05-06-2015, 08:29 AM | #1 |
Rep 93
Car in production missing Adaptive M Suspension and 20" wheels
So my car just went into Production phase yesterday and it lists below all the options I ordered. The problem is I am missing both the Adaptive M Suspension and 20" wheels I ordered. Do these get added in day 2 or 3 of Production or is there a mistake? I pulled up my final order and they are definitely both listed on the final invoice put into system by the dealer.
any thoughts here? |
05-06-2015, 08:55 AM | #2 |
Rep 5,066
If it is on the build list ( which it is) , then it should not be an issue.
Your car was probably a dealer lot car that they already had speced out and typically you will get different options listed on the BMW website. Some people had totally different colored exterior in the past. |
05-06-2015, 08:59 AM | #3 |
Rep 8,833
run your Vin through bmwvin.com
If its on there you are good. The online tracker isn't accurate half the time because it shows build that was originally scheduled by BMW.....not your actual build which is a modified version of that same build. Alan
