New 2009 2010 BMW Z4 - ZPOST
      05-26-2015, 10:33 AM   #1
pavproch
Drives: Z4 3.0i & 330ixT
ED - a p.i.t.a. ... anyone tried a swap to servo?
Am I the only one, who gets annoyed by a complete numbness of ED (electric steering) our Zets were born with?
Anyone anywhere heard/read about a swap to classic hydraulic (servo) steering from e90/91 lineup?
My daily - 330ix e91 MY2011 - fortunatelly has a servo and the feel (for what is actually happening underneath the front rubbers) is simply overwhelming.....
Daily:330ix 6MT - PBX, HR SportSprings, Koni Yellows, OZ Ultraleggera 18", PI+PE, CDV off, UUC sways, M235i SportBrake (front), Cquence rotors (rear), 3.64 diffs, LSD rear
Funcar: Z4 3.0i 6MT - HR SportSprings +sways, OZ Ultraleggera 19", 5.00 diff by Drexler, CDV off, Quaife LSD, M235i SportBrake (front), Cquence rotors (rear)
      05-27-2015, 09:28 AM   #2
nicknaz
nicknaz's Avatar
3189
Drives: C6Z
Before you do anything drastic, how about taking your car to see if there is later software that can be reflashed? Steering software has gotten better over the years
      05-27-2015, 10:07 AM   #3
pavproch
Not decided yet, just started probing.... nonetheless, thanks for a hint, will have the SW checked....
      05-27-2015, 03:28 PM   #4
wmandra
Track Addict
wmandra's Avatar
99
Drives: 2010 328i, 2014 Z4
replace front tension arms with parts from e9x M3 and change bushings to Rogue Engineering version... night and day difference. The EPS system in the E89 is actually really good compared to previous generations.
Driver, Ratchet Head Racing #93 BMW Z4
Club Organizer, Garden State Euros Motorsport Division
2014 Glacier Silver Z4 28i M Sport - See the build thread: http://e89.zpost.com/forums/showthread.php?t=950367
      05-27-2015, 07:29 PM   #5
Hujan
Hujan's Avatar
Does one need to replace front tension arms from the E9x M3 in order to use the Rogue bushings? Rogue's website led me to believe the bushings would work on the OEM tension arms that came on the E89. I was planning to swap them in when I did coilovers.
http://www.rogueengineering.com/rogu...E-TAB-E9X.html
      05-27-2015, 11:16 PM   #6
pavproch
Hey, guys, thanks for guiding me into the areas I never thought of.
      05-28-2015, 12:08 PM   #7
Asbjorn
Asbjorn's Avatar
China
90
Drives: Z4 N54 DCT (VTT GC lites)
The steering is not numb, it is comfortable. It is a feature you know! And you get less comfort/numbness by selecting DSC=off or sport+ (sport and sport+ are not the same - steering feel wise imho). I personally often cruise around with DSC off just because of the improved steering feel.
btw I do not like the steering feel in sport and normal much, but one thing I do notice is that tire pressure and toe adjustments can still be felt, and impact the overall feel in all modes. I am sure that downgrading to less comfortable / more sporty E9x M suspension links, like suggested above, can be felt as well.
      05-28-2015, 12:20 PM   #8
pavproch
Well, the ///M tension arms and RogueEng. bushings are already high on a list of mods to be done next winter...
Gotta admit that most of my driving time the BC reads "sport", I am a bit afraid (of myself ) driving prolonged periods of time with my guardian angel (read: DSC) turned off. So, next time I am switching into "Sport+" I will try to feel the difference...
Thanks.
      05-28-2015, 03:54 PM   #9
Hujan
Hujan's Avatar
As someone that drives both a stock Z4 35i and an E92 M3 with aluminum, sealed monoballs in the front tension arms, I can tell you the steering in the E92 M3 is far superior, but the Z4 35i is not bad for a stock electronic car. Not by any means. Assuming they will fit, my plan is to throw the Rogue bushings that I never put in the M3 into the Z4 to see what that feels like.
As I continue to replace arms on the M3, I may consider moving them over to the Z4. Heck, if the Z4 did not have an electronic rear parking brake, it would already have the OEM brakes from the E92 M3!
      05-29-2015, 10:51 AM   #10
wmandra
Track Addict
wmandra's Avatar
99
see this thread http://e89.zpost.com/forums/showthread.php?t=879624
      05-29-2015, 12:48 PM   #11
pavproch
Wow, thanx.
Somehow I´ve missed that thread yet.
      05-30-2015, 10:50 AM   #12
pavproch
Been off, having wind in my hair...
Well, did not forget to flip the selector between "sport" and "sport+" forth and back several times, but felt no difference in steering quality/responsiveness at all.
Either my Zet of early series - fabricated May 2009 - has the same steering settings for both "sporty" modes or I am less sensitive driver than asbjorn...
      05-30-2015, 12:24 PM   #13
Asbjorn
Asbjorn's Avatar
China
90
Mine is from the same year but EU/China model of course. Try driving in slaloms, constantly turning the steering wheel left and right at constant speed while switching between sport and sport+, or normal and dsc fully off. At least this test should tell you about the difference in weight and transparancy. Sport should feel more filtered and damped/rubbery, but almost as heavy as sport+. The difference between dsc off and normal is bigger, and perhaps a better place to start discovering the differences because it wont influence the adaptive dampers if you have those.
Anyway, another solution is selling the 3 series and get a 5 series with variable eps steering instead. Then you will love the sporty non variable eps of the Z4 haha.
      05-30-2015, 01:04 PM   #14
pavproch
all right, next time I will snake a bit
      06-26-2015, 12:23 PM   #15
pavproch
Well, today I took a liberty to make myself a day off .... selected sport+ first thing in the morning and rode into the dawn .... 499.4 kilometers snaked.... you were right, the steering feel of sport+ seems to be slightly more convenient compared to "ordinary" sport mode.... thanks for hinting me....
      07-08-2015, 08:34 AM   #16
pavproch
Deed is done, Rogue Eng. control arm bushings ordered.... (via their UK-based retailer)
      07-09-2015, 12:02 AM   #17
Asbjorn
Asbjorn's Avatar
China
90
Looking farward to hear your review!
PS Unless it is raining I usually just use DSC=off (not DTC traction) to get the sport+ steering feel without the aggressive DCT and throttle behaviour
zpost
