04-25-2015, 06:05 PM | #1 |
Rep 154
KW H.A.S. drop for a DD
So for those that are running the KW H.A.S. on their F82 and is using the car as a daily driver, what have you found to be the lowest drop in the front and back that still allows the car to clear speed bumps and inclines/declines without too much of a concern?
04-27-2015, 05:13 PM | #3 |
BimmerPost Supporting Vendor
8274
Rep 18,860
HAS will lower a max of 1" all around. Speedbumps will vary.
04-27-2015, 09:09 PM | #4 | |
Rep 154
04-27-2015, 09:11 PM | #5 |
8274
Rep 18,860
Varies on wheel/tire setup. Most will see about 0.75" up front and 0.5" in rear, or about a finger gap between tire and fender.
04-27-2015, 09:14 PM | #6 | |
Rep 154
04-27-2015, 10:20 PM | #7 |
Supreme Leader
2285
Rep 6,548
Drives: G80, 996GT2, 996TT, 991RS 356b
We've seen guys run the lowest setting (1.2 in front/rear).
It depends on if you have a front lip, how large the bumps ,or how steep the drive ways are in your area. The drop isn't quite as steep as the H&R at (1.3 front) for both the F80 and F82. How are the roads in your area? |
04-28-2015, 06:14 AM | #8 | |
Rep 154
Is it as straight forward as measuring the height of the speed bump and making sure my front end is at least that high off the ground? I don't have a front lip yet but am planning on eventually purchasing one after the drop if I still have enough clearance to avoid cracking it the next day. |
04-28-2015, 05:12 PM | #9 |
I'm not slow, I'm just Sloth.
14
Rep 32
Eibach Euro springs are pretty conservative at .8" in front and .2" in rear. My HAS is at .9" and .3" to start and can always drop further.
2015 M4 (12/14 build)- MG/SO, Executive, HK, Adaptive, DSG, 19" |
04-28-2015, 09:27 PM | #10 |
Rep 1,552
My HAS is set right about at the eibach specs. I'm happy with the look and so far so good with inclines and speedbumps
2020 M2 CS, 2018 M3 CS, 2016 M4 GTS, 2013 M3 LRP, 2011 1M, 2011 M3 GTRS3, 2004 M3, 2002 M3, 2000 M Coupe, 2002 M5, 1997 M3, 1988 M3, 2022 STO, 2020 Urus, 2022 TRX, 2022 392, 2021 SVJ, 2018 Performante, 2013 Gallardo 550-2, 2012 Gallardo STS, 2018 R8 RWS, 2012 R8, 2017 G550 4X4^2, 2015 GT3, 2015 Continental GT3R, 1971 Bronco
04-28-2015, 09:31 PM | #11 | |
Rep 154
05-01-2015, 11:23 AM | #12 |
Rep 646
Drives: IG: khanhdom
a little off topic but how is the spring rate for you guys? it scrapes when I hit a bump but didn't have a problem with my H&R springs and that was lower. How I currently sit:
05-01-2015, 01:40 PM | #13 | |
never could compete with Lloyd Braun
5276
Rep 5,382
I'm still considering the HAS so I can raise it up in the winter for snow lol
2022 G80 M3 6MT | Skyscraper Gray | Kyalami Orange
2018 F87 M2 6MT | Alpine White (sold) 2016 981 Cayman 6MT | Jet Black (sold) 2015 F80 M3 DCT | Tanzanite Blue | Gold Brown (sold) 2013 E92 M3 6MT | Mineral White | Fox Red/Black (sold) |
05-02-2015, 01:21 AM | #14 | ||
Supreme Leader
2285
Rep 6,548
I think you should have no issues with the drop. Fellow member Money2536 drives his F80 on the lowest setting on a daily basis in your area. I think he can give you the best feedback
SupremePOWER
1562 Kimberly Ave Fullerton CA 92831 Contact: sales@supremepower.com :: Shop# (714)632-1951 Sales & service of BBS Street & Motorsport products. BBS Highest Volume Dealer 2015 thru 2022 All the top brands at the prices and service you can count on. Professional installation. |
05-02-2015, 02:11 AM | #15 | |
Gone Fishin’
7318
Rep 12,125
Car rides great but the clearance problems the HAS is causing me are very frustrating. I also scrub rear a bit over huge bumps. My friend has same offset, tires, but H&R. He doesnt bottom out. I dont get it. |
05-02-2015, 02:24 AM | #16 | |
Supreme Leader
2285
Rep 6,548
If I were to take a guess, I think it would have to do with the "progressive" spring rates vs the linear spring rates of the H&R, as stated by KW. |
05-02-2015, 04:53 AM | #17 |
Gone Fishin’
7318
Rep 12,125
05-02-2015, 02:22 PM | #18 |
Supreme Leader
2285
Rep 6,548
05-03-2015, 12:53 AM | #19 |
Gone Fishin’
7318
Rep 12,125
Yeh man it makes no sense. The only thing i see is the side that rubs is .2 HIGHER than the rear side that is fine and the camber on the right side is .1 degree higher. The passenger rear just barely knicks the inner liner on big bumps on the highway. Driver rear never.
05-03-2015, 12:58 AM | #20 | |
Supreme Leader
2285
Rep 6,548
JK JK. It really is peculiar that you're experiencing that. Hmm... Lets see if Eric can chime in here for you
SupremePOWER
05-03-2015, 10:51 AM | #21 |
Gone Fishin’
7318
Rep 12,125
I actually do think I want to do coils now just not sure which ones yet. Pyspeed is being awesome and replacing my front wheels for free so I dont have to run spacers.
05-03-2015, 11:18 AM | #22 |
5276
Rep 5,382
That's awesome! Great customer service on their end wow.
