05-19-2015, 09:14 PM | #1 |
Rep 158
Another Euro Eibach review + track eval
I thought it may be time for me to contribute now that I have some experience with the Euro Eibachs on both the street and track. I was going to just add a comment on another Euro spec review but I started getting off topic so I figured a new thread was in order.
I got the Euro Spec Eibachs last month (April) as something to hold me over until I can get a set of coilovers (patiently waiting on the Ohlins…) because I wasn’t fond of the gap but didn’t want the car slammed and wanted something that was track-worthy. The Exiges I had came with Eibachs standard and were very capable so I figured it was a good bet given the relatively low cost. I also ordered from Baan Velgen on a Sunday night and they were at my door on Thursday. I installed the fronts when I received the shipment last month and the rears last week (split it just due to time) and didn't initially get an alignment. I was, however, very diligent in getting the rear bolt aligned to where it was pre-spring install. I knew the alignment would change with the springs even if everything was set exactly pre-install, but I figured this would get me around until I could get an alignment. Similar to another poster on here the car had a bit of a drifty tendency on those big sweepers afterward, but then a used Cayman I had was the same way the first time I drove it hard. I got an alignment on the Cayman and it was a totally different driving experience afterward. I just got an alignment on the M3 and it definitely felt better after the alignment, but it does *seem* lighter in the front. Another car buddy, who also has a F80, did the ever scientific stand-on-the-spring-and-see-which-is-stiffer compression test and the Eibach appeared to compress less vs stock. However I agree it does feel softer at high speed. At low speed in a parking lot the Eibachs seem stiffer Valving on the dampers not matching the spring rate closely enough? Now, just speaking theoretically is a softer front spring a bad thing? I'd say with the amount of stock understeer the car has, probably not (if nothing else changes.) I just had the car at VIR with the Euro Eibachs this past weekend and the car was still very solid - still understeering but a lot of it was me going too hot into some corners and temps close to 90 degrees. So what's my final verdict? It may feel a little lighter in the front but the car seems to stick at least as well as the stock suspension. Interestingly enough, I’ve been tracking cars at VIR for 8 years and have never been on the South course until this past weekend. If I had been on the South course before I would have a better idea of old vs new, but the two common elements to the South and Full courses, turn 10 and Oak Tree, were very stable at speed. I'm looking forward to going to the track with these springs again and giving them more of a shakedown. -Tom
2015 M3 DCT (sold) 2008 Lotus Exige S240 - too many mods to list (sold) 2007 Lotus Exige S (RIP) 2006 MINI Cooper S (sold) |
05-19-2015, 09:15 PM | #2 |
Rep 158
One of the guys that co-owns the garage I was able to use had his set of F80 H&Rs still in the box, so I thought it was a great chance for a photo op and comparison of the stock springs, Euro Eibach, and H&R. The rear spring picture is just Eibach vs H&R as I didn't change the rears that evening (it was already midnight when we finished the front....)
^^ Front H&R, Euro Eibach, Stock ^^ Rear H&R, Euro Eibach
2015 M3 DCT (sold) 2008 Lotus Exige S240 - too many mods to list (sold) 2007 Lotus Exige S (RIP) 2006 MINI Cooper S (sold) Last edited by tcpsoft; 05-20-2015 at 08:41 PM.. Reason: Added pics |
05-19-2015, 09:15 PM | #3 |
Rep 158
And the requisite side pics. The fronts have about three weeks and 500 miles and the rears one day and almost no miles in these pics (so may still settle a bit....) I was in a hurry and the full side pics ended up washed out, so we have front and rear half closeups.
2015 M3 DCT (sold) 2008 Lotus Exige S240 - too many mods to list (sold) 2007 Lotus Exige S (RIP) 2006 MINI Cooper S (sold) Last edited by tcpsoft; 05-20-2015 at 08:55 PM.. Reason: Added pics |
05-20-2015, 05:53 AM | #5 |
Rep 1,191
It may feel softer because lowering the car also lowers the roll center, so even though the vertical stiffness is increased, the roll stiffness may actually be less than stock unless the spring rates are *significantly* higher than stock.
