06-05-2015, 10:24 AM | #1 |
Rep 265
New member: PLEASE help
This one is complex so get ready... and all I ask is that anyone can give whatever input they have. I know it's long to read and you probably wont feel like it, but picture a desparate new father and husband of a woman who has put up with me for years and watched me rebuild my entire E30 and was patient, but glad I no longer had one of these cars - being yelled at to get this thing working. Just... picture your wife... nagging you about your vehicle. Ugh. Anyway, just please help in any way possible. I see this forum a lot and I know you guys are the next best thing to a BMW shop.
I've been on bimmer forums for years, but I haven't have one in a while. I got a 2008 M3 at auction (I'm a 25 year old finance manager at a Cadillac dealer) recently and it had a bunch of issues. I've managed to solve the headlight which after a few days of diagnosing and resetting the FRM, ended up being a stupid ballast and a few blown bulbs. Hopefully this will be as simple and I'm overcomplicating it, but I have a feeling it isn't. I have two remaining issues before I can get this loan put through and my boss is about to kill me because we have had the car a couple of weeks now. After erasing the codes the following returned: 5E19 - Engine management: interface 2B5C - Throttle valves fault status, bank 2 2AFB - Intake-air temperature sensor (probably from removing the sensor and having vehicle on) 2B25 - Throttle-valve monitoring, bank 1 2B15 - Throttle-valve actuator, governor monitoring, bank 1 278A & 2789 - Catalytic-coverter conversion, (bank 2 & 1) CD93 - Bus Off throttle valve CAN 2B14 - Throttle-valve actuator initialisation CDC0 & CDBF - Throttle-valve actuator CAN message, (bank 2 & 1) 27B0 - Secondary air system flow rate, bank 1 I have erased them a few times and it keeps coming back for that secondary air code, so I'm assuming it is the check valve. I do have an exhaust leak that I have yet to discover the source of, but the check valves (without removing) look fine from what I could see so that confuses me a bit. The air pump works fine. IMPORTANT: The strangest part (and believe me, I've done a lot of research on this for the past week) is that the car works fine after being completely cooled down. The secondary air still exists and wont go away, but in the morning or after several hours, the vehicle starts right up with ZERO throttle or limp mode errors and runs like a champ. I took off the manifold, removed the air pump to inspect, looked over everything etc. After putting it back together and starting up to show my friend who hadn't yet seen it - it ran (because it was cooled down completely for hours). I let it run for about 30-45 seconds and gave it two revs to about 2k or so quickly and shut it off. Turning it back on within seconds will result in a fine start up again, but if you leave it for more than a minute or so and turn it back on - the entire dash lights up and throttle goes into limp mode. Let it cool down and later on or in the morning, it runs fine (with the exception of the secondary air thing which does affect it's performance other than a slightly rough idle. This leads me to believe that the throttle actuators themselves aren't the issue because they run perfectly in the cold and the car has NO issues even after an hour of running. This only happens after shutting off and turning on. ONE MORE FINAL VERY VERY IMPORTANT DETAIL: The engine is VERY clean - WAY too clean for 134k miles. Like... brand new clean... which is very... good in a few ways, but madening and frightening to think about. I'd assume that this could mean a software issue. Basically if you scrolled down because this is too long to read, my question is "why does my car start fine in the morning, drive forever without issues, and goes into limp mode after shutting it off for a minute and turning it back on until the next time it cools down and works again?" Sorry for the extremely long post here, but I'm trying to give as much detail as possible. If I can get some help here on getting this thing to work then feel free to post a donation link. I know you have to take my word for that, but I can assure you that after this whole thing is done - that I will donate and remain active here. |
06-05-2015, 03:05 PM | #4 | ||
Rep 265
Very glad this is getting attention. So appreciative of the help you guys have no idea. I've felt very lost here.
