10-14-2015, 10:18 PM | #1 |
Rep 394
Drives: 2015 MW M4
What oil type/brand do you use between dealer services?
I know there has been discussion oil brands and types. Not asking for that. But more if mixing oils if you are changing between dealership service.
But for those DIY changing "mid dealer service". 1. Are you using the same oil as dealership? 2. Are you using Mobile 1 or something else for your DIY change. Then with dealership using the "BMW" oil for the included service? 3. Are you using Mobile 1 or some other brand and paying the dealer the difference to use your chosen oil at time of scheduled maintenance? |
10-15-2015, 01:12 PM | #2 |
Rep 2,105
Drives: M4 MW/SO 6MT, E46 M3 AW/IR 6MT
Ordered oil, filter & washer directly via dealership and replaced my oil at 6500... It is actually half the cost of changing my E46 M3 oil so i love it
MILA | E46 BMW M3 | AW/IR | 6MT | KW V3 | CSL | Vorsteiner |
EMILY | F82 BMW M4 | MW/SO | 6MT | M Carbon Ceramic Brakes | M Performance Exhaust | |
10-15-2015, 02:09 PM | #3 | |
Rep 315
SOLD: 2015 F82 Yas Marina Blue / M Performance Exhaust / Black Kidney Grill
SOLD: 2011 E92 LeMans Blue / Volk RE-30 / CF: Spoiler, Splitters, Nostrils, Kidneys, Gills |
10-15-2015, 03:26 PM | #4 |
6586
Rep 5,305
The weight differs according to which brand you use. The Penzoil oil that BMW now uses is 5w30.
10-15-2015, 04:04 PM | #5 |
Rep 2,105
I'm in Los Angeles and they recommend 5w30
10-16-2015, 11:05 AM | #6 |
Rep 315
I just checked the owners manual on the iDrive and it calls for 0w40 or 0w30 as an alternative.
04-23-2016, 03:47 PM | #7 |
Rear Admiral
1486
Rep 1,706
Drives: Bavarian Milk Wagon
Just did 6k mile, mid-dealer service, oil change today. Ow40 Mobil 1.
04-23-2016, 11:09 PM | #9 |
Rep 583
I just bought this for my upcoming 5,000 mile service:
https://www.ecstuning.com/BMW-F80-M3...ice/ES2831193/ |
04-23-2016, 11:57 PM | #10 |
Rep 4,088
Regardless of whether you like the factory oil formulation, you really shouldn't be switching back and forth between oil brands or formulations often. This is amplified by the fact that this platform has a reasonably sized oil cooler that will retain some dirty oil if not purged during each oil change.
That's why I don't switch formulations unless I'm taking over all oil changes moving fwd. And then I'd use redline :-) |
04-24-2016, 02:27 AM | #11 | |
Rep 394
Drives: 2015 MW M4
04-24-2016, 06:19 PM | #12 | |
Rep 4,088
This concern is exacerbated by the oil in the cooler because you are left with more of the "prior" additive package in the system than if you completely drained the oil. If staying with the same brand, the implication is that you are less likely to suffer the result of mixed formulations. Whether this is a big deal or not is a point of contention, but I prefer to stay with one oil brand/type for long stretches of time to be safe. -Ash |
04-25-2016, 10:20 AM | #14 | |
Rep 394
Drives: 2015 MW M4
Ahhh, now I see where you are coming from. |
05-09-2016, 11:57 AM | #16 | |
Rep 2,561
First of all, BMW factory doesn't use Pennzoil (BMW NA supplier). In Europe, it is Shell (used to be Castrol, before BMW got a better deal from Shell a few years ago). So you will be mixing them during dealer service, regardless. Actually, who knows what supplier your particular dealer will be using. If you ask your SA, I bet he will have to "go back and check" before answering. Most engine oils you're going to buy off the shelf will have the same basic group of additives. Each oil company has its own formulation, and some companies prefer one type of additive over another, but they are all basically a mix of: detergent, dispersant, antioxidant, viscosity improver, and base oil. Oils marketed as "long life" or "high mileage" tend to have more additives. More info here: https://mobiloil.com/en/faq/product-faqs Mixing across viscosity grades, and dyno vs. semi-synthetic vs. full-synthetic is also fine. However, for turbo engines, I would not be using anything other than full-synthetic oil, which stands up best to continuous high temperature exposure. Just pick a top-name synthetic oil supplier (many religious opinions on what those are), and don't be shy to change the oil in the middle of BMW's ~10K mile oil interval schedule. a
'19 TM3P (BK/BK)
'15 F80 M3 (SO/SS) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's |
05-09-2016, 12:32 PM | #17 |
Rep 4,088
Appreciate your post, but I respectfully disagree about *frequent* mixing of additive packages. I'm not saying it will cause significant harm to the engine, but you aren't getting the optimal effect the lubricant engineers designed either.
05-09-2016, 05:06 PM | #18 | |
Rep 497
2020 G05 40i | ZMP | Carbon Black | Ivory
05-09-2016, 07:39 PM | #19 |
Rep 2,134
Now that BMW has reduced their oil change interval, I can't justify changing it out at 5,000 miles. So I have elected to simply let the dealer do it normally. But all my other BMW's I have done a mid cycle oil change myself with BMW oil.
