12-16-2015, 11:07 PM | #1 |
Rep 535
Angel Eyes Not Functioning At All After Coding in NFRM
Hey Everyone,
A couple of days ago I was coding in my NFRM to enable euro headlights (AHL2_enable to aktiv) and after I coded it in I lost all angel eye function. The angel eyes don't come on with welcome lights, DRL, or headlights (auto or manual). I've tried reversing the coding, rewriting the whole NFRM module to OE specs based on vehicle order, and even trying to reset the FRM via EDIABAS (not sure if I did tat correctly though). Basically, I'm at a loss as to what to try next to regain function of my angel eyes. A little background that may help: -The car is a 2008 E90 M3. -My angel eyes are OE bulbs and always have been. -I have no bulb out warnings at all. -I have coded many other things in the past and haven't had issues so I don't think it's a coding issue but it definitely could be. -I can't find any error information in INPA. -I've checked all fuses in the off chance something blew but all fuses are OK. If anyone has any insight or ideas I would greatly appreciate it. Thanks!
12-16-2015, 11:14 PM | #2 | |
Rep 1,527
12-17-2015, 12:15 AM | #3 | |
Rep 535
Yeah, I tried to code it back to stock using this procedure:
12-17-2015, 03:49 AM | #4 | ||
Rep 1,527
12-17-2015, 05:44 AM | #5 |
Rep 92
I'd try to compare your MAN file with a standard TRC you get off the net for an E90 M3 to see if any AE settings were changed by mistake. I managed to turn off some menu functions when coding the M3 for the first time. For some reason, the TRC file downloaded by ncs had different settings to what was already on the car!
12-17-2015, 08:59 AM | #6 | |
Rep 535
12-17-2015, 01:59 PM | #7 |
Rep 57
Dealing with this myself. Mine's an 08 with LCI tails coded by prev. owner (and ESS tune, not that ESS's alterations matter, but it's certainly a variable in this equation).
- I get right and left parking light bulb-out messages intermittently while stationary and driving. - DRL and H8 AE bulbs all OEM and known-good. DRLs and AEs don't work at all when installed. - Menu options for Welcome Lights and DRLs are present and their selection (or lack thereof) have no effect. - Bixenons, adaptive function, turn signals all work 100% Thinking my FRM needs to be coded to fix the issue.
Current:
e90 M3 6MT - ACM l Ohlins l ESS l Challenge l OEM l Lux l Odo. Gears l RPi Past: e34 m52 swapped 5MT e46 M3 6MT e38 740i e70 X5 3.0si |
12-17-2015, 04:52 PM | #8 |
Rep 92
A guy has posted his TRC on this page: http://www.bimmerforums.com/forum/sh...g-my-E90/page5
Or there is an E92 TRC here. http://pastebin.com/Mzdndj7y Or the b m w coding. com (remove the spaces) forum has a whole section for requests and dumps but is a nightmare to navigate. Whatever you do, don't go changing a load of options unless you are fairly sure and only ever code 1 module at a time!! @Tim P, you need to get the cold and warm bulb checks on your rear lights coded out to stop the bulb out messages (I'm guessing this was not done). I'm not sure about the AE issues though! |
12-18-2015, 08:44 AM | #9 |
Rep 57
I believe those messages are for front parking lights, not rear. I'd have to check again when they pop up, but I'm pretty sure it's from the front.
Current:
12-27-2015, 02:51 AM | #10 |
Rep 535
***FIXED!***
I coded back to stock doing SG_CODIEREN (spelling?) using a blank .MAN file rather than doing FA_WRITE. I don't know why that worked but it did. I also updated DATEN files to the latest instead of V50.x (I forgot the exact version). That may have something to do with it but I can't imagine why. I have both a PRE and a POST TRC file saved so I'll examine them and try to find the difference for future reference. Thanks for the whelp everyone!
12-29-2015, 11:13 AM | #11 |
Rep 57
Glad you got it working!
I found an old post by the PO of my car stating that he had the corner LEDs coded out by someone and then immediately began receiving parking light messages and AEs stopped working. Now I know that coding mistakes are the reason mine aren't working and I'm going to work to correct them.
Current:
