01-23-2016, 11:15 AM | #1 |
Rep 151
Should I repair total loss E93?
I currently have an E60 (wife's). Never driven an M or sat in one.
I have an opportunity to repair this E93. Entire right side damaged. Both front suspensions and rear right suspension damaged. This was a total loss hence salvage. Will result in a rebuilt title if repaired. 2010, vert, 46k miles, has DCT, Nav, MDrive. I have read a lot about expensive throttle actuators going bad and rod bearing failures. I am concerned about that. Don't know what other common problems I may encounter. Should I be concerned about the top open/close mechanism? I am not 100% sure I should rebuild. I don't know any body shops in Atlanta. What would this be worth after repairs? Any suggestions or advice would be helpful. |
01-23-2016, 11:28 AM | #2 |
Rep 24,863
70% chance there is damage on not visible parts and on a E93 it's even worse .
Advice => Personal I would never do it ! !
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. Last edited by ///M Power-Belgium; 01-23-2016 at 03:49 PM.. |
01-23-2016, 11:55 AM | #5 |
Rep 1,678
Drives: 2011 MCB E92 M3
I'd pass.
2011 Monte Carlo Blue E92 ///M3 - ESS VT2-625
01-23-2016, 12:56 PM | #6 | |
Rep 151
01-23-2016, 02:10 PM | #7 | |
Rep 301
Pass on this one. It probably has frame damage. If you've never drive an M, I would not recommend starting with one that was totaled and has a wrecked front and rear suspension. I'm guessing, the amount you will spend on repairing it correctly will be close or equal to buying one with about 10k more mile. You asked what will will it be worth after repairs, I can't imagine any where near to a clean titled comp. because it will have a totaled title so don't expect to make a profit after repairs unless you sell it to a high schooler. Good luck.
"…And the longer you deny yourself that M satisfaction the more unhappy your soul will be…. Get busy living or get busy dying and stop sweating the small stuff!" i001947
01-23-2016, 03:03 PM | #9 |
Rep 1,974
Even if someone gave me that car for free I would not want it. E93 can be had for cheap, especially an 08. I'd rather have a clean higher mileage 08 than this one.
01-23-2016, 03:11 PM | #10 |
Rep 6,732
2 layers of Opti Coat, you'll be fine...
Flying Ace4987.00 |
01-23-2016, 03:16 PM | #11 | |
Rep 151
01-23-2016, 03:17 PM | #12 |
Rep 6,732
I think you're putting the cart before the horse if you're worried about rod bearings and throttle actuators. Chances are those are just fine. You need to be more worried about the frame, DCT, differential and 3 piece roof first.
Can can be repaired but the price of the car plus repair costs needs to be considerably low if you want to fix it without getting into good used car pricing. Resale will be very low considering it'll be a salvage.. you'll probably be very lucky breaking even |
01-23-2016, 03:28 PM | #13 | ||
Rep 151
01-23-2016, 03:32 PM | #14 | |
Rep 151
01-23-2016, 03:33 PM | #15 |
Rep 277
I wouldn't waste my time... Any slight frame damage or frame pull on either side... The roof would never line up properly... Then you're dealing with future leaks, electrical problems etc...
Just my 2cents |
01-23-2016, 04:16 PM | #16 | |
Rep 24,863
And I can tell you he has the nessesary knowledge for our cars , and so I saw serious BMW's damage in his shop in the last 15 years . So I showed him your pics and he said ...///M3-E93 ? Oughhh ! Repare is always possible these days , but a E93 and if something is bent there is always a chance for wind noises inside cabin . As for frame damage...Our ///M cars are very sensitive for steering wheel vibrations and when it's not fixed in perfection with the specific tools there will be extreme tire wear and probably the car will always pull to one side of the road . And please don't forget about the value of the car...Even repared in perfection your car is/was a "total-loss" wich means "huge value loss" ! In short....Think twice
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
01-23-2016, 04:17 PM | #17 |
Rep 532
Oof. I'd not repair that. . Does the top operate smoothly now? (could be a good indicator of frame damage if *not*)
Go buy my old E93 at United Roswell. It's there. 2009. Silver. |
01-23-2016, 04:20 PM | #18 |
Rep 611
Drives: 2013 M3 coupe' 6mt
If it was a coupe it might make a good track car. $20k seems high for salvage. Engine and DCT might be worth $10k if unharmed.
memories: '71 2002 (new), '72 Bavaria, '74 2002tii, '00 540i Sport |
01-23-2016, 04:48 PM | #19 | |
Rep 1,178
Sorry but sounds like you do not have the financial ressources to own any degree of used M car. Maybe an E46 ? |
01-23-2016, 05:28 PM | #20 |
Rep 2,400
That differential looks bent and some of the bracing sheared off.....Assuming if diff is ok, just by visual inspection of the damage you can see how much the obviously needed replacement (and discounted) OEM parts are online, and it will add up very quickly....definitely stay away as you won't come out ahead financially and if you consider the opportunity cost of time/labor, makes even less sense. A part out may be a way to make a very modest amount of money at best, but again, is time consuming.
01-23-2016, 05:54 PM | #21 |
Rep 8,083
if you will track it and not worry about resale and the price is low enough do it.
most people on here (as you can see) can't even wrap their minds around a crashed car. |
01-23-2016, 06:22 PM | #22 | ||
Rep 151
I do have access to recycled parts nationwide, however, M parts are in short supply and expensive. I think all you enthusiasts horde extra parts You are also correct I cannot spend $30k on an extra toy. |
