11-23-2015, 10:42 AM | #1 |
Part Time Firetruck Crash Barrier
792
Rep 1,567
Transmission/Drivetrain issue this weekend, flatbed required
I don't know exactly what the issue is yet as the car got to BMW yesterday. They are checking it out now and I'll update once we know more. . .
So what happened?? I turned left off of my street onto the main road nearby in 1st gear (car is 6mt) and went to get on it a little bit. I had probably applied about 2/3 throttle in sport+ which is plenty of go, and right around the 3k rpm mark I was mostly through the turn and fully applied the throttle, hoping for a little wheel spin. I had a first time passenger and wanted to have a little fun. I hit a little bump in the road and all of a sudden the RPMs flared up and skyrocketed towards redline and I immediately depressed the clutch because I could tell something slipped. I shifted into 2nd and the RPMs were sort of "free floating" and there wasn't any power transfer occuring, plus I heard a pretty awful grinding sound coming from what sounded like the rear of the car. I pulled over to the side of the road, and a "Rear Differential Error" came up on the dash. I wasn't really in a safe place to leave the car, so I immediately tried to move into the hospital parking lot that was just in front of me. I tried 1st, 2nd, and reverse and while I could engage the gear, there would be absolutely 0 power transfer from the engine to the rear wheels. Add to that a horrible clunking sound as well, which made for a very quick trial because whatever the sound was clearly wasn't good and I didn't want to do any further damage. I restarted the car to see if it would tell me any more about the error, and actually there was not an official error being thrown upon restart. I called BMW Road Side and they came to pick up the car in about 60 minutes. Since I was 3 blocks from home I just pushed the car into a slightly better spot and walked back home until the truck arrived. Very, very weird issue. Some additional background: 13,000 miles or so on the car, it's my 3rd manual vehicle, and I haven't been overly abusive to the clutch or anything. . . **Oh 1 more thing: For the last 3 weeks or so I've had a strange issue with 1st gear not fully engaging. . . I could shift up to the gate but it would stick a little. If I shifted into 2nd and then up to first it would work every time, so I was thinking there was probably a synchro issue of some kind but that it wasn't serious. Maybe I was wrong and it was much more serious after all! Update: I blew the right rear axle entirely. It was indeed the bump I went over as I finished the turn. Friggin potholes. Axle on backorder, I was advised it may be Xmas before I get Geri back. Crap.
m340ix Mineral Grey/Tacora Red Last edited by brianeck; 11-23-2015 at 01:47 PM.. Reason: Updates |
11-23-2015, 10:58 AM | #2 |
Rep 2,770
Sounds like the diff let go. I wonder if a rear tire came off the ground. I know gear-type LSD's do not like that very much but I think ours is clutch-type.
Keep us posted on what BMW has to say.
2008 Honda S2000 - Current
2016 F80 M3 - SOLD!! 2011 e92 X-Drive Coupe - SOLD!! |
11-23-2015, 11:38 AM | #3 |
Large Member
951
Rep 1,749
Glad I didn't get the 6mt!
I'm sure they will fix it up and you will be back on the road in a month or three. Hang in there OP!
2008 E92 M3 (Engine swap completed), 2015 F82 M4
11-23-2015, 12:07 PM | #4 | |
Rep 2,561
Should be fully covered by warranty, as there no obvious ways anyone can abuse a diff, short of running it w/o fluid. Most likely transmission choices has had zero influence on this outcome. a
'19 TM3P (BK/BK)
'15 F80 M3 (SO/SS) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's |
11-23-2015, 12:33 PM | #5 |
Large Member
951
Rep 1,749
Whoooosh!
