06-20-2015, 04:56 PM | #1 |
Rep 206
Steel brake wear question
Hi,
I have the steel brakes and have 19,000 km on the clock, including around 12 laps on the Nordschleife. My pad wear indicator in the idrive says I have 170,000km left on the front pads and 140,000km left on the rear pads. Is this normal? Just seems a bit too durable so to speak. And no, I don't drive like a grandma.. Cheers! |
06-21-2015, 12:18 AM | #2 |
Rep 3,834
The stock pads will last 4-6 track weekends with proper brake management. The estimated brake replaced indicator is entered in manually by your service team. Not an accurate estimation based on abnormal driving style (tracking).
Daily: G12 750 MSPORT Weekend Car: E90 M3
06-21-2015, 06:52 AM | #3 | |
Rep 20,742
Drives: 2021 911 turbo
My understanding is that the iDrive brake replacement interval indicator is based on an algorithm that uses driving conditions to estimate brake wear. It is just reset by the "service team" to a default value when new pads are installed. I also seriously doubt that stock pads will last 8 to 12 track days. My stock pads were worn down to about 20% left after only 3 track days.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
06-21-2015, 08:50 AM | #4 | ||
Rep 3,834
I'm not 100% sure on the F8x stock pads. I based it off of the E92 M3 guys who have tracked their cars with stock pads. I have 80% brake left, 11k miles and 1 track weekend. I take it easy on the brakes the last lap to let the brakes cool off. Going to RPM next weekend with the stock pads and ATE TYP200 fluid. We get one free brake replacement so I haven't switched to track pads.
06-21-2015, 09:11 AM | #5 | |
Rep 20,742
I'll make sure to check it out on my M4 .
06-21-2015, 10:42 AM | #6 |
Rep 3,834
That's what I've been told by 2 SAs now (not specific to the F8x, but all the other iDrive cars I've had). They could be b'sing to make me feel that they're doing more than just an oil change. Also, never let the pads wear down until the sensor goes off. The sensor has a wire, once it hits the wear limit the wire will short to indicate the urgent need to replace the brakes. You then need to replace the pads AND the sensor. The sensor can be re-used as long as you don't let it wear past the trip point.
06-21-2015, 11:02 AM | #7 | |
Rep 20,742
My understanding is that the brake pad replacement prediction in the iDrive and the pad wear sensors are not related. Both would trigger a similar alarm, but the signal comes from two distinct and indepenedent source.
06-21-2015, 12:46 PM | #8 | ||
Rep 3,834
