06-20-2015, 06:15 PM | #1 |
Rep 225
Pre-Cat O2 sensor change pics
Ok this wasn't hard but definitely not fun or easy. Total time was about 1.5 hours. I put my car up on some cheap ramps from harbor freight which gave me about 4" of clearance from my chest.
My advice: Don't waste your time trying to work around removing the transmission cover (6 screws) the skid plate (10 screws) or the passenger side sensor shield (2 screws). The driver side is a cake walk and only required the transmission cover off to access the sensors electrical mount. Passenger side has a shield that will require you to remove everything else to access the mount the electrical plugin sits in. I'm not sure how bad these look but the carbon build up looks somewhat bad. I only turned over the engine to verify I wasn't throwing any codes. I will drive it later to see if I can feel a difference.
They've done studies, you know. Sixty percent of the time, it works every time. ~ Brian Fantana
06-20-2015, 06:18 PM | #2 |
Rep 225
Here are the pics
06-20-2015, 06:23 PM | #3 |
Rep 225
06-23-2015, 06:10 PM | #6 |
Rep 225
Haha! Love that.
She is running fantastic. I'm noticing a huge difference in low RPM power. She just seems much more eager to run. I'm not sure if it was the plugs or the O2 sensors because I didn't drive it until they were both done, but wow. It may be in my head but my butt dyno lies to no man. Especially not me You can see from the link I posted it seems like my engine seems to be running on the rich side as well. Perhaps this fixed or helped that? IDK but well worth the time it required.
11-11-2015, 10:41 AM | #7 | |
Rep 460
2020 BMW m5 f90 Project gamma intake downpipes charge coolers . Awe Exhaust Pure_performance_TX stage 3 build motor e40 ABP tune snow performance meth kit
2018 x6m Built motor stage 3 tune PG downpipes |
11-11-2015, 05:57 PM | #8 |
Rep 473
Adding to the previous question, do you have the size wrench and torque values for the sensors?
2011 e92 JzB 6MT
Akrapovic Evolution, ESS Tune, KW V3 |
11-18-2015, 01:54 PM | #9 | |
Rep 225
11-18-2015, 08:02 PM | #10 |
Rep 460
7/8th will do
09-27-2016, 01:09 AM | #11 | |
Rep 413
To make removal of the old sensors a little easier: A. Try to do this job while the exhaust is still warm (but not "burn yourself" hot) B. Spray some Liquid Wrench on there to soak in the threads for a good 20+ minutes before removal C. Help break the corrosion by slightly tightening the sensor onto the exhaust (maybe a 5 degree turn) before trying to loosen the sensor off the exhaust. Here is a picture of my unsuccessful attempt to use an O2 sensor socket. Last edited by Theodore; 12-12-2016 at 05:58 PM.. |
11-17-2016, 11:45 PM | #12 | |
Rep 2,526
