06-01-2015, 01:57 AM | #1 |
Rep 142
JRZ RS pro reservoir connecting problem
Hi guys
I bought a set of used JRZ RS Pro and am in the process of installing it. However, it didn't came with the installation guide. I'm wondering if any fellow member on the forum would share it with me! My biggest problem is I couldn't get the reservoir cables to connect. Isn't it supposed to be plug and play? Or is there a certain condition (clicks) that I need to be at to plug it in? Getting really frustrated with this. Im wondering if any of you could help Thanks George
2008 JZB 6MT
Brembo + Hawk DTC70 / JRZ RS Pro / Varis Diffusers / GT4 Lip / TE37 SL / NT01 275 Square / Akrapovic Evo / Recaro Red PP / Back Seat Removal / APR GT-250 & GT4 lip + Chassis Mount Front Splitter + Canard / Motul 5W-40 & RS683 Brake Fluid Life is too short to drive boring cars |
06-01-2015, 11:37 AM | #2 |
Rep 937
George,
As you know the lines are pressurized. A few things may help. Don't try to keep connecting unless your ready and have rested. Every time you try you are leaking fluid which some may argue is minute but non the less you leaking what should be there. If you are connecting the front lines, lift the front of the car via the center jack lift point so the whole front 2 wheels are off the ground. This should relive some pressure. Then, all jokes aside, man up and force the 2 connections together (not super easy as again the lines are pressurized). Do the same for the rear.
2009 E93 M3 Sold
06-01-2015, 11:48 AM | #3 |
Rep 3,856
I would give JRZ a call:
http://www.jrzsuspension.com/contact/usa.html They're very helpful, excellent customer service |
06-03-2015, 12:44 AM | #4 |
30
Rep 132
Hi George,
We're a new sponsor here on Bimmerpost and are a JRZ dealer. As knolow mentioned, the most likely issue in difficulty of connecting the quick disconnects is that the lines are greatly pressurized. Do you have access to nitrogen or normal compressed shop air? It's highly recommend that you relieve all the pressure in the canisters before releasing/connecting the quick disconnects, so as not to risk losing substantial amount of shock fluid. In addition, this should be done with the suspension unloaded. With the system depressurized, connecting the QDs should be fairly manageable. Prior to loading the suspension, refill with nitrogen to your desired pressure. If nitrogen is not available, at least fill it with some standard compressed air to get you by on your way to a shop who can fill your canisters with nitrogen. Hopefully that helps a little. Let us know if we can clarify anything else. |
06-04-2015, 12:28 AM | #5 | |
Rep 142
Thanks!
2008 JZB 6MT
06-05-2015, 12:25 AM | #6 |
30
Rep 132
Awesome! Glad it all worked out. Let us know if you ever need help with anything.
