06-30-2015, 01:19 PM | #1 |
BimmerPost Supporting Vendor
9602
Rep 10,891
Official spring data from Swift is here!
After a considerable wait, we have confirmed the official data on Swift's M3/M4 lowering springs for the F8x cars. Swift Japan has been a leader in spring technology since the company's inception in 1997. Swift has engineering backing from one of the largest spring manufacturers in Japan, their parent company Tokyo Hatsujo corporation. Swift's spring technology allows for an excellent control of spring rate, spring travel, and response, while maintaining the lowest possible spring weight. This reduction of spring weight translates directly into lower overall unsprung weight and better vehicle handling and ride quality. Swift's proprietary HS5.TW alloy is specifically designed to balance these characteristics. Swift's M4 springs come in a 279 lbs/inch front rate, and a 726 lbs/inch rear rate, and will lower the car by 1.1 inch in front and .9 inches in the rear for an attractive but reasonable drop. The M3 springs are a bit more conservative, with a 268 lbs/inch front rate, a 715 lbs/inch rear rate, and a 1 inch drop in front and .4 inch drop in the rear. Spring data: M4 Rate Front 279 lbs/in 5.0 kg/mm Rear 726 lbs/in 13.0 kg/mm Drop Front -1.1 in -28mm Rear -0.9 -23mm M3 Rate Front 268 lbs/in 4.8 kg/mm Rear 715 lbs/in 12.8 kg/mm Drop Front -1.0 in -25mm Rear -0.4 -10mm
06-30-2015, 01:55 PM | #3 |
never could compete with Lloyd Braun
5276
Rep 5,384
This is only for the M4, correct? I thought the M3's drop spring rates were to be slightly less aggressive.
2022 G80 M3 6MT | Skyscraper Gray | Kyalami Orange
2018 F87 M2 6MT | Alpine White (sold) 2016 981 Cayman 6MT | Jet Black (sold) 2015 F80 M3 DCT | Tanzanite Blue | Gold Brown (sold) 2013 E92 M3 6MT | Mineral White | Fox Red/Black (sold) |
06-30-2015, 02:01 PM | #4 | |
9602
Rep 10,891
There's an inbound shipment from Japan now- I'm waiting for confirmation of ETA. I hope to have a good ETA in hand this week.
At this point, I'm excited to have confirmed spring rates and drops! These springs have been in the pipeline for so long that I'm happy to have accurate data on those base attributes in hand. Quote:
06-30-2015, 02:34 PM | #5 |
Gone Fishin’
7318
Rep 12,125
Crazy that the M3 has been out so much longer than the RCF but yet both springs are coming out at the same time.
http://www.clublexus.com/forums/rc-f...-released.html |
06-30-2015, 03:37 PM | #6 | |
Rep 1,497
06-30-2015, 04:29 PM | #9 |
Sameet
740
Rep 2,541
Drives: AY/B M4 '15
Sweet.. So we can expect orders within the next two weeks? So glad I waited now..
06-30-2015, 04:31 PM | #10 |
Supreme Leader
2285
Rep 6,548
Drives: G80, 996GT2, 996TT, 991RS 356b
Nice
About time Swift!!
SupremePOWER
1562 Kimberly Ave Fullerton CA 92831 Contact: sales@supremepower.com :: Shop# (714)632-1951 Sales & service of BBS Street & Motorsport products. BBS Highest Volume Dealer 2015 thru 2022 All the top brands at the prices and service you can count on. Professional installation. |
07-01-2015, 10:45 AM | #12 | |
5276
Rep 5,384
For comparison: 185 lb/in Stock M3/4 Front Springs 575 lb/in Stock M4/4 Rear Springs
07-01-2015, 12:53 PM | #14 | |
Rep 3,039
Also Ilia PM me with a price and when these are available and if we can pre order them. Thanks! |
07-01-2015, 01:07 PM | #15 |
5276
Rep 5,384
I'm torn between these and the Eibach US spec. The Eibachs seem more NJ road friendly with the drop but I'm not sure lol
07-01-2015, 02:03 PM | #16 | ||||||
9602
Rep 10,891
I'm happy to help!
The Swift drop is relatively mild as well, I think. Most of our clients that are using a full coilover are going substantially lower than 1" in front, but this is also a matter of taste, of course.
07-01-2015, 04:12 PM | #18 |
Rep 3,039
07-01-2015, 05:09 PM | #19 |
5276
Rep 5,384
07-03-2015, 12:22 AM | #20 |
Rep 886
Spring Rate Increases
M3: +45% F +24% R M4: +51% F +26% R
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs |
