05-03-2015, 06:13 PM | #1 |
Rep 184
Rotors/Free Maintenance question.
My car falls off free maintenance in a couple of weeks. I noticed today that the front rotors have quite a lip around the edge. Is it safe to assume they will fall within the minimum tolerance and need replacement? Sorry for the crappy picture I had to crop it for it meet the forums max attachment size.
05-04-2015, 12:10 AM | #3 |
Rep 41
Drives: '13 E92 M3 ZCP MineralWhite
never hurts to ask. When my maintenance was almost up, my stealer said my rotors are 0.2mm (not a typo) more than the threshold and so they refused to change them.
05-04-2015, 04:35 AM | #4 |
Rep 2,445
Drives: 2022 M3 6MT
My dealer said that my rotors were warped but pads were fine so refused to change them. I had to make a big stink about it to get anything done.
2022 M3 6MT - Portimao Blue Metallic
2022 X3 M40i - Tanzanite Blue Metallic |
05-04-2015, 08:45 AM | #5 |
Rep 1,067
Drives: 2017 M3 ZCP / 2017 RRS SC
Are those OEM M3 rotors? They should be cross drilled if they are.
Have you had the brake pads replaced before but the rotors we said to be within spec? If so you may have a chance. You may be able to get BMW to evaluate the brakes if you make a complaint about the brake feel, weird intermittent vibrations or sponginess. You may not be successful walking in saying you need your brakes replaced because of the way they look. They are usually pretty strict on when the "car" tells them the brakes need service.
17 M3 ZCP -- 2017 Range Rover Sport SC --RIP-- 12 X5 50i Sport -- 11 M3 DCT -- 2011 X5 50i(Lemon) -- 2008 550 Msport -- 2007 x5 4.8 sport -- 2004 545 sport -- 2002 x5 4.4 sport -- 2001 540i Msport 2000 SL500 -- 1997 SL500 |
05-04-2015, 12:30 PM | #7 |
Rep 11,891
What does CBS say?
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
05-04-2015, 01:41 PM | #8 |
Rep 2,982
Well...whatever the case is, make sure you get within replacement spec and get that covered. The service is not cheap. And yea, why aren't they drilled?
05-04-2015, 02:33 PM | #9 |
Rep 2,527
Drives: 2011 M3/Porsche 992 GT3RS
Garage List 2024 Porsche 911 GT3RS [0.00]
2021 Porsche 718 Sp ... [0.00] 2021 Mazda Miata MX-5 [0.00] 2006 BMW M3 [0.00] 2011 BMW M3 [10.00] |
The rotors are going to cost you a thousand dollars just in parts for all 4 corners.
05-07-2015, 02:54 AM | #10 |
NewFinishColumbia/detailer
604
Rep 2,096
How long do the stock brakes usually last between $1000 cost is dropped out of the account should you have to pay for them out of pocket? You could shave that 20% off in a day on the right roads.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project http://www.instagram.com/steve_inf31 |
05-07-2015, 08:52 AM | #12 |
Rep 273
05-07-2015, 08:58 AM | #13 |
Supreme Czar
309
Rep 779
I have 85k on my original front rotors, still working just fine!
05-07-2015, 11:13 AM | #14 |
Rep 2,982
You must literally drive 99% hwy in rural areas or you only engine brake.
Whatever it is, I can guarantee you, you're not having as much fun as you should before your rod bearings blow up and you don't have this car anymore. |
05-07-2015, 11:16 AM | #15 | |
Rep 7,129
05-07-2015, 11:43 AM | #17 |
Supreme Czar
309
Rep 779
I bought the car last year with 76k miles, no idea how it was driven. I've heard of some E9* M3's (on this forum) with over 90k on original front rotors.
05-07-2015, 02:43 PM | #18 |
604
Rep 2,096
If you have good brakes you better have good money too. Eventually she's gonna cash that chip in.
05-07-2015, 03:29 PM | #20 |
Rep 381
BMW changes your rotors when you need new pads under their maintenance plan. So if you have OEM pads, run them down and you should get new rotors and pads.
05-07-2015, 04:44 PM | #21 |
Rep 41
I don't think so. I have had pads replaced without rotors under maintenance plan. They measure the rotors and replace them only if they are under spec.
05-07-2015, 04:55 PM | #22 | |
Rep 381
I've had two sets of front rotors replaced with new pads. The front rotors were 1mm (29.44 mm) away from minimum width (28.4) and the pads were low enough to trigger the service light. My service advisor told me that's how they always do it with the M cars since they cannot resurface the rotors at the dealership. Even if they didn't replace the rotors, I would be extremely disappointed if they didn't at least resurface the rotors when they put on new pads. I would talk to your service advisor. Perhaps, he kept your expensive rotors and sold them for profit. lol Dealerships are not run by angels, hence the common name on these forums, "stealership." |
