11-18-2015, 09:05 AM | #1 |
Rep 748
Tire temperature.
Dear fellow owners)))
About two weeks ago i got my F15 finally coded and since that time cannot stop myself from falling on love with my car all over again! This morning i activated vehicle status TPM screen in iDrive which after coding shows individual tire pressure and its temperature, after driving for some time i discovered that my front-left ( driver's side ) tire is warmer by 10 degree then rear- right... While front-right and rear-left all have the same temperature. Interested in opinions. BTW as soon as i figure out how to upload photo, i will)
Ones drove a Reliant Robin. )))
11-18-2015, 09:16 AM | #3 |
Rep 5,066
My unscientific explanation is that you are the only passenger in the X5 and there is more weight on the front left side of the X5 causing more friction? Just a guess lol.
2015 F15 X5 35i Msport Space Grey M Performance parts MPPK, MPE
11-18-2015, 10:42 AM | #5 |
Rep 748
Good question, i thought so as well, but it does not seemed to be. Car has 8000 mls on it, which would be enough to show uneven wear.
11-18-2015, 10:43 AM | #6 |
Rep 748
Ha-ha! I am not THAT fat)))) LOL!
11-18-2015, 11:41 AM | #7 |
Rep 89
different temps (sunlight?, garage heater?) when parked? then if you adjusted your pressures in the same parking conditions would cause this. ie if you adjusted left-front at 78 degrees to the correct psi.
11-18-2015, 05:16 PM | #8 |
Rep 1,328
I've noticed the same thing, though the dealer told me that they have ordered a new sensor/module for mine. Not an individual tyre sensor, but the computer for it or something.
11-18-2015, 05:23 PM | #9 |
Rep 748
How did you approach dealer about this issue? I mean i coded this.
11-18-2015, 05:33 PM | #10 |
Rep 1,328
I didn't.
I have the Tyre Pressure option per your screenshot above, and they called me while the car was in transit and said they picked up on a fault with the feature, and that a new sensor or module would need to be fitted. To be honest, I haven't noticed anything wrong, and in fact only learned that tyre pressures and temps change with use. |
11-18-2015, 05:44 PM | #11 | |
Rep 137
11-18-2015, 05:45 PM | #12 | |
Rep 748
11-18-2015, 05:46 PM | #13 |
Rep 748
No)))Not at all, oppositely this morning i was driving as slow as i could, since i was thinking hard about reason to call out)))LOL
11-18-2015, 07:41 PM | #14 |
Rep 710
There is a strong chance the sensor is not that accurate and 5 degrees means nothing in reality. Your tire temps, if you just came off a drive or took it while driving, are actually quite low. For your info, my track tires didn't even work as designed until we hit +180 degrees F.
Generally speaking in typical street driving, the higher the pressure, the lower the temp. The opposite is true.
Sold: 2014 X5 xDrive35d MSport
11-18-2015, 07:54 PM | #15 | |
Rep 748
11-18-2015, 08:20 PM | #16 |
Mmmmm…
1152
Rep 2,426
Drives: F15
I thought temp couldn't coded for the F15?
What option is this? |
11-18-2015, 08:24 PM | #17 |
Rep 748
It can apparently. I did not code it myself, someone did it for me remotely. PM me if interested.
11-18-2015, 08:44 PM | #19 |
Mmmmm…
1152
Rep 2,426
Drives: F15
It guess time to fire up that computer then. I'd like to see some temps... I swear it didn't work for me when I coded the temps, but I'll look again.
Anyways I think it's normal to have different temperatures. Hell the tire pressures vary so much depending on the road I'm on. |
11-20-2015, 07:12 AM | #21 |
Mmmmm…
1152
Rep 2,426
Drives: F15
I redid some of the coding and from what I have seen with temperatures, when driving alone, the driver's front tire definitely heats up faster than the passenger rear tire, when I have a full car, they head up more evenly.
