06-15-2015, 03:01 PM | #1 |
Rep 208
Best Ramps?
I see some folks use Rhino ramps, so I assume that a 135i with stock ride height can get up these without any rubbing. Are those the 'go-to' brand, or are there any others out there that won't rub and get the car high enough to do most normal maintenance activity?
06-15-2015, 03:04 PM | #2 |
Rep 6,196
Check out Race Ramps?
http://www.raceramps.com/ Had a set for getting the race car into the trailer. |
06-15-2015, 09:05 PM | #4 |
Rep 505
I have Race Ramps. Quality stuff -- lightweight and they do not slip. They clear my (slightly) lowered car.
You can get them from Reverse Logic since they have 10% off + free shipping. |
06-15-2015, 09:53 PM | #6 |
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
I use these ones, they are enough to let me get the jack to the front jacking point.
http://www.streetfx.com.au/product/g...chable-design/ I can't get onto normal ones. |
06-15-2015, 10:26 PM | #7 | |
The Crowing
111
Rep 2,005
2009 135i : BMS JB4 G5 ISO,CXRacing FMIC Kit,Injen Cold Air Intake,Evolution Raceworks Charge Pipe,Walboro Inline Fuel Pump, E85 BMS Backend Flash w/ 60% E85,BMS Meth injection (trunkmount),BMS dual meth nozzles,Spec stage 2+ clutch w/ steel SWFW,BMS Catless Downpipes,Berk Tech Race Axleback |
06-16-2015, 01:39 AM | #8 |
Rep 888
Drives: 08 135i M Sport 6MT, 15 X3 35i
I have rhinos. Great ramps but they tend to slide a bit so they just need to be placed about a foot back if clearance is an issue.
Makes oil changes and jacking up the front a breeze
2015 Cosmic Blue Metallic Wrapped X3 35i ///M Sport Full 3M Vinyl Wrap | Flat Black Grilles |
06-16-2015, 02:59 AM | #9 |
708
Rep 3,268
Drives: 2010 128i
+1 on Race Ramps. I have the trailer extension ramps, so not ideal for working on the car, but it certainly would help with getting the front end high enough to clear a standard size floor jack.
____________________________ |
