02-16-2016, 09:53 AM | #1 |
Rep 1,368
In the midst of doing research on a coilovers that best meets my need. There's definitely a lot of information out there...
This would be for my daily driven E92 with the occasional mountain run (3-4 year) and track day (2-3 year). I'm running a square set of Apex EC-7 18x10 ET25 with Michelin PSS 275/35/18 tires. The rears have a 10mm spacer and I do NOT want to run a spacer in the front to clear any coilover spring perches, etc. So, this rules out KW systems. I've gathered that there are options from JRZ, TCK, Ohlins R&T, and MCS that wouldn't require a front spacer with my wheel/tire setup. Am I missing anything? Street comfort is a top priority for me. I know that track performance would be the trade-off. My consensus is that the Ohlins R&T would be the best fit. Would have been nice to keep it under $2k and the Ohlins seem to be above that. Is there a better option? Thanks |
02-16-2016, 12:30 PM | #2 |
281
Rep 7,518
Both Ohlins and JRZ are high quality, our recommendation though would be the JRZ for your daily commute. This is something that we recommend to all of our customers and install on our track prepped cars as well as our personal cars. Ride quality is superb.
We offer both Ohlins and JRZ's and would be more than happy to set up options for you. Both these coilovers will go over $2k but we can do a swift spring setup. |
02-16-2016, 12:40 PM | #3 | |
Rep 1,368
02-16-2016, 08:09 PM | #4 |
281
Rep 7,518
02-16-2016, 08:52 PM | #5 |
Rep 2,400
TCKline D/As would work as well. Love the kit, the springs are pretty soft (350 F/ 600 R) with excellent ride quality, yet will make car extremely fast. TC's own E90 M3 is doing 1:39s at Laguna Seca with Hoosiers and the D/A kit and pads with no other mods. Stiffer springs in their research were shown not to be faster on the track. My understanding is that it has great clearance (you can contact them to find out), but you're looking at $3+k.
02-16-2016, 09:06 PM | #6 |
Rep 599
I'm running a very similar wheel setup, Arc-8, not Ec-7, but don't have any problem with clearance on the coilovers on my KW V3's. I'm sure others have as well without issue... I'm even running some camber, which I would think would make clearance worse. For what it's worth.
02-16-2016, 09:55 PM | #7 |
Rep 1,368
02-16-2016, 09:57 PM | #8 | |
Rep 1,368
02-17-2016, 06:45 PM | #9 |
Rep 599
I didn't raise the perch, but I am running linear springs in the front. I didn't ever have the stock springs, so I don't know how they would have worked.
Coincidentally, I am switching to MCS, wanted a stiffer spring. If you can swing it, they are supposed to be a great setup. If not, you can buy my old setup when it comes off in a month.. |
02-17-2016, 07:52 PM | #10 |
Rep 988
If you have EDC you should look into the bilstein B16 damptronic.
Great comfort on the street and felt great on the track at my last hpde. It allows for all the EDC settings because it plugs into the system. I've got mine matched with GC camber plates. |
02-18-2016, 07:08 AM | #11 | |
Rep 1,368
02-18-2016, 07:09 AM | #12 |
Rep 1,368
I don't have EDC, but would definitely consider the Bilstein's if I did.
02-18-2016, 05:46 PM | #13 |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
In my opinion, there's nothing that 2-3 track days a year can throw at the car that the STOCK suspension can't handle.
The real question is, if there's $$$ burning a hole in your pocket, what do you want to get...Because judging from your desired usage, the OEM suspension is the best all around compromise. If you can't have a metric @ss ton of fun with a handful of mountain road days and 2-3 track days, then there's something wrong with the car, and there in lies a much bigger issue. In my opinion.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
02-18-2016, 08:53 PM | #14 |
Rep 599
The roads are ok here. I ran with the rebound and compression pretty much maxed. It was ok. It all depends on your tolerance level. I didn't find it much worse than stock (but I can't really remember what that feels like anymore).
02-18-2016, 09:03 PM | #15 | |
Rep 1,368
It maybe fair to say that most of us on this forum look for reasons to spend our hard earned dollars on car parts. |
02-18-2016, 09:05 PM | #16 | |
Rep 1,174
02-19-2016, 02:15 PM | #17 |
Rep 875
Nothing wrong with having what you want, it is after all your money. But if you're only doing a couple track days a year with horrible roads on the daily grind, you should look into things that won't adversely affect your comfort levels while giving you extra fun on the track.
My suggestion would be to get stickier tires (RS3, AD08R, RE71R, RivalS) and a nice set of front camber plates and a nice alignment afterwards. You will be amazed at the difference in handling performance while maintaining your stock dampers/springs comfort. |
02-19-2016, 03:19 PM | #18 |
Rep 599
Im curious if there is a suspension set-up that has EDC? I have a non-EDC car, and I want something superior to the stock EDC set-up. My previous '12 M3 had EDC, and whilst I appreciated the adjustability, I felt the damping could be improved upon. My car is a DD, exclusively for non-track scenarios.
02-19-2016, 03:51 PM | #19 | |
Rep 1,049
Can a good set of springs with ZCP suspension give me less roll and retain the stock height and ride (more or less)? The soft springs are the only thing I don't like about ZCP. |
02-20-2016, 10:52 AM | #20 | |
Rep 3,456
Drives: Harrop E90 M3
02-20-2016, 12:16 PM | #21 | |
Rep 599
Thanks. I did look at that kit. It's based off their V3 kit and adds mobile EDC. I'm not sure if it is superior to the stock EDC system. I wonder if anyone has insight, or know of better EDC enabled aftermarket coilovers for our cars. |
03-07-2016, 06:56 AM | #22 |
Rep 139
TCKline and Ground control make 'Coilover conversion kits' compatible with EDC. They basically include stiffer springs and camber plates.
'09 E90 M3 DCT EDC, ESS VT2 625, ESS HFC, GTS DCT, D2R BBK, B16D, VORSHLAG CP, DELRIN SUB, TE37SL
'00 996.1 GT3 CS |
