09-14-2015, 08:13 AM | #1 |
Rep 108
Front end noise/clunk
Started getting this annoying clunking noise from front end few weeks back, happens on lower speeds (under 20mph) when you drive over road imperfections and it seems to be getting worse. Sounds like some suspension piece is loose but dealer could not find anything, they checked the front brake pads too and made sure those were not making any sound.
Dealer ordered new drivers side shock but I have a feeling it's not coming from there. Anyone else experienced something similar? Car is stock suspension wise. Just saw AMPowerj's thread "I ran across a suggestion somewhere to make sure you torque the sway bar tie rod to the strut with load on the suspension. I realized I hadn't done this with the installs so I pulled the front of the car up on race ramps today and tightened the nuts connecting the rod to the strut, obviously with the wheels still on and the suspension under load. " - I'll ask dealer guys try this before they start swapping suspension pieces.
2019 BMW X4 m40d
09-16-2015, 12:48 AM | #2 |
Supreme Allied Commander
3888
Rep 54,553
Drives: F80 M3
Dealership has the capability of mounting chassis ears to each component to try to pin point the sound, haven't they done that?
Anti roll bar links would be my first guess. Struts, mounts and springs can all make noise. Even control arm bushings and joints. . |
09-18-2015, 08:37 PM | #4 |
3888
Rep 54,553
Drives: F80 M3
09-20-2015, 09:23 PM | #5 |
Rep 806
Did this fix it for you? I'm having a noise as well when I turn my wheels lock to lock i get a clunk when it's near the locks on either side intermittently. thanks
96 E31 JB 07 E92 AW F82 BSM |
10-03-2015, 04:53 PM | #6 |
Rep 108
Sorry for late reply, been traveling... yes the sounds is gone. I had no issues when turning wheels thou, just when you drive over any seams on the road / other imperfections.
2019 BMW X4 m40d
05-13-2018, 10:46 AM | #7 |
Rep 392
bumping this thread, i belive i have this issue on my 17' ZCP as i hear the same sound under same conditions as described, going to bring it up at my 30k service here in a few thousand miles
05-14-2018, 11:50 AM | #8 |
Rep 408
Mine is doing the same thing. I've already had it fixed in Feb 2018 and now the noise is back. I thought it might be related to the M Performance HAS I had installed in Feb 2017 but maybe not? Anyone else with the HAS having the same issue?
05-14-2018, 12:50 PM | #10 |
Rep 408
Thanks but this doesn't seem right to me? The noise didn't start right away and gets progressively worse over time like something is getting loose and not seating properly.
05-14-2018, 01:04 PM | #11 |
Rep 1,094
The noise (rattle/clunk)I have sounds eerily similar to an issue I had on my S4 years ago...bad end link. But, I do have the M Performance HAS setup and a few folks have reported the same kind of noise, so I don't what to believe at this point.
C-Mu135.00 |
