05-28-2015, 10:47 PM | #1 |
Rep 725
Can you lemon law a car for interior rattles?
Have a m4 got it in February. The interior rattles quite a bit, seems
More than normal. Can the car be lemon lawed if not fixed? Thanks
2008 335i- FBO
2015 M4-exterior mods, JB4 E 85 2008 Zo6- intake 2015 Honda Accord 2020 Range Rover Sport HST |
05-28-2015, 10:49 PM | #2 |
Explodes on impact
209
Rep 552
Yea... yea I got an M(azda)3.... <.<
*work in progress* |
05-28-2015, 11:45 PM | #6 |
Rep 3,341
mine rattles too, but i know where it is coming from. the door seals.
it can be fixed. did you try to go to the dealers?
Currently:
2018 GT3 2020 X3MC Previously: 1999 M3 2002 M3 2005 S4 2008 C63 2015 M3 2016 X5M 2019 911S |
05-28-2015, 11:49 PM | #7 |
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
He has an M4 - not the same door seal issues as the M3.
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
05-29-2015, 12:00 AM | #9 |
Rep 471
Every M3 ever built had major rattles. Both my e36 and e46 M3's had rattles.
The way I explain is that these cars were always stiff, which translates to noises. I can't see it any other way. |
05-29-2015, 12:07 AM | #10 |
Rep 4,090
No, the rattles can be fixed.. Again probably need to lube your doors.
Also as camber stated, stiffer cars find rattles. Also another thing is the F8x probably doesn't have a ton of sound insulation vs other 80K cars that aren't as performance driven. Do you have CF interior trim? There is a few posts on fixing the rattles with some tape. Can you pin point the rattle? Lose speaker? You can always add in some sound insulation to the doors if you need it. |
05-29-2015, 12:35 AM | #11 |
Rep 2,135
My rear door panels creaked, by far most annoying sound ever.
05-29-2015, 12:56 AM | #12 |
Rep 3,341
by the way, most every car i have ever had rattled...
c63, s4, x5, mdx, etc.
Currently:
05-29-2015, 01:15 AM | #14 |
Large Member
951
Rep 1,749
He should get a Chevy?
2008 E92 M3 (Engine swap completed), 2015 F82 M4
05-29-2015, 01:53 AM | #15 |
Rep 597
BMW made this much stiffer than many race cars. That along with 19" rims, and no rubber bushings.... things are going to get loose. The e92 was not nearly as stiff.
I knew when I went from my 550i to the M4 the ride would be rough. Rough ride - equals - rattles and shakes. go buy a chevy with 4000lb of torsional stiffness and rubber mounts, less likely to have rattles (at least in the first 30k miles) "BMW claims the M3's torsional stiffness is over 40,000 Newton-meters per degree, approaching that of the 2004 BMW M3 GTR race car, which used a steel-tube roll cage to reach 46,000 Nm/deg. The stiffness comes in part from the same strut-tower brace that also helps steering feel and response. Additionally, BMW mounts the rear subframe directly to the body, with no rubber bushings." http://www.roadandtrack.com/new-cars...ons-bmw-m3-m4/ |
05-29-2015, 05:22 AM | #17 |
Rep 3,803
Yea. I wouldn't be so quick to say no.
Depends on the state, and the issue (safety/warranty) as to how many times the dealership/manufacturer has to fix the problem. I say this from experience. I'll leave it at that. So, yes it absolutely can be done. Those that say no, have never been through the process. |
05-29-2015, 05:29 AM | #18 |
Rep 1,418
4400 miles and not one rattle yet... And how the f do you people hear rattles with the sound of the engine so loud inside? Between music and engine sound I don't think I could hear a rattle.
05-29-2015, 06:39 AM | #21 | |
Rep 2,134
https://books.google.com/books?id=_p...asured&f=false
2016 F80 | MG/SO | DCT | Adaptive M Suspension | 19" Black 437M Wheels | CF Roof | CF Trim