I'm quoting and responding below, but I thought I'd add two things. Just did a battery test and I'm reading 12.22v. I just drove it for about 30 seconds to the Subway next to my building to grab lunch and immediately shut it off when I got there. Went inside for 7 minutes and went out to the vehicle back in limp mode when I turned it on. The other thing in reference to the last thing I'm quoting below from tbrown1985 - one thing to note that when this is in limp mode is the difference in idle. The idle when the vehicle runs well is around 600. Limp mode it runs rough (obviously) and stays right around 900-1k. Is this abnormal or is it just limp mode? I did have a hard start a couple of times, but that was it. It also has a tendency to stall when it is fully heated up and in limp mode. Drives perfectly, but getting out and running it again in limp mode, the vehicle can barely move and wants to stall badly. Is this possibly a battery/ICV issue? Remember, it wants to stall when it is hotter, but ONLY when it limp mode. Guess I kind of need a battery either way Quote:
That would be the magic number. Does this have anything to do with something specific? I wasn't sure if it limits it differently based on the situation it detects, but now I wonder. |
06-05-2015, 03:12 PM | #5 |
Rep 11,891
I too feel it is also emissions equipment related...such as throttle actuator issue. What is weird is, you have a lot more codes than a standard throttle actuator issue, which leads me to believe there's some additional sensor issue as well.
Perhaps it's worth paying a indy shop or dealership to diagnose for you before you decide who will fix it?
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
06-05-2015, 03:18 PM | #6 | |
Rep 265
06-05-2015, 08:40 PM | #7 |
Rep 176
I would check your computer. Sounds like a software issue to me. Take it to the dealership and have them diagnose - will eliminate your guessing/assuming and no headache!
06-05-2015, 08:41 PM | #8 | |
Rep 11,891
06-05-2015, 08:48 PM | #9 |
Rep 265
Alright so I'm coming to a conclusion, but I won't be able to update yet. Any more input will of course be taken into consideration in the mean time. After reviewing M5 (why I didn't search this with M5/6 is beyond me. No sleep this week with the kid hasn't helped me to think better - anyway, I found my EXACT issue (only works in cold, etc...) and literally every single one was fixed by replacing the throttle actuator(s). This crossed my mind, as I read about the issue with resistors going bad. I know resistors don't like excessive heat and power overload. I just figured it may be more with so many different codes, but many have had both go.
A fresh code pull the same, but a couple different codes for each actuator. I'd assume that this could be because if one doesn't work, they both will come up with at least one code. Maybe they're both bad. I'm going to open them and see if the failure is as obvious on the post I read about the resistor looking totally black compared to the others and give one a shot by soldering it. If it works or temporarily does, then I will replace them with new units. This leaves me with secondary air to tackle which even though the valve looked clean, I'll be taking it out to examine it. I may just replace it. The pump works great, but the exhaust leak on bank 2 is incredibly loud with the air pump on. Louder than it should be which suggests that the bank 1 code really is for a valve that is stuck in the closed position. So while I'm not done, I'd like to thank everyone so far. I always had regular 3 series, but this seems to be the best place for M related posts to get attention. You guys are seriously amazing for this. It was (hopefully) so simple and I didn't think to look at M5/6 posts. While I'm here I may as well spout off some details on the car and my to-do list. I have yet to build a mod list, but I have a list to get it in full working order. Vehicle is an 08 M3 with every single option available (including CF roof) minus DCT and 19" wheels which I didn't want. I paid 17400 for it and it has 134k. I'm starting to think it has a rebuilt motor which scares me, but it runs great when it works and the valves, heads, pistons, everything - all look BRAND new and all the fluids are fresh. To-do list: -Unplug and try to get rear brake sensor to rest without buying a new one (front done) -Fix seatbelt extenders to actually spring up -Stop secondary air code -Find and repair exhaust leak -Replace shift knob That's it for now. Thank you so much again for your help. I'll be wrapping this up and keeping updated over the weekend. |
06-05-2015, 08:49 PM | #10 |
Rep 265
That will be the next step if this doesn't work. I used to work at the dealer to so I still know some of the guys. Just been too busy to get over there. I'll definitely have them print my service records which I pray they exist.
06-05-2015, 09:31 PM | #11 |
Rep 1,260
I'm gonna say that you replace both throttle valve actuators and it will fix the problem.
I got all of those codes except the intake sensor and the cat. converter code when both mine went bad. Do you get a high emissions error?
