05-26-2015, 03:08 PM | #1 |
Rep 501
6 piston gold calipers
Im curious as to the possibility of installing the gold 6 piston calipers on the f80 with non ceramic rotors... there's a vendor selling a kit with these calipers and iron rotors for the previous M3... would be nice to just swap the blue 4 piston calipers for these...
06-05-2015, 12:56 AM | #3 |
BMW Motorsport
237
Rep 2,225
Drives: BMW ///M4 F82 / BMW ///M5 F10
i think it must be doable but I wonder if using the M5 version of the caliper would be the easier option?
Neil J. //McRae -- Alive and Kicking -- neil at DOMINO.ORG --///M ARMY M5 CP Alpine White -- M2 LBB -- M4 DCT CP Alpine White |
06-05-2015, 11:15 AM | #4 |
Rep 501
06-05-2015, 06:13 PM | #6 |
Rep 501
06-05-2015, 07:07 PM | #7 | |
Rep 1,275
http://www.ecstuning.com/ES2804295/?...BDwxoC2Cfw_wcB
2019 ///M5 Competition
On Order: 2023 ///M3 Competition xDrive |
06-05-2015, 10:03 PM | #8 | |
Rep 501
06-05-2015, 10:14 PM | #9 |
Rep 1,275
Bummer! I hope they offer something in the future, as it's pretty reasonably priced, IMO.
06-06-2015, 06:53 AM | #10 |
BMW Motorsport
237
Rep 2,225
i think give it time.
Neil.
06-06-2015, 04:18 PM | #11 |
Rep 501
I shall... F80 will be built 7/15. I just wanted something better than stock without shelling out $8k for the ccb. From what I've read the stock blue brakes are the only weak point on this car and not worthy of a $70k car. Even the Cadillac ATS-V while 2k cheaper comes standard with 6 piston front and 4 piston rear brembos...
06-08-2015, 01:15 AM | #12 |
Rep 37
Interested in this too. Ordering very soon and doubtful about the CCB's. Like the calipers, don't need the ceramics.
Cars: M4 F83 - X5 Hybrid F15 - Z3 M QP - E30 325 Cabrio - Z1 - Jaguar XJ40 XJR - Ferrari 348 tb - Abarth 595 cabrio
07-30-2015, 10:39 PM | #13 |
Rep 1,060
I too am contemplating this, as I believe the standard calipers on the F8x are too small. I found the F8x CCB calipers (minus pads) with mounting hardware and lines at a great price. I just need to know if it's possible to work without any issues.
07-31-2015, 03:16 PM | #14 |
Rep 501
They should mount fine... the trick i believe is the rotors and accompanying hardware... because it should be plug and play if you have everything needed. Only a matter of time for some shop to do it i guess because the calipers can be gotten for a fair price from getbmwparts or the like...
07-31-2015, 04:41 PM | #15 |
Rep 2,991
I checked REALOEM and confirmed that the uprights are the same between the regular brakes and the CCB.
http://www.realoem.com/bmw/enUS/show...diagId=31_1122 This is good, since it means that the CCB caliper will bolt right up. However, since the CCB rotor is larger, the pads wouldn't contact the rotor in the right place. Porsche guys who track a lot often replace their CCB rotors with steel rotors, either by bolting on a full steel setup or just running larger steel rotors with CCBs. I think the latter is the right way to fix it. I'm hoping that Performance Friction comes out with a rotor hat that fits both the Steel and CCB optioned M3s and uses a standard 380mm rotor for the steels and a 405mm rotor for CCB. This would allow CCB owners who want to track without fear of destroying $5k rotors switch to steels, but it'd also allow the larger 6 piston calipers to be used as an upgrade. Likely this is possible but I haven't measured the rotors. Probably cost prohibitive compared to stoptechs or Brembos, though, given the cost of OEM calipers, but who knows. |
08-04-2015, 01:33 PM | #16 |
Rep 1,405
yes you can do this set up
here what you need caliper right 34117850463 $622.29 caliper left 34117850464 $622.29 protection plate 3412284767 $44.74 protection plate 3412284768 $44.74 Brake Rotor 400x36 Right 34112284102 $366.03 Brake Rotor 400x36 Left 34112284101 $366.03 Brake Pads 341112284869 $290.06 Brake Pads Sensor x 2 34352284343 $25.73 x 2 Total = $2,407.64 Last edited by Amgeater2; 08-04-2015 at 01:46 PM.. |
08-04-2015, 01:35 PM | #17 | |
Rep 501
08-04-2015, 01:46 PM | #18 |
Rep 1,405
08-04-2015, 02:01 PM | #19 | |
Rep 20,742
Drives: 2021 911 turbo
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 08-04-2015 at 03:22 PM.. |
08-04-2015, 02:52 PM | #20 |
Rep 1,405
08-10-2015, 03:28 PM | #22 | |
Rep 13,019
Do you know for a fact that F80 calipers fit the F10 M5 rotors?