11-23-2015, 12:39 PM | #6 |
Sakhir Smurf
314
Rep 594
Drives: Plaid, F82 M4, E46 M3, Sequoia
+1 on the diff issue. The sounds you're describing sound like diff issues warning signs, and then this bump probably sealed the deal. Could be loose parts in the diff, hell even a loose mounting of the diff or subframe causing it to break apart under stress and load
2015 M4: Sakhir on Sakhir | M-DCT | Adaptive Suspension | Lighting | Executive | Cameras | HK Sound | Full Leather
2004 M3: Laguna Seca Blue | SMGII | Basic track mods: 18" Square setup on R888s / Performance Friction rotors / SS Lines / Ground Control Street/Track Kit / DTC-60 Pads NASA NorCal Instructor |
11-23-2015, 01:02 PM | #8 |
Rep 382
There was another thread somewhere not quite similar but same as in the first gear to redline and then all kinds of things happened. In the end BMW refused any warranty done due to this. They are able to see the log of when you shift and the rpms. Good luck
Current: 2015 BMW F80 M3
Retired: 2012 BMW 335is Other: 2014 Mini Cooper |
11-23-2015, 01:16 PM | #9 |
Gone Fishin’
7318
Rep 12,125
And thats why you don't buy M cars from crappy dealers
11-23-2015, 01:16 PM | #10 |
Sakhir Smurf
314
Rep 594
#SMG #MDCT ftw
11-23-2015, 01:32 PM | #11 | |
792
Rep 1,567
I still slammed my left foot down on the clutch as soon as I noticed the RPMs going skyward as any practiced manual driver would, and I think I managed to do this before they actually did go beyond the redline. . . But either way even if they did the only reason they went so high was a direct result of a mechanical failure of some kind and whatever slipped caused them to jump way higher since there was no longer any resistance from the road/rear wheels/rear diff. I think you guys are probably right that it was a diff issue (and that is the code the car threw as well) since the audible sounds were coming from the rear of the car. In any event, this will most certainly be a warrantied claim and I'm not worried about it in the slightest.
m340ix Mineral Grey/Tacora Red |
11-23-2015, 01:33 PM | #12 | |
Gone Fishin’
7318
Rep 12,125
11-23-2015, 01:46 PM | #13 |
792
Rep 1,567
Update: I blew the right rear axle entirely. This means it was indeed the bump I went over at near WOT haha.
Rear axles are backordered and aren't even in stock in Germany. My adviser just told me its going to be 3-4 weeks minimum for the part to arrive, and that they can't tell if the differential itself is damaged until they get in there. Thankfully my dad has left me with his very capable 5.2L Cherokee as he just moved to Grand Cayman so I don't need a loner car. And about the firetruck incident. . . I had literally JUST gotten my car back from Detailer's Domain after the re-installation of my Modesta and Xpel Ultimate on all the affected panels 6 days prior to this! I haven't had my poor car for the best part of the last 3 months and now I lose the last pre-sub zero driving months hah. Oh well. Unbelievable.
11-23-2015, 01:53 PM | #14 |
Sakhir Smurf
314
Rep 594
Now that I remember, I wonder if when the firetruck hit your car it damaged/dislodged the diff and rear end. Seems strange that this only started happening after your hit.
Did you file an insurance claim / police report after the hit? This might come in handy...
11-23-2015, 02:00 PM | #15 |
792
Rep 1,567
I did I have a police report and an insurance claim filed. It is unlikely to be related, as the firetruck hit the left rear and the right rear is what just broke. The firetruck really only did cosmetic damage, but either way the reports are all there if it does become an issue.
11-23-2015, 02:02 PM | #16 |
792
Rep 1,567
Hah now that we know it was the rear axle it wouldn't have made a difference if I was in the manual or the auto The only difference is I would have been having less fun driving when it happened in the DCT
11-23-2015, 02:25 PM | #17 |
Advocatus Douchebagus. Sex Marxist.
2417
Rep 3,415
Drives: Lucy.
Lucy sends her warmest regards to her boat-mate Geri Haliwell and wishes GH a speedy recovery!
(sorry to hear this happened man....!)
Drivin' Lucy
11-23-2015, 03:08 PM | #18 | |
Rep 3,341
wow, is that covered under warranty or insurance? damn bad luck.... sorry to hear.
Currently:
2018 GT3 2020 X3MC Previously: 1999 M3 2002 M3 2005 S4 2008 C63 2015 M3 2016 X5M 2019 911S |
11-23-2015, 03:11 PM | #20 |
Rep 3,341
is it due to an "accident" from the bump or is it considered a failure of the part? if it is an accident, then go through insurance.
if it is a part failure then go through warranty.
Currently:
11-23-2015, 03:12 PM | #21 |
Rep 11,763
Drives: 2018 M4 Comp Indv
Hopefully you will keep us posted on the error messages and diagnosis... Seems like there's been a few of these weird things going on with the 6MT, granted they seem unrelated and this definitely sounds like a blown diff.
11-23-2015, 04:17 PM | #22 |
792
Rep 1,567
They are calling it a part failure. The bump I hit was legit barely even noticeable, I've hit WAY worse potholes around town, I guess I hit this one just right (slightly sideways haha).