06-06-2015, 09:32 AM | #13 |
Rep 265
Wish I could have. I'm the finance manager so I'm the one who does all of that stuff here. We do the GMPP which is by far one of the best in the industry and I'm sure people on here can agree with that. My issue is that I can't write a warranty on a vehicle over 100k. I am getting a powertrain from Route 66 which will cover me against anything like this, but I have to get it to pass inspection first and put my loan through. Otherwise it isn't active yet. I did think about fixing the secondary air issue and just passing the vehicle for inspection and bringing it in for the throttle problem, but I'd rather learn this one myself. Hopefully this will be a matter of the resistors and I can replace them, but we will see tonight or tomorrow.
06-06-2015, 09:42 AM | #14 |
Rep 265
Yes I did. Although I know it's part of the throttle issue as well, I do have a secondary air flow issue on bank 1 so I think I would be getting the emissions warning either way
06-07-2015, 11:25 AM | #15 |
BimmerPost Supporting Vendor
3388
Rep 7,542
The car probably has two faulty throttle actuators. Replace them, clear faults and see if any return. While you're in there I'd probably replace the ICV too as it's another common failure point.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- |
06-07-2015, 06:52 PM | #16 |
Rep 265
So the redline used to stop where the vehicle would be when it was cold (obviously). When I would restart it, the redline would stop for a second during initialization and it would then go to 4k for limp mode and stay there.
After taking them out and turning the gears to see if it would work, it no longer hesitates and goes straight to 4k. This pretty much concludes what everyone said that it is the actuators. The boards seem fine (which sucks cause I got two transistors locally by some miracle), but the gears seem pretty bad. Here are pictures of everything. https://www.dropbox.com/s/ldz0jfvkwy...%20pm.jpg?dl=0 https://www.dropbox.com/s/fm9zber28q...%20pm.jpg?dl=0 https://www.dropbox.com/s/8jcufmthv4...%20pm.jpg?dl=0 https://www.dropbox.com/s/6gogjorlm1...%20pm.jpg?dl=0 https://www.dropbox.com/s/rwclz0a5rc...%20pm.jpg?dl=0 https://www.dropbox.com/s/q6n4bqy8ex...%20pm.jpg?dl=0 So the actuators... great Looks like someone has been in one of these based on the anti-seize all over one... Last edited by bmwlover0725; 06-07-2015 at 07:34 PM.. |
06-07-2015, 08:13 PM | #17 |
Bad Lieutenant
233
Rep 3,517
Shitty design, shitty location and no easy access for lubrication = fail.
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
06-08-2015, 09:53 AM | #18 |
Rep 67
Actuators should fix it. Bad ones usually dont let the throttle fully close so when you perform a warm start your mixture is immediately off and you get the error right away. The car doesnt even start checking the emmissions stuff until it enters closed loop, so that's most likely why the errors dont show up on the cold start. You'll find much more info on M5board so that was a good call searching over there. Good luck and let us know how it goes.
06-08-2015, 11:15 AM | #19 | |
Rep 265
I found a set with 30k on them for 435 shipped with a 90 day guarantee. I know they may already be somewhat worn, but that will give me a little bit of time to get this inspected and make my warranty active so I can have them replaced with new once they fail again. I'll update later this week when installed |
06-08-2015, 12:55 PM | #20 |
Rep 67
06-08-2015, 01:00 PM | #21 | |
Rep 265
Wow that will be a good one for future use and for my friend's M6. Thanks! |
06-11-2015, 09:45 PM | #22 |
Rep 265
Well I did it. Got them today in beautiful shape for 435 shipped. I think it was the bank 1, but bank 2 didn't look like it was far off from failure. The new ones felt more solid when I manually pushed the motor and they were much cleaner and didn't have any play at all. They actually looked like they were brand new and just replaced before the vehicle they were in was totaled.
The bottom line is that they worked great. I owe everyone here a HUGE thank you. I'll be throwing a donation of 50 bucks once my next commission check hits. This forum is worth every penny of that - plus. I've done a how-to video that I'll be putting together as soon as I get some time. The DIY is great, but I'm sure a video will be an added benefit to that article. Thanks again everyone!! |
