |
Rep 951
Man sorry for your issues. I wanted a DCT after daily driving my M in traffic two years in a row but now I guess not, too many gremlins. One of the reasons I stayed away, the E46 SMG. Hope you get it resolved
04-13-2015, 05:44 PM | #6 |
Bad Lieutenant
233
Rep 3,517
It's difficult to hear if the revs are really reducing/increasing. Could it be a gauge cluster issue for the tach?
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
04-13-2015, 11:31 PM | #8 |
Rep 6,732
Wow that is odd. I wonder if they replaced your fluid with the right DCT fluid. It almost looks like there is slippage happening.
1. Maybe have them reset your DCT adaptation 2. Ask (or look) at your service invoice for BMW DCTF-1 (83 22 0 440 214) 1-litre can 3. Go to another dealer that may be more experienced with DCT's |
04-14-2015, 12:35 AM | #9 |
Rep 7,129
Agree with Bimmer, I'd double check what fluid they used. Make sure you get the part number yourself rather than take the dealers word for it.
Had a DCT leak sortet myself recently where the dealer filled MT fluid. Resulted in a new box, cooler and pipes. Good luck |
04-14-2015, 08:35 AM | #10 |
Rep 587
Drives: 2023 M3 CX
Here come the DCT bashers lol Its an excellent transmission and I have had 0 problems with it @58K miles. Shits all over my E46 SMG...
OP, my guess is software too. If it was working fine before the service, I don't think something hardware related. But like another member said, check to make sure the right fluid, and then ask again for a reset. Also, increase your shift speed and see if it still occurs.
2023 BG G80 ///M3 COMP XDRIVE Dinan CF Intake | Valvetronic SS Full Exhaust | AST Adjustable Springs | UNIT 17 Front Splitter | UNIT 17 Sideskirts | BC Forged HSC21 Wheels 20x10 et12 / 20x11 et12 |
04-14-2015, 09:47 AM | #11 |
Rep 7,129
Hi TO//M, I totally agree, following the M-DCT issue history it seems to be as close to bullet proof as it gets. Heck people have loaded S/C onto it for years and they still run fine.
The infamous leakage is annoying and I think a clumsy design by BMW, costly too if not covered by warranty. Filling with wrong fluid is potentially much worse, and even more clumsy by the dealer. Looking after these things I wouldn't be surprised if the box out live the rest of the car. |
04-14-2015, 10:47 AM | #12 |
Rep 39
04-14-2015, 10:49 AM | #13 | |
Rep 39
Also, I neglected to mention that this happens intermittently, not all the time. As far as I can tell, it's when the transmission gets hot. Does anyone have a recommendation for a location with an experienced DCT tech? I am in Irvine, CA, and work in Corona, CA. Last edited by PeteV; 04-14-2015 at 12:48 PM.. |
04-24-2015, 10:36 AM | #15 |
Rep 39
Took the car back to the dealer again (BMW Murrieta), and they say that the car is functioning properly, and to drive it for 1,000 miles for the transmission to "re-learn" how to shift properly. Sounds like BS to me. Anyone have another opinion?
04-25-2015, 10:18 PM | #16 |
Rep 6,732
I can send a video of a properly functioning DCT, and yours is not.
I'll try to drive it the way you desribe and see if my car behaves the same. I'd give Charlie at Mckenna a call since he is in LA and a forum sponser. Maybe he can give it a go. At least PM him to check your video. If it needs 1,000 miles to readapt... wow. Never heard of that fixing what you showed. |
04-25-2015, 10:42 PM | #17 |
Rep 791
Drives: 2011 550xi
DCT problems are such a blast. I was to the dealer 4 times for mine and they kept denying/talking their way out of it.
Now mine is leaking, so at least they have to fix it.
2017 Nitro Blue Ford Focus RS 2008 Sparkling Grey Metallic 135i 6MT - JB4 G5 - MHD Race BEF - N54Tuning DP's - ER Chargepipe/w HKS SSQV - Coolingmist Progressive Meth - MMP Hot Side Inlets - AFE Exhaust - Seconday Cat Delete - AMS FMIC - BMS Catch Can - Rob Beck PCV - LUX 160 AE |
04-26-2015, 02:13 AM | #18 |
Rep 7,129
Pete, if its the "re learn" they refer to, I believe this is done even without driving the car through SW programming. This was done when I recently got a new box, they did drive a few miles also but I believe this was for final check only.
04-28-2015, 01:55 PM | #21 |
Rep 39
04-28-2015, 02:59 PM | #22 |
Rep 24,863
Spot on !
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
