07-24-2015, 07:56 PM | #1 |
Rep 251
Spacer help
Just installed Macht Schnell 15mm front and rear and its sticking out. Not sure why its not flush. I'm going to take it off and maybe have it looked at when I get springs installed next week. I might just go get 12mm all round. The fronts are the ones that look bad.
07-24-2015, 08:03 PM | #2 |
Rep 5,678
Taking them off and having them looked at is a waste of your time. I think this looks exactly like a 15mm spacer is expected to look. Your spacers are simply too aggressive for your preference... go with 10mm or 12mm.
Some people think 15mm spacers are "perfectly flush" and others (like you) think they look a little "poked" out. On a car without a drop, my opinion is that 15mm spacers look a tad poked out.
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 |
07-24-2015, 09:16 PM | #3 |
Rep 251
Gotcha. I'll look at it again with ACS springs installed next week and if it still looks off to me I'll go with 10 or 12's. Thanks again for your info. I thought maybe I didn't install it right. The pics from others looked good but again those were dropped already.
07-24-2015, 09:25 PM | #4 |
Rep 4,092
Drives: 21 X6MC
hmmmm... I might have to reconsider since I'm planning on doing 18mm fronts and 15mm rear.
07-25-2015, 01:52 AM | #7 |
Rep 251
Just order 10mm Macht Schnell since Amazon didn't have any 12mm and I wanted it by Monday. Lets see how they look and hopefully I'll get ACS springs installed on Tuesday.
07-25-2015, 04:27 AM | #8 |
Rep 1,812
Drives: 2015 6MT YMB M3, 1974 Corvette
I don't know just had my done on Thursday and it looks pretty flush to me (15 front 12 rear). Stock springs. I think the "flushness" is determined from where you are comparing it to......i.e. the top of the wheel (12 o'clock), or another clock position. obviously from 3-9 it is not flush.
AIRPOWER
07-25-2015, 04:34 AM | #9 |
Rep 1,812
This is a good before and after shot
AIRPOWER
07-25-2015, 02:50 PM | #10 | |
Rep 4,092
Drives: 21 X6MC
07-26-2015, 12:00 AM | #12 |
Rep 1,665
Bad move. Once your car is lowered, you will realize 15mm was perfect as the addtl negative camber will make the front rims flush.
07-26-2015, 12:30 AM | #13 |
Rep 251
We'll see. Having the car lowered on Tuesday but ACS springs has a pretty conservative drop. I don't want the wheel poking out at all so if the 15mm looks fine I can return the 10mm to Amazon and\or I may buy 12mm while getting the springs.
07-27-2015, 07:33 AM | #14 |
Rep 283
there's no visible difference between 10 and 12. I installed ACS with 10mm front and rear and it's perfect (admittedly the Cops in Germany are very less of humor if your wheels are poking out a bit too far). You'll love the ACS as they offer great performance and a lowering that let you still drive the car over speed bumps and into parking lots without having to move in super-slomo and the whole crowd laughing at you...
07-27-2015, 10:03 PM | #15 |
Rep 270
07-28-2015, 11:20 AM | #16 | |
Rep 1,665
I agree that an alignment is needed after lowering to prevent excessive tire wear. However, extra camber in and of itself causes minimal additional tire wear. It is excessive toe out that can chew up tires in 1000 miles or less. |
07-28-2015, 11:45 AM | #17 | |
6586
Rep 5,305
That being said, I agree that 15mm spacer up front would look flush with a drop. On stock height, it will look a bit much IMO. |
08-05-2015, 01:07 PM | #18 | |
Rep 1,812
I hope these pics are what you were looking for.
AIRPOWER
08-05-2015, 01:46 PM | #19 |
Rep 544
15/12mm combo will sit pretty flush from what we've seen on lowered setups. You can get a bit more aggressive on stock suspension if there are no plans to lower in the near future.
08-05-2015, 01:57 PM | #20 |
6586
Rep 5,305
The question is why would you get more aggressive on the stock suspension? Because of the lack of camber at stock height, the 15f/12r already looks too aggressive imo; thicker spacers would only lead to the downright silly.
08-05-2015, 03:07 PM | #21 | |
Rep 1,405
08-05-2015, 07:25 PM | #22 | |
Rep 544
Hope this helps! |
