Pandora Car Alarm System
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      08-30-2015, 08:06 PM   #1
kylecronin
kylecronin's Avatar
Drives: 2015 M4
What is this sound? Is it normal?
I've had my F82 (DCT) for a little over 5 months and put about 14,000 miles on it. I've noticed a sound for a little while, sort of a vibration at 1500RPM or so at 50+% throttle. It's not super loud and it doesn't appear to affect the performance of the car, but I'm wondering if anyone can tell me what it is, and if it's something I should try and have fixed. I don't know if the car has always made this sound, or if it's something new.
I uploaded a clip here:
https://soundcloud.com/kyle-cronin/m4-sound
This audio was recorded with a microphone dangling outside the bottom of the driver's door. In this clip, I'm in 3rd gear at about 1000RPM. I then give about 50% throttle, and as the tach passes 1500RPM you can hear the metallic vibrating sound. As the RPMs continue to climb the sound disappears.
I also recorded the engine and the exhaust by putting a microphone near the wipers and dangling a microphone out the tailgate, both of which did not register the sound. It must be coming from underneath the center of the car.
      08-30-2015, 08:26 PM   #2
BavarianDevil
BavarianDevil's Avatar
Drives: 2015 BMW M4 Silverstone/Beige
track not found
      08-30-2015, 08:28 PM   #3
kylecronin
kylecronin's Avatar
Drives: 2015 M4
Originally Posted by BavarianDevil View Post
track not found
Sorry about that! I had the wrong permissions on the upload. It should work now.
      08-31-2015, 02:06 PM   #4
mad chemist
mad chemist's Avatar
United Kingdom
59
Drives: F82 M4
It's the exhaust valves resonating.
      08-31-2015, 04:07 PM   #5
kylecronin
kylecronin's Avatar
Drives: 2015 M4
OK, that's good to know, thanks. Is it normal? Is it something I can have fixed?
      09-02-2015, 02:31 PM   #6
mad chemist
United Kingdom
59
Drives: F82 M4
100% normal for most early cars. I think LCI ones have modified exhaust valve assemblies.
Dealer will change out the exhaust it if it really bugs you as it's a known fault.
You could remove the internal spring in each valve housing and stretch it out a bit and then re-fit. Worked for me but it is a PITA to re-fit the spring into the valve assembly.
Mad.
Tags
dct, sound, vibration
f80post
