BMW M3 Forum (E90 E92)
EXXEL Distributions
      01-17-2016, 04:33 PM   #1
E90//M
Race wins reduce depression 100%
Drives: 2010 E90 M3 DCT
No more cats but a new tune?
I've ran a cat back system over the past year on my E90 M3 along with an ECU tune, DCT and coding flash. But I just decided to go full cat less. Do I really have to pay another grand for a new flash to accommodate the new setup? Or is there a better alternative?
      01-17-2016, 05:00 PM   #2
dcpatters
Drives: 2017 BMW M4
What kind of tune do you currently have? In my experience with ESS, when I went catless, my tune was upgraded at no cost.
I've got a BPM stage 2 tune now, but I think they do the same with updating tunes.
      01-17-2016, 05:04 PM   #3
E90//M
It is a BPM tune and DCT flash
      01-17-2016, 05:09 PM   #4
dcpatters
Drives: 2017 BMW M4
I'd send them an email, their customer service is outstanding.
      01-17-2016, 06:20 PM   #5
8600RPM
Drives: e92 m3
Catless xpipe requires a catless tune to squeeze out 5 to 8 more hp as well as turn CEL light off. But aside from thst it's not necessary
      01-19-2016, 12:47 PM   #6
M3 Number 86
Drives: black m3
Just went catless on Friday and I did not do anything except tune the o2 for higher flow based on Alex@Alpine which tunes out the CEL. Nothing else was changed. At the track i was getting way higher top speeds for some reason so the car was either making more power or I was just getting better.
      01-19-2016, 01:17 PM   #7
8600RPM
Drives: e92 m3
Going catless is by far single most big gain on these cars. A simple high flow air filter and catless xpipe and you have good 25bph.
      01-19-2016, 01:23 PM   #8
Evolve Automotive
Evolve Automotive's Avatar
Drives: E46 M3 . E90 M3
You will need a update on your tune. Have you tried contact BPM to see what the cost to upgrade would be?
      01-19-2016, 02:14 PM   #9
p-lethal
p-lethal's Avatar
38
Drives: 2011 BMW M3 Le Mans Blue
i believe any changes to the bpm tune file cost $100
2011 BMW M3 Le Mans Blue - mOBridge DA1 \ Helix DSP Pro \ HAT Legatia L4SE Carbon \ HAT L1 Pro R2 \ HAT Clarus C10SW-D2 (2) \ Jehnert XE200 \ Hertz HDP1 \ Hertz HDP 4 \ Hertz HCP 2
      01-20-2016, 06:18 PM   #10
azndrunk74
Drives: Frozen Black F10 M5
+1 I went this route as well since i was fine with the stock tune. with the alpine o2 tune your car can still pass the OBD2 tests . very happy with the performance with just a drop in filter and test pipes.
2014 Frozen Black F10 M5 | Agency Power HFC Downpipes | Custom Open Flash Stage 2 Tune | KW HAS kit | 3D Design Lip | 3D Design Skirts | 3D Design Spoiler | IND Front & Rear Reflectors | IND M5 Badge | M Performance Steering Wheel | M Performance CF Shift Knob | Pedal Haus Pedals & Paddles | Turner Exhaust |
      01-21-2016, 02:39 AM   #11
Silverwolf
Drives: E92 M3
Care to elaborate more on what the alpine o2 tune actually does?
      01-21-2016, 02:48 AM   #12
Fikster
Drives: E39T,E36/7M,E90M
I purchased 02 extenders from fabspeed, i got them for dirt cheap, but they list for 150. Simply install between exhaust pipe and O2. Havent had a fault code for 5000 miles and my readiness monitors are all "complete"
      01-21-2016, 02:54 AM   #13
Fikster
Here is picture of the extenders installed on the post-cat O2s... https://instagram.com/p/_algLdCiyW/
Sorry for my Instagram link, I'm still learning how to- forum via mobile device
      01-21-2016, 03:42 PM   #14
azndrunk74
as stated above it lets the post cat O2 sensor account for higher flow which in turn prevents a CEL from lighting up. other tunes simply suppress the CEL by leaving the rear O2 in a not "ready state" which will not allow you to pass any OBD2 related emissions tests.
      01-21-2016, 03:43 PM   #15
azndrunk74
i'm surprised this worked for you..many others have tried the j-style o2 extensions with no luck. you're one of the lucky ones!
m3post
