05-19-2015, 02:54 PM | #1 |
Rep 142
alignment problems (can't get to the spec i want)
Hey guys
I am running into some problems with my alignment setup and I couldn't figure out why. I bought the car last month, the car got into small accident but it's not frame damaged (only cosmetic and alignment was off). I then put on a set of Ohlins DFV and camber plates and took it to alignment and fix it. However, I ran had problems dialing it to the spec I desired. P.S Car is a 08 MT with 92k miles, and the previous owner spun out a few times on track 1) My front right camber only goes up to -2.8, while my front left goes to -3.4 (my friend who i bought this setup from can max out his car at -3.9) 2) My rear right toe only goes to 0.08 while I was aiming 0.18. Also, my steering wheel position did not get properly aligned after alignment. My question is, is it because my bushings/control arms/toe links are old? or is it simply because the guy didn't do it right?
2008 JZB 6MT
Brembo + Hawk DTC70 / JRZ RS Pro / Varis Diffusers / GT4 Lip / TE37 SL / NT01 275 Square / Akrapovic Evo / Recaro Red PP / Back Seat Removal / APR GT-250 & GT4 lip + Chassis Mount Front Splitter + Canard / Motul 5W-40 & RS683 Brake Fluid Life is too short to drive boring cars |
05-19-2015, 04:00 PM | #2 |
Retired Curmudgeon
2992
Rep 4,063
Ok, silly question but are you sure you put in your camber plates correctly (and the same each side)? You can rotate them by 120 or 240 degrees inadvertently during install...
As for toe in at the rear, why do you want 0.18 (are we talking inches or minutes or ?) on each side? Isn't that more than the spec calls for? This isn't an old trailing arm suspension that benefits (stability) from a lot of rear toe. At 92k miles, you could have bad bushings, ball joints, etc. contributing to the alignment issues.
'19 X3 M40 Carbon Black/Oyster, '21 X7 40i AW/Black, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
05-20-2015, 08:52 AM | #3 | |
Rep 633
Bottom line, either have it read manually or take it to the race shop who will do corner balancing and proper alignment. These machines can be off calibrated. On our cars, the bushings are SUPER stiff and wont allow for flex (off alignment) unless something is bent (I did bend the rear trailing arm or whatever its called with a bunch of holes in it). Good luck and try not to worry much ask me how I know. Cheers, Lutfy |
