10-04-2015, 10:10 AM | #1 |
Rep 955
DIY : E92 M3 Alternator Replace
A few weeks back I ordered a new alternator.
A few reasons I ordered it, mainly: A) I ordered an "upgraded" 220AMP one since I have a rather powerful aftermarket amplifier. B) I noticed when my vehicle is 100% warmed up my idle wont stay at 550/600. It'll bounce up to 800 rpm after about 10 seconds. I know for sure its not my battery as its nearly new (about 8 months old). I also ran some tool32 tests and the IGR system says its falling back to "IGR-Medium" quite quickly. C) On cold starts I have a rough sounding noise I have traced to the alternator clutch. I am 100% sure its related to the alternator clutch as I have made some changes in the JBE and CAS modules and been able to delay this noise by 0.5 to 1.0 seconds. So anyways, the procedure is quite simple. I wont post detailed instructions how to do every step as most of it is on here already, but: Step 0) Unplug your negative cable from your battery. Essential as you will have a loose + cable once the alternator is out. A) Remove the air filter housing. NOT the pleneum. Just the air filter housing lid and bottom and the hose connecting it to the pleneum. You should now be able to see the alternator quite well. B) Remove the radiator fan. Its attached by one torx screw on the left side. There is also a hose "clipped" to the bottom of the fan. You can unclip this hose by sticking your hand in through the air intake on the very very bottom of the vehicle (under the car). Its on the passanger side. Feel around, its there. Removing the fan will seam a bit impossible to anyone whos a novice at this vehicle DIY stuff. It will go. It needs a bit of force, and you need to do your best to get the fat radiator hose to allow you to get it out. Also make sure to (duh) unclip the electrical connection to the fan on the passanger side. C) So at this point you have a very clear view of the alternator. Next you need to take the belt off the alternator. All that you need to do is use a 14mm to retract the tensioner and slip the belt off. Once its off, put it to the side and out of the way. Thats all there is to do regarding the belt. D) Next you need to remove 2 16mm bolts holding the alternator. Double check they are 16mm as I don't recall if they were 14mm or 16mm. One is right at the top very visible, the next one is hidden on the bottom of the alternator right around where the belt tensioner wheel is. Feel around with your finger, its there. Unscrew and pull out both bolts. E) Next unclip the 2 pin electrical cable plugged to the back of the alternator. F) Now its time to wiggle the alternator out. Yes, leave the B+ cable attached for the time being. There is just not enough room to get to it with the alternator in place. G) So at this point the alternator should be out of its place, but still sitting at the bottom of the engine bay. Unscrew the B+ cable at the back. Its a 17mm bolt from what I recall. H) The alternator is ready to be pulled out. Quite a bit of room to get it out, you will have no trouble. This is as far as I am right now (taking a break between removal / reinstall) but reinstall looks opposite of removal. A couple of things I will do before reinstalling: A) Give the B+ cable and its bolt a good sanding to ensure a good connection. B) The "slots" that hold the alternator I will probably clean with WD40 and give a tiny tiny greesing just to make it slide in there easier (thats what she said!). Final notes: A) The torque on the B+ lead should be 19NM according to BMW. B) The BMW TIS states that the underbody protection needs to be removed. I found there is absolutley no need to do this. C) Will post if a new alternator fixes some of the issues mentioned at the start of this post. |
10-05-2015, 09:00 AM | #2 | |
Rep 2,665
Drives: Goggomobil
F86 X6///
05-08-2016, 11:42 AM | #3 | |
Rep 413
I believe the TIS underbody protection removal is to allow for reattachment of all the hose clips to their respective hoses after re-installing the fan shroud. There are quite a few connection points that are very difficult to reconnect otherwise. Here is a photo that shows some, but not all of those hose clip connection points: |
msan404.00 |
05-08-2016, 12:16 PM | #4 |
Rep 999
I think my alternator just went out on me... Was looking for a DIY! Thanks
Performance ESS 625 VT2 Supercharger - CAE Shifter - Revinora race+ axle back - Macht Schnell down pipes - SOSI X-pipe Looks M colors grill - CF trunk - Sapphire Blue Forgestars F14 |
04-10-2017, 01:24 PM | #6 |
Rep 6
Thanks so much for this guide.
