BMW M3 Forum (E90 E92)
      02-13-2008, 08:19 PM   #1
eclipsisNA
Drives: 2013 Estoril 328i M Sport
2014 BMW 428i  [7.76]
My recommendation for a USB flash drive
I started another topic a while back asking about what a good choice for a USB flash would be. After a ton of research, I settled on the Corsair Flash Voyager 8GB. I've had the unit for about three weeks now and can give a brief synopsis of its overall quality.
It's encased in sturdy and firm rubber padding. Tests have shown that you can run it over and it'll remain in pristine quality. This is unlike many earlier USB flash drives that were in normal plastic housings that could break without much harassment.
The unit I bought in particular is the 8GB version, which holds roughly 1,300 songs in 320kbps quality. A main factor in considering a flash drive is it's read speed, and the Flash Voyager is the fastest unit on the market (outside of its more expensive brother the Flash Voyager GT). It's average read speed is 38 mb/s, which is a great deal faster than other drives that average around 8 mb/s. Even if you're sending FLAC quality songs through your amp, there won't be any lag time in requesting the song and it appearing through the speakers.
The MAJOR plus in running a USB flash drive instead of your iPhone/iPod as the provider of your MP3s is that iPhones/iPods are the utility that process the audio signal and they do it in analog only. Flash drives on the other hand don't do any of the processing at all and hand that task over to the unit installed in your car which in turn does it digitally, thus giving a more pristine representation of the original MP3/WAV's quality.
The Voyager comes with a USB extension cable that allows you to clear the height restriction in our tiny armrests. Overall I think this is the ideal piece of hardware to use with the iPod adapter that many of us will be getting. If anyone's interested, Newegg has a good deal on it:
http://www.newegg.com/Product/Produc...82E16820233037
      02-13-2008, 08:33 PM   #2
drvai
drvai's Avatar
Drives: E92 M3 AW
Hi. Thank you for sharing.
Wouln't be better to buy one of the smaller Pen drives so it would be easier to put it con the car (no extension needed). ???
      02-13-2008, 08:35 PM   #3
eclipsisNA
Those smaller units are a fraction of the Voyager's capacity (8GB) and their read speed is also much slower (probably around 9 mb/s. I have over 1,000 320kbps MP3s and those smaller drives can't hold all those songs. It's best to just get something like the Voyager and hook up the tiny USB extension (which is very secure I might add).
EDIT: It should be known for those that are unaware that Corsair is one of the leaders in the low latency, high speed PC memory market alongside OCZ and Patriot. Their reputation in providing stable and fast memory is second-to-none, so that's another plus to consider.
      02-14-2008, 02:28 AM   #4
nechronics
nechronics's Avatar
Syria
24
That's an excellent drive.
Last year I bought a 4gb Patriot drive similar to that one - for the same reasons. It was by far the quickest drive on the market for read and write speeds - works like a charm to this day. It's also in a similar rubber casing which is a HUGE plus, feels so much more durable than other plastic drives I have.
they make a 16gb version of that exact drive too
http://www.newegg.com/Product/Produc...82E16820233042
      02-14-2008, 02:47 AM   #5
Big Windy
Big Windy's Avatar
Drives: None
looks ugly but seems to do the job quite well. thanks! i'll be getting on of those!!!
      02-14-2008, 07:28 AM   #6
drvai
drvai's Avatar
Drives: E92 M3 AW
Ohhh. I see. Thank you so much. Do you know if they make a "more discrete version"?
      02-14-2008, 12:14 PM   #7
eclipsisNA
I wish they did, but as of right now they don't. The technology is still pretty new, so hopefully we'll see something a bit tinier in a few years. And you're welcome.
      02-14-2008, 02:43 PM   #8
GarryF
United Kingdom
34
Drives: SSII E90 M3
in a 320D today I tested a CD, Flash drive & ipod. My self and someone else couldn't tell the difference in quality between the 3 different sources, this was on the base euro sound system though so you might hear differences on the higher end systems.
I'd take it with a pinch of salt though until someone does some proper double blind tests, the line out using the dock connector of an ipod is pretty good, most people compaining about poor ipod sound quality are probably playing dodgy 128kbs mp3 downloads
      02-14-2008, 04:30 PM   #9
eclipsisNA
You can tell the difference on the Individual Audio system, as I've compared that to my E46 M3's HK.
m3post
