12-29-2015, 01:47 PM | #1 |
Rep 739
Clarifying Ohlins R&T Offerings for 1M
After reading through some previous threads on Ohlins for the 1M I am confused...
Is there a specific set for the 1M with different valving and spring rates? It seems that EAS has different prices for 1M and E9x M3, while some other retailers do not differentiate. Obviously I'd like to buy a 1M specific setup if it is available. And would like to know where to get the best deal if this is true. Thanks, Chris |
12-29-2015, 01:56 PM | #2 |
Rep 1,585
Drives: 2011 VO 1M
Garage List 2010 Porsche 911 GT3 [10.00]
2021 BMW X5 SD40i [0.00] 2023 Toyota TRD Pro [0.00] 2011 BMW 1M [9.83] 2014 Ford Raptor [0.00] 2005 Ariel Atom 2 [0.00] 2008 135i SOLD [10.00] |
Yes there is a slight difference with the valving on the rears and rear springs are have less weight based on the lighter E82 chassis. Fronts are the same spring weight based on what I was told. Check w/ Adam at GMP Adam@gmpperformance.com I was one of the first to get the 1M specific kit and he helped tremendously.
GL ~Chad
///1M #643 of #740
12-29-2015, 02:02 PM | #3 | |
Rep 739
12-29-2015, 03:34 PM | #4 |
Supreme Allied Commander
3887
Rep 54,531
Drives: F80 M3
Slightly different valving and spring rates as the 1M is lighter.
The honest answer is that the difference is very minimal as 12kg rear spring rates will work just fine on the M3 and the 1M. 11Kg would be a good street rate, but slightly on the softer side for track. You will also get rear adjustable extenders that aren't part of the E9x M3 kit. Let us know if you have further questions as we have sold and installed more BMW Ohlins R&T than anyone in the US. |
12-29-2015, 06:17 PM | #5 | ||
Rep 1,585
Drives: 2011 VO 1M
///1M #643 of #740