When I get the bolts out and it comes time to wiggle the alternator out, is it supposed to be ridiculously hard to get out? I've been trying to get it out for the past two days by wiggling it or using a 2x4 to pry it. I've had about ten different people try to get it out but it seems to just be pivoting around where the bottom bolt goes in (I've already taken out both bolts). It's really stuck in there. |
05-18-2017, 06:50 PM | #7 |
Rep 4,430
Bumping this thread. What were some indicators that you all receive to make you decide to replace your altenators? I'm Thinking about replacing mine. I have an 08 with 73k.
ModeCarbon V1 CF lip/PF AG CF SS ext./ARKYM CF Diffuser/OSS AE's/B&G Springs/CF Performance Spoiler/V2 Led Performance SW/Meisterschaft GT exhaust
05-25-2017, 04:50 AM | #8 | |
Rep 30
Mine was feeling strange for a week or two. Couldn't pick what it was but knew my car wasn't the same. It's a daily btw so it makes it a it easier to tell any subtle changes. First started with a very very subtle weird noice on start up followed by slightly lower idles. This was all coupled with me feeling as though the car felt different when driving but couldn't pick what it was. This all lasted a week. Then all in one day; seat warmers stop working in the morning. Came night time to go home, slowly slowly every single light started to go on. Engine light, abs, punctured tire, air bag, dampening shocks etc etc and finally the car lost power and turned off. Replaced the battery and the car turned on beautifully. Drove it to work today (this all happened yesterday) only to return home now with the 'low battery' signal coming up as I entered the drive away. Alternator it is. Taking it in tomorrow |
05-25-2017, 05:19 AM | #9 | ||
Rep 4,430
05-27-2017, 05:09 PM | #10 |
Rep 4,430
I've noticed that I could only find a refurbished Genuine BMW alternator or a brand new Valeo alternator. The valeo is literally half the price of the original BMW unit. Would anybody have any info if Valeo is reputable or am I better off buying the refurb BMW original?
05-30-2017, 08:16 AM | #11 | |
BimmerPost Supporting Vendor
3768
Rep 2,912
Drives: 2011 E93 M3
05-30-2017, 08:19 AM | #12 | ||
Rep 4,430
06-29-2017, 07:16 PM | #13 |
Rep 2,717
Garage List 2016 BMW X5M [0.00]
08 BMW M3 [0.00] 14 BMW X5 50i - sold [0.00] 09 BMW 335i - Sold [0.00] 09 BMW 328i - Sold [0.00] 07 BMW 328i - Sold [0.00] |
did anyone have any codes scanned?
I had my car turn off on me not too long ago... I started getting EDC error then ABS, low washer fluid, transmission and everything lit up and car died... I waited 5 min and started up with no issues... I replaced thermostat and coolant sensor but now I have 278D error with one source says its: Generator communication. Error will not cause a warning light and other: radiator outlet temp sensor. Should I be replacing my alternator now?
Evolve, Eisenmann, Strasse, StopTech, Active Autowerke
07-02-2017, 06:51 PM | #14 | |
Rep 2,717
11-02-2017, 12:19 PM | #15 |
Rep 69
I'm driving a 2013 e93 M3 and have had all sorts of warnings flashing over the last several months. I replaced the battery and the warnings keep coming, now with even more weirdness. I think there's a voltage issue, and am going to replace the alternator.
I've previously replaced spark plugs and an ignition coil on an e46 m3, removed the throttle limiter, that kind of thing. Anybody done an alternator replacement who can point me towards tricky things to look out for? I understand there's a number of clips invovled that could snap - is that pretty much it? So it seems to me it's disconnect neg battery terminal in trunk; remove air filter cover; remove radiator fan; unplug alternator and remove it. Seems from what I've read that the clips under the fan are a pia (I do not plan on removing the splash guard). Is the fan tricky to get out? also the alternator itself sounds like it can be tricky to remove. I'm concerned I'll get to the middle of this and not be able to finish it - this is my one and only car.... I've ordered a new alternator and an aluminum bolt replacement kit for the bolts, I read they should be replaced when performing this change. Thanks. |
11-16-2017, 01:17 AM | #17 |
Rep 649
I want to make a correction for this DIY for anyone in the future. If you follow the steps per the op (which his diy was a great help), on step E where he states to take off the 2 pin electrical connector first, is pretty much impossible if your car is older, as the clip is stuck on their pretty good. I would wiggle the alternator out FIRST (it took a great deal effort as it finally came out, using a long flat head screw driver) then take off the electrical connector and the B+ cable.
