05-21-2015, 10:59 PM | #1 |
Supreme Leader
2285
Rep 6,548
Drives: G80, 996GT2, 996TT, 991RS 356b
Bilstein B16 PSS9 PSS10 coilovers released for F80 M3 / F82 M4
Featured on BIMMERPOST.com SUPREMEPOWER 1025-B Ortega Way Placentia CA 92870 (714)632-1951 sales@supremepower.com Bilstein Suspension Part Number: 48-244091 Weight (lbs): 40 Series: B16 (PSS10) Position: Front and Rear Descriptor: Without Electronic Suspension Quantity Per Vehicle: 1 Internal Design: Monotube Finish: Dampers: Zinc/Springs: Blue Front Damper: F4-31244077-H0/F4-31244091-H0 Rear Damper: F4-26244091-H0 BILSTEIN B16 - PSS9/PSS10 The engineers at BILSTEIN have created the ultimate race inspired suspension—the BILSTEIN B16 PSS9/PSS10. This innovative suspension system delivers unsurpassed driving performance. The manually adjustable damping mono-tube gas shock absorbers feature 9 or 10-stage precise compression and rebound settings, from comfort to competition. The threaded body allows accurate adjustability of the front and rear progressive rate springs to achieve the vehicle ride height, center of gravity and level of performance handling desired. The Bilstein B16 system puts you in complete control, providing the kind of precise suspension tuning formerly available only on race cars. From a weekend of competition to daily driving, this system provides perfect handling performance for every situation. Features and Benefits: - Individual settings ranging from maximum Comfort to aggressive Sport can be selected by the twist of a dial (9 on PSS9, 10 on PSS10) - Threaded body adjustable range of 20 mm at both axles - Lowering of approx. 30-50 mm at front and rear - Road-tested and fine-tuned by BILSTEIN ride engineers, under extreme motorsports conditions - Spring plates and lock nuts made from a special aluminum alloy - Surface coating using Triple-C-Technology®for long-lasting corrosion resistance - Round threads for easy adjustment - Quality sport springs made from highly durable material - Quality sport springs made from highly durable material - Gas pressure technology - BILSTEIN monotube technology, made in Germany
SupremePOWER
1562 Kimberly Ave Fullerton CA 92831 Contact: sales@supremepower.com :: Shop# (714)632-1951 Sales & service of BBS Street & Motorsport products. BBS Highest Volume Dealer 2015 thru 2022 All the top brands at the prices and service you can count on. Professional installation. Last edited by supremepower; 05-22-2015 at 10:14 AM.. |
05-21-2015, 11:01 PM | #2 |
Supreme Leader
2285
Rep 6,548
SupremePOWER
1562 Kimberly Ave Fullerton CA 92831 Contact: sales@supremepower.com :: Shop# (714)632-1951 Sales & service of BBS Street & Motorsport products. BBS Highest Volume Dealer 2015 thru 2022 All the top brands at the prices and service you can count on. Professional installation. |
05-22-2015, 05:57 AM | #4 |
Rep 549
Cool! It will have the same 3 settings like stock?
F80 M3 SO/SO |BM3 St.1 91 oct.|Cattless DPs|Tractive P'n'P|Brembo 6pot|Rays G25 with CUP2 tires|GTS coding|
1M VO FBO (KW DDC) PTF st.2+ sold e90 335i FBO jb4 sold |
05-22-2015, 08:31 AM | #6 | |
Rep 1,191
2015 M3, 2005 330i ZHP, 2015 228i 6MT Track Handling Pack, 2007 M Coupe (Sold)
05-22-2015, 08:51 AM | #7 |
Rep 3,834
The PSS10 has 10-click setting. Each click changes the rebound and compression dependently. This is not to be confused with the B16 Damptronic that's releasing later this year.
Correct, they're aren't Damptronic. I think OP meant they will work as long as you code out EDC, but it's not integrated with EDC. Expect Damptronic to cost $1,500 more. Bilstein are known for easy adjustibility, you just dial it in for the street and leave it alone. For the track, you dial it up. All knobs are extremely easy to locate and adjust. The height adjust is also easier than most coilovers.
Daily: G12 750 MSPORT Weekend Car: E90 M3
05-22-2015, 08:57 AM | #8 | |
Gone Fishin’
7318
Rep 12,125
05-22-2015, 09:07 AM | #9 | |
Rep 3,834
Everyone: This is not to be confused that PSS10 = V3. It's more comparison to K&W V2. People who had Bilstein B16 loves them. I would consider these b/c it lowers less in the rear compared to the V3 (min 5mm vs 25mm). For the street, there's no need to mess with rebound and compression independently (it would confuse the average driver). Having one knob to adjust per shock is welcoming. Also, I like how Bilstein covers up the shaft to protect it from dust/sand = reduce pre-mature failure due to dirt/sand destroying the seals. Do expect these to ride firmer than K&W V3.
05-22-2015, 10:16 AM | #10 |
Supreme Leader
2285
Rep 6,548
JNoSol is correct! There is an error in the post
We apologize for our mistake! Thank you Jimmy for correcting it for us and staying on top of it The Damptronics are the correct suspension set up that will enable full use off the Adaptive M-Suspension. PSS10's are available now, but the Damptronics are a working progress
SupremePOWER
05-27-2015, 09:40 AM | #13 |
Rep 3,450
Seems very legit!
"Well, there's a straight-six engine at the front, a manual gearbox in the middle and drive goes to the back. That's Page 1, Chapter 1 from the petrosexual handbook" - JC
05-27-2015, 12:55 PM | #19 | |
Supreme Leader
2285
Rep 6,548
PM coming your way!
SupremePOWER
05-31-2015, 05:33 PM | #21 |
Rep 635
05-31-2015, 05:54 PM | #22 |
Rep 3,834
Please confirm the lowering spec again. I was under the impression that the min drop is 30mm front and 5mm rear (not 30mm-50mm front and rear), which is ideal as the rear of the F8x is already low enough.
