07-30-2015, 11:22 PM | #1 |
Rep 36
E92 cage design
Hello everyone. So after messing with my rear suspension for a month now and spring rates still arnt what I'm looking for I've decided to it will be easier and safer to do a coilover in the rear. Because of the motion ratio issue with the inboard spring I feel like I'm adding unneeded stress to the subframe. I've contacted gmg about installing a cage and they have been very responsive and easy to work with. The price was also very fair, but I'm not sure about how I feel about the design of the cage. Im also not local to them so thats kind of a pain. I was wondering if anyone has some photos of the m3 gt4 cage. That car utilizes rear coilovers so I wanted to see what the factory designed for it. I also would like to mount the rear subframe directly to it for that magical throttle response and durability. Let me know if anyone has any recommendations/photos. I'm in Seattle and was hoping to get a plan and just have my local welder fab it up but for a perfect cage I'm willing to travel.
07-31-2015, 12:37 PM | #2 |
Lord Scrip
1823
Rep 3,018
Drives: 2011 M3 Coupe
I hope you get what you need. I'm very interested to see the factory design also. Please post pics when you get your beast caged!
08-01-2015, 08:57 AM | #3 |
Rep 1,470
You need to reinforce upper perch for rear coil overs. The stock perch is not designed for that load.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
08-03-2015, 04:21 PM | #4 |
Rep 36
Yep, that's why i'm looking for cage designs. i was hoping someone had photos of the gt4 trunk interior. the gt4 is based on the factory body and wanted to see what bmw came up with.
08-04-2015, 11:00 AM | #7 |
Rep 980
I have been looking for a solution to this as well, since my Nitrons R3 can be converted to a rear true coil over, but I wanted a trunk cage only to reinforce the perches. In a side note, VAC Motorsport runs my same setup with a rear coil over without reinforcement, at least that's what they told me over the phone when I bought the suspension. Granted they own a shop, so if anything ever went wrong, they could fix it.
Mods: too many the list wont fit in the sig page. PM me
Tesla Referral code: http://ts.la/juliana77782 |
08-04-2015, 09:01 PM | #8 |
Rep 1,470
I would have expected better looking welds if that is a GT4. I would also want nascar door bars on my side in case of a side hit.
08-06-2015, 10:58 AM | #9 |
Rep 36
I would have thought the welds would be cleaner as well. The photos were pulled from auto sports (the German magazine) site. They cite it as being an actual GT4. I tried contacting one of the members on here with one but never got a response. Anyone else know some with one to confirm. About the nasa style cage. I'm running the oem doors which have impact beams so it's not a huge deal. A lot of guys running the nasa door bars are rocking carbon/fiberglass doors.