Also, the two alternators bolts are 16mm and the B+ nut is a 17mm |
Rajmun340413.00 |
11-18-2017, 08:50 AM | #18 | |
Rep 1,178
C) Will post if a new alternator fixes some of the issues mentioned at the start of this post. Is there a downloadable TIS available ? I can access it online allright but it is very slow and they made it very unfriendly to browse through. |
11-18-2017, 10:13 PM | #19 |
Rep 649
If anyone in the future needs to replace their alternator, i would get it tested first at autozone on the car and see what has failed first. The voltage regulator failed on mine, everything else passed on the alternator. When i took apart the alternator, and took of the plastic housing in the back (it pops out, using a flathead screwdriver). Than there is 3 8mm bolts holding the voltage regulator. Once i took that apart, i inspected the brushes and they were really short and worn out. I had the option of replacing the brushes or putting on a diff work ing volt regulator with good brushes (i took this step). I installed everything back, ran some tests with multimetere and everything looked good. I also went to autozone they tested the alternator once again and it passed everything including the volt regulator..
12-27-2017, 08:54 AM | #20 |
Rep 60
For the original DIY: I just replaced this and I am not sure how the OP did it, but there was no way that I could it....here is a quick update on the steps I would add.
Add-in: I would release the belt tesioner (the middlle one) by loosening bolt directly above it. This will release the tension on the belt. D) Next you need to remove 2 16mm bolts holding the alternator. Double check they are 16mm as I don't recall if they were 14mm or 16mm. One is right at the top very visible, the next one is hidden on the bottom of the alternator right around where the belt tensioner wheel is. Feel around with your finger, its there. Unscrew and pull out both bolts. Add-in: Wiggle out the alternator prior to un-clipping the connector and removing the nut. E) Next unclip the 2 pin electrical cable plugged to the back of the alternator. F) Now its time to wiggle the alternator out. Yes, leave the B+ cable attached for the time being. There is just not enough room to get to it with the alternator in place. G) So at this point the alternator should be out of its place, but still sitting at the bottom of the engine bay. Unscrew the B+ cable at the back. Its a 17mm bolt from what I recall. H) The alternator is ready to be pulled out. Quite a bit of room to get it out, you will have no trouble. This is as far as I am right now (taking a break between removal / reinstall) but reinstall looks opposite of removal. A couple of things I will do before reinstalling: A) Give the B+ cable and its bolt a good sanding to ensure a good connection. B) The "slots" that hold the alternator I will probably clean with WD40 and give a tiny tiny greesing just to make it slide in there easier (thats what she said!). Add-in: Reinstall the alternator first, starting with the lower bolt, making sure the lower bolt passes thru the hole on the block. then screw in the upper bolt. Add-in: Place the belt in the correct postion, put the screw back into the tensioner, once this is complete, remove the cap from the tensioner pulley with a screw driver, you should see a 14mm bolt. For this step I recommended getting someone to help you with this. I used a short extension attached to a 14mm socket, placed it on the 14mm bolt and rotated it clockwise, this will release the tension on the belt...this is where your helper comes in, while i was holding the pulley in position, your helper wiggled the belt into place (this was tedious), once in place release the tensioner and your done. now you just reinstall the fan, clip the hoses from the bottom and reassemble the air intake.... Final notes: A) The torque on the B+ lead should be 19NM according to BMW. B) The BMW TIS states that the underbody protection needs to be removed. I found there is absolutley no need to do this. C) Will post if a new alternator fixes some of the issues mentioned at the start of this post. |
dazzabb20.50 |
01-18-2018, 07:19 PM | #22 |
Rep 1,144
I've been having some battery issues for a few weeks now. Every now and again I get in the car and it gives me the battery discharge warning. It seems to very with the cold weather which has been an issue since I am in Philly. One day its 60 then next thing you know its 10. Anyway today I was driving on my way home from work and started to get all sorts of messages on my dash, immediately thought it was the battery. Well then everything just dies out, and I sit for 25 mins waiting for a jump but out of the blue it started up without needing it..... Worried to drive it as I don't want to be stranded. I went out and checked the battery and the alternator and both seem to be at the right numbers(12.3V and 14.5V respectfully), also the car started up without a hitch. I found this video that was really helpful, no need to have a voltmeter. Apparently the car has that function built in. Anyway I am not sure what to check next. I have read about the plug-in contact of the battery positive cable on the front power distributor being loose in the E92 M3, but not sure if that the culprit or not. Any recommendations?
Voltage display on dashboard video: Last edited by JP10; 01-18-2018 at 07:26 PM.. |
