09-24-2015, 05:45 PM | #1 |
Ultimate Driving Machine E92ESS625 M3/G05 X5 Msport 40i Individual
463
Rep 2,002
Drives: 2011 E92 M3 DCT/ESS 625 kit
Stock dyno results
What numbers are you guys getting stock. I have been reading 350 and with test pipes and tune I got 363. Not much of an improvement compared to what I have seen on this site.
"The Ultimate Driving Machine"
2011 E92 M3 supercharged ESS 625 2016 F15 X5 Msport 35i |
09-24-2015, 05:53 PM | #2 | |
Rep 4,744
Drives: S65 1M Clone & E92 M3 4.6L
I dyno'd a stock 2013 on a dynojet for my baseline and it put down 325 and my stroker put down 420whp. Another time I dyno'd a few stock e92's on another dynojet and they put down 330whp while the stroker did 412whp. We also did a bunch of FBO NA e92's and they ranged in the 350-365whp. Usually it is a 25-35whp gain by going full exhaust and tune. I would not be discouraged by your numbers. |
09-24-2015, 05:55 PM | #3 |
463
Rep 2,002
I guess ur right I did a tune,test pipes on mpe exhaust,active drop in filter. Unfortunately I did not do a before dyno on the same machine. Did 4 pulls
09-24-2015, 09:17 PM | #6 |
463
Rep 2,002
You guys think I should be getting more power?
09-24-2015, 10:25 PM | #7 |
Rep 10,668
It's on a dyno dynamics so you can compare only to other dd results. Check the dyno database. There are a few and you can search or cull out the list.
09-25-2015, 06:13 AM | #8 | |
463
Rep 2,002
09-25-2015, 06:56 AM | #9 |
Rep 10,668
This is the problem with some dynos that make the results hard to compare to. If most dyno 315/320 and you were 350, then something is not right because there just is not that much difference from car to car.
If you were at 350 and added test pipes and a tune, I would expect you to redyno at well beyond the 363. I would say test pipes and a tune are good for 20+ rwhp. If you could find a dynojet to run on, you could get results that you could compare more easily. |
09-25-2015, 11:00 AM | #10 | |
Rep 1,755
09-25-2015, 11:24 AM | #11 |
Rep 10,668
Depends on where you are starting from, what dyno you are on, how the dyno is set up, the condition of the motor and the octane of the gas. I'd put test pipes and a tune at 20+ rwhp over stock. 30 rwhp at the most. Add full x pipe, pulley, intake and rear exhaust and 50 rwhp over stock is a good goal.
09-25-2015, 12:00 PM | #12 | |
463
Rep 2,002
09-25-2015, 12:01 PM | #13 | |
Rep 4,744
No - the max output matters less than the gains. Your car is fine. Next time try to get a stock car to dyno at the same time. It will give you an idea of how much additional power you have gained from your mods. But do note, even stock cars will vary slightly so it won't be exact.
See the thread below of an E9X dyno day I hosted a while back. There is also a stock f82 in there and a dinan s3-r. Your numbers are inline with what we experienced. http://www.m3post.com/forums/showthread.php?t=1114095 |
09-25-2015, 10:13 PM | #14 | ||
463
Rep 2,002
09-26-2015, 10:33 AM | #15 |
Rep 611
Drives: 2013 M3 coupe' 6mt
Stock 2013 M3 at the wheels- 333hp
Testing done at Passion Performance in Cashiers NC. |
09-26-2015, 09:41 PM | #16 | |
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
