12-06-2015, 08:48 AM | #1 |
Rep 170
6 speaker Stereo upgrade path?
I'm contemplating doing an upgrade on my OEM Base stereo system and am looking for some links or information to get me started. I am an old car stereo guy and have done hundreds of installs, but have had this car less than two weeks and am just getting to know it. My car has the base stereo with iDrive in it if that makes a difference.
What I am thinking of doing is swapping out all the existing speakers and adding tweeters in the front pillars, keeping everything in stock locations behind stock grills. Then wiring up a small subwoofer in the trunk. I have haven't decided if I will use the factory power, which in my case I believe is coming off the head unit or wire up one of two 4 channel amps I have from my old car (Hertz HCP-4D) for the front and the other for the sub. This configuration I know would give me the best sound, but I am trying to eliminate the process of trying to find space to mount everything so would prefer to go the oem amplification route.. So initially, I'm interested in doing a simple 3way upgrade in the front without having to add a bunch of extra components like amps and processors if that is possible. What I'd like to know is the following:
The simplest way to go would be to buy a matched or packaged speaker set with high efficiency speakers to run off the head unit then wire in a sub with its own amp. I know the base headunit power is low, but with a more efficient speaker I should be able to get ok sound.
12-06-2015, 11:39 AM | #2 |
Rep 3,621
Some info off the top that might help:
Look up old posts here from "VP Electricity" and / or look at the site for a company called MusicarNW. You should find some links, info describing the system you have and suggestions on how to approach an upgrade. DSP (or lack of) will be mentioned. People run LOC's, but many amps (i.e. some newer JL Audio) can do it directly and skip the step. You'll find lots of other members have posted upgrade threads, just have to search for them. Technics (maybe Technic) is a forum member that makes harnesses using OEM parts, they work well and he has a good reputation. Ping him over IM but be sure you do your research first and find out what you need. He has created threads about this and you'll find info in the other search mentioned above. He'll gladly sell you what you need but will be reluctant to answer questions you can answer on your own (I would too after years and years of PM's asking me the same things). Often there is an amp in the left side of the trunk between the tail lights and wheel well. Not sure about your case, you'll have to see what you have, but for many systems an amp is located there. It's not too tough to get to and would be a good spot for an adapting harness. Again only if your car has an amp there - just FYI that many do. MusicarNW has a good Youtube video describing how to get to it, step by step so you don't bust any panel parts, you can search for that as well if (once again) you have an amp there. Hope that helps. |
12-06-2015, 03:27 PM | #3 |
European Editor
10624
Rep 22,992
Best bang for the buck is to get BMW's Alpine amp/speaker upgrade package for $400ish. You will need to have your HU coded afterwards though. You won't get much better sound with just a speaker upgrade. You need some power to move the speaker elements.
12-07-2015, 04:27 PM | #5 |
Rep 157
12-08-2015, 09:28 AM | #6 |
Rep 170
Has anyone on this forum had any luck getting in touch with Technics in the last few months? I am unable to send him PM's here, and have joined one of the other BMW forums for sole purpose of trying to communicate with him but need to get my post count up first. When I try to send from 1addict it says he can not receive pm's.
I'm trying to find out about the harness for base stereo and MB Quart Connectors? Which I think are for certain MB Quart Amps. Although I have my own amps like I said before am curious for space constraints in using one of the smaller powersport amps on market. I could make my own harness but figure if someone else has done the work it would be worth the money to use them. |
12-08-2015, 09:29 AM | #7 |
Rep 170
I'd be interested in Alpine setup if your deal with the other party falls through just for the amp and wiring alone... I could use/sell the speakers. In the meantime...
Has anyone on this forum had any luck getting in touch with Technics in the last few months? I am unable to send him PM's here, and have joined one of the other BMW forums for sole purpose of trying to communicate with him but need to get my post count up first. When I try to send from 1addict it says he can not receive pm's. I'm trying to find out about the harness for base stereo and MB Quart Connectors? Which I think are for certain MB Quart Amps. Although I have my own amps like I said before am curious for space constraints in using one of the smaller powersport amps on market. I could make my own harness but figure if someone else has done the work it would be worth the money to use them. |
12-08-2015, 06:31 PM | #8 | |
1Addict
3239
Rep 7,905
12-08-2015, 07:50 PM | #9 |
Rep 404
12-08-2015, 08:11 PM | #10 |
1Addict
3239
Rep 7,905
So the wiring is there though?
12-09-2015, 02:52 AM | #12 | |
European Editor
10624
Rep 22,992
Checkout this thread... Alpine Hi-Fi System kit http://www.1addicts.com/forums/showthread.php?t=327268
01-29-2016, 06:00 AM | #13 | |
Rep 590
http://www.1addicts.com/forums/showthread.php?t=1067408
2018 MG F80 M3 ZCP | BBS LM?s | Michelin Pilot 4s | BMW HAS Coil Overs | Stek PPF | DINAN CF Intakes | IND Engine cover | Akrapovic Evolution Exhaust |
2018 Champaign Quartz F31 Sports Wagon | BMW 624 wheels | KW Street Coil Overs | DINAN Stage 1 v2.0 | Soul Performance Muffler delete |
02-17-2016, 08:30 PM | #14 |
Rep 170
These arrived this week... I am hoping to get an install started and do a write-up very soon. Look for a complete build, coming soon.. and yes they will fit, with some custom work.
