10-16-2015, 08:07 AM | #1 |
Rep 938
X35d exhaust upgrade?
The x5/x6 m models have the best sounding exhaust of any bmw. The growl and pop is truly amazing. While a lot of that is the motor I wonder how much is the muffler. Anyone do an upgrade on an x35d? I think an exhaust on a diesel could sound pretty unique.
10-16-2015, 01:02 PM | #2 |
Rep 5,066
I would be interested to hear what the exhaust sounds like on a diesel!
2015 F15 X5 35i Msport Space Grey M Performance parts MPPK, MPE
10-17-2015, 07:23 AM | #3 | |
Herr Oberst
244
Rep 531
More importantly, the X5M will always sound better because it has 8 cylinders set on a fully cross-plane crankshaft. Because internal combustion car engine run on a 4-stroke cycle, any multiple of 4 in the cylinders produces a more even, pleasing note. They also vibrate much less longitudinally and horizontally, but that's a different story altogether. Sixes just never sound as good as eights. It's a sad fact of life. Long story short, a "loud" exhaust on a diesel would give you a clattery, truck-like sound, akin to what you hear out of the redneck fellas who juice their Cummins diesels up. You'd get more turbo noise, too. Probably not what you had in mind. |
10-17-2015, 12:06 PM | #4 | |
Rep 23
Well said.
2015 BMW X5d
Black Sapphire / Black Dakota | M-Sport Pkg | 42 MPG Premium Pkg | Cold Weather Pkg | Driver Ass/Ass+ | HK Audio |
10-17-2015, 01:27 PM | #6 |
Rep 5,066
OP, I've not heard any "pop" from a M car before.... or are you referring to the 35i with M Performance exhaust??? I also think some inline 6 gas engines sound better than certain V8's but this is all subjective of course..
10-18-2015, 12:13 PM | #7 |
Herr Oberst
244
Rep 531
10-18-2015, 02:10 PM | #8 | |
Rep 710
In addition, the "clatter" is the injector solenoids firing, not the combustion. When I turn my Powerstroke to the "ON" position, it primes the injectors and you hear clatter - this is also a diagnostic advantage too: uneven clatter and you will melt a cylinder. Newer diesels are using different injection technology or strategies which lower the clatter to next to nothing. My 35d motor doesn't clatter but on a cool day, you can hear the combustion until it's warm. My 1995 3930 Ford New Holland tractor clatters though but the technology is slightly different. Putting an after-market exhaust on a 35d will be tricky if you are looking for a throaty sound. It still has to go through the turbo (which muffles), the CAT, the DPF (all which muffle the sound or pressure waves) then to the muffler. And I think a nice V8 diesel, like my 6.0L, with a turbo-back 3in free flow exhaust sounds awesome, especially at wide open throttle - it is a throaty roar even at 3500 rpm. An in-line 6 Cummins in a Dodge, not so much...
Sold: 2014 X5 xDrive35d MSport
10-18-2015, 08:31 PM | #9 |
Herr Oberst
244
Rep 531
Perhaps I wasn't clear with "unpredictable." Instead of a flame front, you get an explosion that can technically start anywhere in the mix cloud, or at multiple points at once. Swirl effects in the combustion chamber based on engineering designs can reduce this, but you're still stuck with an air/fuel cloud that will ignite at whatever point gets hottest first, and not at the spark gap.
Diesels are certainly quite predictable systems overall, especially with modern injector technology. Injector noise aside, my understanding is that much of the clattery sound comes from ignition and cavitation in the cylinder. At any rate, I appreciate your insights and it sounds like we're getting to the same end....not much value in a crazy exhaust on the 35d. Last edited by lowlevelhell; 10-18-2015 at 08:37 PM.. |
10-18-2015, 08:44 PM | #10 |
Rep 1,363
I don't know anything about diesel predictability, but here's a vid of a 335d
It looks like the cars sounds good under load or heavy revving but no so much under light revving |
10-18-2015, 08:47 PM | #11 |
Rep 5,066
Every BMW turbo diesels I've heard on Youtube has that turbo whistling sound on the exhaust.. IMO doesn't sound very pleasing...
10-19-2015, 11:27 AM | #12 | |
Rep 781
10-19-2015, 01:26 PM | #13 |
Rep 1,547
I too have been researching something on this end...and to no avail. Typically an expensive endeavour to be a guinea pig. It would be nice to see an intake / exhaust upgrade for us diesel guys, mated with a tune...would defintely wake this vehicle up a little. I love the power delivery out of the box, but more is always better.
2014 BMW X5 xDrive 35d M Sport Mineral White
2011 BMW 135i M Sport Space Grey 2007 Suzuki GSX-R 750 |
10-20-2015, 08:04 AM | #14 |
Herr Oberst
244
Rep 531
10-20-2015, 05:08 PM | #15 | |
Rep 1,363
04-30-2020, 12:48 PM | #16 |
Rep 552
Drives: 2014 X5 35d, 2008 Lexus IS-F
Fairly new to the forums. Was reading up on your comments last night gentlemen. I personally do not like my EOM exhaust on my 35d M Sport. So I am hoping my project turns out well..
-Vibrant 10632 Street Power Oval Muffler -MMI Motorsport Dual Wall, Staggered, 3.5" Dual Tips -New Piping from DPF to Muffler All 304 stainless steel, but thinking if I want to do some powder or ceramic coating. Talked to the manufacturer and they said the muffler is free flow, safe on diesel applications, and sounds a bit higher than stock but not ridiculous. I'm not looking for ridiculous sound, I just want more free flow exhaust. Waiting on the parts, more to follow I guess.. UPDATE: Alright, so muffler and tips are put in on my 35d. Pretty happy with the setup and look, although I had to got through two separate shops because the shop that did my muffler did not want to do the tips after they began the work. Apparently, because of the heat shields being so close to the back of the tips. I ended up finding another shop that could modify the back of the tips a bit and get it done 🤷🏽. Drove through some rough streets to ensure there is no banging or metal clanking coming from under the vehicle. It is as quiet as OEM. PROS; -The muffler is straight through and safe for Diesel applications -Perfect size, not as long as the OEM muffle and does not touch the heat shield -It setup sounds just like OEM -Tips stick out less than half an inch which was my preferred goal -No more D.Pedal delay / I can feel the difference now when pressing the D.Pedal as the vehicle just takes off on comfort mode. Before it had a slow lag to the pedal response CONS; -It sounds just like OEM (no ricer sound) -Heavier muffler (does not affect anything on the vehicle from what I've seen and experienced) The OEM Muffler is baffled (I did not know this) so it stays pretty quiet. I do not know why they would do this when the CAT and the DPF is doing most of the work 🤷🏽. Happy with the setup and look, and glad it does not have a ridiculous metal clanking sound which was what I was worried about. Last edited by XxBBVTMxX; 05-07-2020 at 04:37 PM.. |
04-30-2020, 04:09 PM | #17 | |
Well versed in the care and feeding of BMWs
261
Rep 733
B&O, parking assistant, executive package, 3rd row seats and the manual rear shades are the ONLY items we didn't order. Having everything else makes our F15d a NICE ride.
05-20-2020, 07:25 PM | #18 |
Rep 552
So finally all done. Used 2Kdf flat black to paint the piping and protect the welds.
-Simple green scrubbed -Sanded -Prepped -Sprayed Now you can't see the heat shield nor any piping from the bumper exhaust hole and I get added protection to the metal 🤙🏽 |
PnP206.50 |
07-27-2020, 02:08 AM | #20 |
Rep 552
11-01-2021, 11:45 PM | #21 | |
Rep 451
I have a completely deleted F15 diesel including a muffler delete, however its a bit loud for my liking. Thinking of quieting it down a bit and going with a similar setup since I no longer have a factory muffler to swap back in. |
11-02-2021, 04:19 AM | #22 | |
Rep 612