I don't know anything about the euro eibachs, but that would explain what you're feeling. That whole "lowering screws up geometry" thing is actually true.
2015 M3, 2005 330i ZHP, 2015 228i 6MT Track Handling Pack, 2007 M Coupe (Sold)
05-20-2015, 11:38 AM | #6 | |
Rep 20,742
Drives: 2021 911 turbo
As another question for you, there have been numerous debates regarding constant rates springs vs variable rate springs. Can you share your point of view on the two?
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 05-20-2015 at 11:45 AM.. |
05-20-2015, 11:55 AM | #7 |
Rep 20,742
OP, thanks for sharing your experience.
I have been on the fence regarding the Eibachs for a while now. I also find that the cars sits a little too high and would have like the slight drop provided by the Eibachs. However, changing spring rates without changing damper rates goes against much of what I believe in, hence my hesitation.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
05-20-2015, 03:09 PM | #8 | ||
Rep 1,191
As far as variable rate springs go, I think linear rate is better purely from a handling standpoint. But there are many other factors that make progressive rate springs a better option (or sometimes the only option) for a street car. Ride quality is only one of the factors, but definitely a big one. The linear vs. progressive rate decision is one that has to account for a huge amount of factors, from the load carrying capacity of the car to the durability of the wheel and tire and body to the assembly method in the plant. Quite often that decision is made very early on when the car is first being designed, and well before the ride engineers get their hands on it.
05-20-2015, 04:37 PM | #10 |
Rep 1,191
Edited my post above to answer your question about variable rate springs.
05-20-2015, 09:02 PM | #11 | |
Rep 158
Pics updated
05-20-2015, 09:08 PM | #12 | ||
Rep 158
2015 M3 DCT (sold) 2008 Lotus Exige S240 - too many mods to list (sold) 2007 Lotus Exige S (RIP) 2006 MINI Cooper S (sold) Last edited by tcpsoft; 05-20-2015 at 09:18 PM.. |
05-20-2015, 09:10 PM | #13 |
Rep 20,742
Great thread. Thanks for the pics, they are quite revealing .
05-20-2015, 09:29 PM | #14 | |
Rep 158
05-20-2015, 09:42 PM | #15 |
never could compete with Lloyd Braun
5278
Rep 5,385
Thanks for the review! Even tho you have two photos, I'd still be interested to see a full on profile pic once the rears have some miles on them and settle fully.
05-21-2015, 12:50 AM | #16 |
Rep 680
05-21-2015, 10:26 AM | #17 |
Rep 501
Damn these were the springs i was going to put on the (eventual) F80... very disappointing to hear about this floatiness. Ill say again i dont understand why kw doesnt make the V1 for this car
05-22-2015, 07:54 AM | #18 | |
Rep 20,742
When you purchased the Euro Eibach, did you know for sure they had a fixed rate?
05-22-2015, 08:51 PM | #19 | |
Rep 158
From everything I can tell these are linear rate springs. I agree its hard to discern from the pics but in person they definitely don't appear or feel progressive.
05-27-2015, 10:28 PM | #20 |
Rep 155
Just a thought here; but if the spring rate increase was higher in the front springs than on the rear springs, it would cause the car to feel lighter in the front because it is shifting the balance of the car rearward.
Reason I say - I have the Euro Eibachs as well. I re-aligned the car by slightly increasing toe-in front, caster/camber unchanged since they are not adjustable on stock suspension. Rear I aligned to -1.8 degrees and 1/16th of toe. I have noticed the car pushes more now than it did with stock suspension. I really believe the reason is that the front spring rate increase is higher than the rear springs. I didn't put my car on scales to confirm this but I would put money on it. - Chris |
06-10-2015, 09:07 AM | #22 |
Rep 20,742
As a piece of info, based on info shared in the Eibach thread, it seems like the Euro Eibach spring have a lower spring rate than the OE one. This could explain the "floatiness" the OP has experienced.
