04-21-2015, 08:10 PM | #1 |
Rep 538
Anyone get INPA working for the MSS60?
Bought a cable for coding and so I could get setup with INPA for some basic diagnostics.
I have the hardware working, and I believe I can code just fine, however I noticed if I attempt to use INPA for diagnostics on the MSS60 DME nothing really works well. Everything is in German, and there are tons of script errors making it nearly useless. I have tried INPA 5.0.0 with older daten files as well as 5.0.6 with slightly newer files. Neither worked well, in fact the older one actually worked better. Has anyone gotten this to work? If so what versions of all the tools did you use? |
05-08-2015, 10:07 AM | #3 |
Rep 947
I bought a software with cable and return it for the same reason. That software is not original and is missing some archives. So you will be getting some glitches like not everything in English or missing coding options. I couldn't even install it!!!! After long hours of trying I gave up. I'm returning it and getting my money back.
