      12-08-2015, 02:08 PM   #1
luna-c
Drives: 1M
Clonking sound from stock 1m rear suspension
Does anyone have the same issue? I had not noticed it previously but when going over rougher road surfaces (bumps and compressions) there is a very mild clonking sound coming from the rear suspension. Suspension is stock. This noise does not happen all the time either.
Any feedback would be much appreciated.
      12-09-2015, 11:21 AM   #2
Snertz
H O O N
Snertz's Avatar
Drives: ein M!
Check either the sway bar end links, or the lower mount on the damper. I got a clunking noise from the rear of mine and it turned out the lower mount on the damper was shifting around despite the bolt being torqued to spec. Got to a point where flat spots were worn onto the bolt.
U WOT M8?
      12-15-2015, 03:36 PM   #3
luna-c
Drives: 1M
Thanks Snertz. I'll be sure to check that out.
Tags
1m suspension coilovers gmp ohlins, clonking, clonking sound, clunking, rear suspension
1addicts
