05-11-2015, 06:48 PM | #1 |
Rep 1,726
Streetable track pads...do they exist?
Just wondering...
I ran Hawk HPS 5.0 pads on the B8 S4 for street and 4-6 DE days a year to good effect. Minimal squealing and acceptable hi-temp resistance for my Level 1 ability. Pagid RS29s seem to be the goto track pads. If wondering if there is an intermediate pad offering that would allow me to be lazy and forgo swapping in/out. Or is the OEM pad acceptable with hi-temp brake fluid?
My Trackable Street Car
2016 BMW M4 GTS |
05-11-2015, 08:06 PM | #2 |
Rep 5,678
If you REALLY don't want to swap, I would stick with OEM. Nothing I am aware of yet that would be a better dual purpose.
You will, however, be giving up a lot of performance relative to swapping pads IMO.
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 |
05-11-2015, 08:33 PM | #3 |
Enjoying driving
388
Rep 1,169
I don't know if they make the RS19s in proper size for our cars, but they squeel a little less than RS29s. I used the 29s year around without swapping on my previous cars, and besides my son, no one complained
Also my experience with RFC08s was that they were less noisy. |
05-11-2015, 09:54 PM | #4 |
Rep 265
No. Track pads have a higher operating temperature which can't be maintained on the street. Street pads that provide good cold stopping power will fall apart with the high heat of track driving. Play it safe and use track pads imo.
05-11-2015, 10:30 PM | #5 |
Rep 3,834
The guys in my BMW club all uses PFC pads for street and track. Most don't swap them. They do squeal, but tolerable.
Too bad no one carries PFC for the F8x yet. Maybe it's a special order item.
Daily: G12 750 MSPORT Weekend Car: E90 M3
05-12-2015, 05:51 PM | #6 |
Rep 1,415
Anyone think its a good idea to swap to RS29s for track, and then back to stock pads for the street?
If I only track once every few months, this would be preferable but is there issue with swapping and the effect on the rotors? |
05-12-2015, 07:51 PM | #7 |
Rep 5,678
It's fine... drive home from the track with the RS29's on and they will self clean the rotors. No issue at all.
05-13-2015, 11:39 AM | #8 |
Rep 1,191
I used Carbotech's on my Mini, XP10 in front and XP8 in the rear. One year I left them on all summer and into fall, down to ~45-50degrees. They stopped fine at all temps and in the rain. They produced quite a bit of dust and has some minor squeal, but not too bad.
Once I stepped up to XP12 fronts, I found that they were too aggressive on the rotors and if driven when cold they would remove the pad material layer that you want to have on the face of the rotor. I would not drive XP12's on the street.
2015 M3, 2005 330i ZHP, 2015 228i 6MT Track Handling Pack, 2007 M Coupe (Sold)
05-24-2015, 10:52 PM | #9 |
Rep 1,726
anyone pair up Pagi RS29 in the front and OEM pads in rear? or is that difference/brake bias too great?
2016 BMW M4 GTS |
12-17-2015, 07:54 PM | #10 | |
Supreme Allied Commander
3888
Rep 54,553
Drives: F80 M3
As an alternative, Ferodo has their DS2500 compound, which is suitable for street and light track day, for the F8x M3 M4 now. |
01-21-2016, 04:40 PM | #11 |
Faster on 2wheels
131
Rep 381
I'm going to run Ferodo's at THill this weekend and leave them on after. Reviews to follow.
01-24-2016, 08:45 AM | #13 |
Rep 20,742
Drives: 2021 911 turbo
I ran the RS29 on the street for most of the summer without issues. They are not that noisy, only occasional peeps and the slap from forward to reverse transition. I did not suffer any garbage truck squeal like I had experienced with other track pads.
I only put the OEM pads back on when we took our 3 week vacation road trip. I would definitely not recommend OEM pads for track use. While they perform "well enough" at the track with a lot of management, they just melt away with any serious track use. And you are likely to get uneven deposits which results in annoying brake shudder.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
01-24-2016, 10:38 AM | #14 |
Rep 10,176
I had RS19s in my e92 M3, that occasionally I would be too lazy to swap out between events, and they made my car sound like a 50 year old Sanford & Son dump truck on the street.
I've tried intermediate pads, like Hawk HPS, and since I am an advanced driver, they melted on fast/hard braking tracks like Watkins Glen, just like factory pads do for me. They leave lots of deposits on the pads and forced me to find different braking points (which isn't fun). Which brings me to a point... We have not talked about the driver's ability yet. If the driver is in a novice or even intermediate (for some/most clubs), changing the fluid might be enough. For fast intermediate and advanced run groups, get real pads suited for the track. I recommend the same for street vs. r-comp tires. Lastly, these calipers make it sooo easy to swap pads, it's as easy as swapping tires. Don't be lazy and sacrfrice safety. |
01-24-2016, 10:52 AM | #15 |
Rep 1,726
i ran rs29 front and oem rear for 2 track weekends (4days), one weekend at VIR and one weekend at Summit Main. Running motul 600 fluid
i'm an intermediate group driver. brake bias was likely affected but i did not have a baseline for comparison. i did notice the rear end get alittle light on hard threshhold braking going from a 135 mph front straight to a 40-50mph decreasing radius corner. of course, i was braking hard in a straightline, so no harm. but i'm sure if there was moderate steering input, there would have been squirrely-ness or perhaps oversteer. however, not sure if the rear end squirrely-ness was necessarily related to the brake bias, as i've read a few track rat reports of the F8X doing this even with equal pad type front and rear. maybe this means this car needs more rear downforce? or firmer front springs/compression damping? or more aggressive pads rear compared to front?
2016 BMW M4 GTS |
01-25-2016, 08:09 AM | #16 | |
Rep 3,453
But my guess is the weaker rear pads contributed to this. |
