07-22-2015, 02:49 AM | #1 |
Rep 493
Will a Brembo or Stoptech front caliper fit my M4rotor?
I have the normal BMW M4 brakes in dark blue. I believe the rotors are 380x24,
with very small looking calipers. Does anyone know if Brembo makes an off the shelf large front 6 pistton caliper that will work with my steel 380mm rotor (plug and play)? Thank you Mario
15' YMB M4, TC Kline ℅ camber plates, AWE Exhaust 544whp Stage 1 Map. Past E90 335iA BLK/BLK 19" IForged Daytona, UR Intake, JB3 2.0, RR DP, AA intercooler, HKS BOV, KWV2, 424whp
07-22-2015, 11:38 AM | #2 |
BimmerPost Supporting Vendor
9602
Rep 10,891
Hello Mario,
Unfortunately the BBK calipers you've seen will not fit, as there are many variances between the OE hardware and the performance upgraded hardware: Caliper piston sizing Mounting style (axial mount vs radial mount) Disc thickness You can, however, replace the front brake kit only, and go with a front big brake kit to improve both the look of the brakes, and their thermal capacity.
07-22-2015, 01:26 PM | #4 |
9602
Rep 10,891
Yes, which isn't a realistic proposition unless you're willing to install an in-line bias adjuster and re-engineer the braking system most of the way.
07-31-2015, 03:10 PM | #5 | |
Rep 501
