05-23-2015, 06:35 PM | #1 |
Rep 49
Spongey brake pedal
After installing my AP bbk I bled all the brakes with racing fluid. They felt a bit spongey so I asked my dealer to sort them for me - the pedal is still spongey. Brakes work well, well enough to lock front wheels if needed but the spongey pedal is frustrating.
I'd say there is at least an inch to two inch of travel before I can feel any real reaction out of the pedal whereas before and with my friends car on AP the pedal is very positive and reacts immediately with little pressure. Any thoughts? Fixes? Thanks |
05-23-2015, 06:55 PM | #2 |
Rep 1,711
When you replace brake lines and calipers, it introduces a lot of air in the system. You need to bleed many many times. It may take up to 3 liters of brake fluid or even more to remove all of the air from the brake system.
Good luck |
05-23-2015, 08:16 PM | #3 |
Rep 1,470
Use vacuum bleeder. Had same problem when I put Stoptechs on a friend's 997.2 GT3RS.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
06-03-2015, 07:02 AM | #4 |
Rep 4,633
You need DIS or INPA to do a full bleed, you need to activate the abs pump to really get all the air out esp after a caliper change.. I would think the dealer would do this but those techs are lazy people.. Each caliper needs the abs to be activated
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
06-03-2015, 06:54 PM | #5 |
Retired Curmudgeon
2989
Rep 4,057
Do the APs have two bleeder screws per caliper? This happened to someone on another forum -- they didn't realize there was another bleeder on each caliper.
'19 X3 M40 Carbon Black/Oyster, '21 X7 40i AW/Black, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
