01-19-2016, 12:27 PM | #1 |
Rep 193
OEM F10 F12 F13 M5 M6 Brembo Brake package Front Rear Calipers Rotors Pads
Brake kit has been sold Last edited by prell; 02-17-2016 at 08:04 AM.. |
02-11-2016, 02:05 PM | #5 |
Rep 193
Well, you have a couple constraints, the first is with the front 400mm rotor and rear 395mm rotor, a size 19" wheel with correct offset would be a minimum requirement. Second you would need caliper brackets fabricated. The fronts are radial mounted so the fabrication would be pretty straightforward. I know Racing Brake and ECS have fabricated the brackets but when I called RB they would not sell me the bracket separately and the ECS one I believe is designed to work with a 380mm front rotor. The rears would also need caliper brackets fabricated and also keep in mind the rears have no ebrake, they were electronic on the F10/F12 etc.... A decent fabricator should be able to bolt these up without issues. I have seen several people put these on the E9X M. Hope this helps
