07-03-2015, 10:36 AM | #1 |
Rep 2,352
Drives: 16' BMW i8
Garage List 2001 BMW M3 E46 CON ... [9.50]
2016 BMW i8 [10.00] 2003 JEEP GRAND CHE ... [0.00] 2000 540i SPORT E39 [10.00] 2007 TOYOTA TACOMA ... [0.00] |
Pulling to the right (passenger side) and steering wheel is off-center
Any of you guys experiencing this or pulling to either side, especially when applying your brakes hard? I have just over 2K miles with no track time.
I literally just took out my friend's brand new M4 with 10 miles on it on the flattest road that I know as a comparison and his travels straight. Mine veers to the right. Also, I just got an alignment done last week and it was ever so slightly off where it was pulling right, which was corrected back to factory spec but the car still pulls. Plus my steering wheel is a tad bit off-center. It's tilted to the right. If I grab my steering wheel hold it completely level, the car will travel to the left. I am very aware of road crowning and it's not that. Any ideas? Last edited by Ghetto2315; 07-29-2015 at 10:55 AM.. |
07-03-2015, 02:25 PM | #3 |
Rep 2,352
Drives: 16' BMW i8
07-03-2015, 03:09 PM | #4 |
Rep 2,053
You know now that you mention it, I think I felt a pull to the right under braking also, but it was not all of the time. It happened probably a handful of times on my ED, but not everytime. I thought it could be related to/associated with possible tramlining, but didn't attribute it to a brake problem, at least until I get more mileage under on the odometer.
I also think that someone in the past on these forums had a similar issue resolved by checking/correcting tire pressures, not relying on the on-board TPMS readings. OP - do you have CCBs or standard M brakes?
Moved to the darkside: '23 718 GT4; 11-10-2022.
Le Mans Blue F80 - Munich 5-22-2015 / US 7-7-2015 / SOLD 9-17-2022 ED RecapArctic Grey G05 - Spartanburg 8-29-2019 X5 PCD Recap |
07-03-2015, 03:22 PM | #5 | |
Large Member
951
Rep 1,749
Mine brakes straight as an arrow so I hope you can find a solution to your problem.
2008 E92 M3 (Engine swap completed), 2015 F82 M4
07-03-2015, 05:38 PM | #7 |
Rep 84
Has this happen twice. I thought the alignment was off, but after I took off from the light it was fine.
Current:
2014 M Line 335i & 2012 M Sport Z435i |
07-03-2015, 05:43 PM | #8 | |
11829
Rep 15,400
Or him to gain some! I'd prefer eating to living with a cranky witch on a diet.
07-20-2015, 09:42 PM | #9 | |
Rep 20
07-21-2015, 12:33 AM | #10 | ||
Rep 2,352
Drives: 16' BMW i8
07-21-2015, 04:16 AM | #11 | |||
Rep 253
07-21-2015, 07:58 AM | #12 | |
Rep 2,352
Drives: 16' BMW i8
07-28-2015, 06:17 PM | #13 |
Rep 20
my issue is getting bigger
Ghetto2315 -
I hope that your issue has been resolved. I'm currently having more issues with a dealership out here in the Bay. They have now changed my rear control arm, right from swivel bearing and the car still drifts to the right. They have now called me and stated they are stumped on what is causing the issue - BMW tech has to look over my car now. The dealership continues to state that this issue happened from something that is not covered by the warranty - pot hole or curb which neither has occurred. Has anyone else had an issue like this and what advice can you give me regarding how to deal with BMW? |
07-29-2015, 10:52 AM | #14 | |
Rep 2,352
Drives: 16' BMW i8
07-29-2015, 11:11 AM | #15 |
Rep 20
Updated news on my drifting to the right....
Dealership has now called me stating that they have replaced the right front swivel bearing, rear control arm and the car is still drifting to the right. They currently have no idea why it is doing so and have called a BMW tech to the dealership. Starting to be worried about my build from Germany - the only other things that could cause the issue is something with the steering or a bent frame which we be from the factory. I'll keep you guys updated once the BMW tech gets back to me...funny that the dealership can't figure out something yet want to try and charge me for their mistakes. |
07-31-2015, 01:00 AM | #16 |
Rep 9
I have exactly the same problem. My M3 has been pulling to the right since I drove it off the lot about 3 months ago. If I let go of the steering wheel I start drifting immediately. Only takes about three seconds for me to end up in the next lane. When I'm driving normally, I feel like I'm constantly correcting the car back to center.
I went through the same process as you guys. Took it to the dealer twice. The first time, they did an alignment, swapped the tires and said they got it as close to straight as possible, but that these cars were designed to drift to the right a bit. I drove it back and noticed the same problem immediately, still as severe as it was before. It's definitely not a casual drift like they make it out to be. So I took it back, and they drove it again and said they noticed it but there wasn't anything they thought they could do about it, and that other people had complained about the same thing but had given up trying to fix it. So... I said screw that and took it to an independent shop. They did another alignment and got it dialed in much better than the dealership, but it had no effect on the pulling. It's still just as bad, if not worse now as I'm starting to notice it at lower speeds too. Since I was going to get new wheels/tires and suspension anyway, the shop suggested I just try that first and see if the new tires fix it or if they can dial in the camber plates on the new suspension to make it straighten out. I'm pretty frustrated, as I've had many cars and none of them have had a pull even close to this one, so I know it's not just a minor drift. The fact that it came like this off the lot makes it even more frustrating. I'm curious to hear what the BMW tech has to say about this... |
07-31-2015, 07:45 AM | #17 |
Rep 2,352
Drives: 16' BMW i8
I wonder how many customers it takes to complain before BMW USA does something about it?
07-31-2015, 01:04 PM | #18 |
Rep 629
They are aware. They called back for my alignment sheet and one other car. Equal camber fixes the problem. Once I installed my camber plates, the car no longer pulled right.
07-31-2015, 02:15 PM | #19 |
Rep 9
08-01-2015, 10:42 AM | #20 |
Rep 2,352
Drives: 16' BMW i8
08-01-2015, 10:50 PM | #21 |
Rep 325
I had the same problem. It's this swivel Bearing. Ever since day one my cars pulled to the right. My car still pulls to the right. I just livd with it and going to sale car soon.
08-02-2015, 12:42 AM | #22 |
Rep 251
I've had my car for about 3 weeks and its been pulling to the right from the start. I was going to get it aligned anyway at the 1200 mile service since I was planning on getting springs installed so didn't think much of it. The dealer quoted me $1100 for an alignment yesterday when I was scheduling my service. Wish I read the these threads before getting the springs installed so I could have had the dealer look at it under warranty. The pulling to the right is the same now as it was before getting it lowered. Will be taking it to an independent shop to have it aligned and hope it takes care of the issue.
