02-16-2016, 09:56 AM | #1 |
Rep 198
F15 H&R front spring DIY?
done the search...but haven't found any DIY's for a H&R spring install for a 2014 X5 35i. i installed H&R's on my 2008 X5, and thinking i can save myself $500+ on paying someone else to do the job for me.
TIA. |
02-16-2016, 11:58 AM | #3 |
Rep 198
so a DIY from an E70 would be about the same procedure as for the F15?
also, and help with the "rear link" DIY would be helpful. have heard that part was relatively easy. |
02-16-2016, 02:06 PM | #4 |
Rep 18,757
klerk , same DIY as the E70.
The rear link is very straight forward. Remove the old and replace with the new, then adjust.
02-16-2016, 04:23 PM | #6 |
Rep 18,757
Try with the way it came. H&R should've pre-set it to where it is best for the car.
02-19-2016, 10:02 AM | #7 |
Rep 1,547
Took me just over 3 hours start to finish to put my ACS springs/links in. Pretty straightforward.
2014 BMW X5 xDrive 35d M Sport Mineral White
2011 BMW 135i M Sport Space Grey 2007 Suzuki GSX-R 750 |
02-19-2016, 10:53 AM | #9 | |
Rep 525
so if you want to at least save some labor by installing rear links on your own, it is quite and easy job, if you have wheel ramps, its 5 minutes. you can set the links center to center same as stock so you wont have an issue before spring install.
02-19-2016, 01:08 PM | #10 |
Rep 1,547
No sir, no DIY needed... As for the rear air system, as mentioned above, no need to bleed it. I've got my rear links set to the lowest setting...stance is perfect IMO.
03-13-2017, 09:24 AM | #11 |
Rep 93
Likely going to be swapping my H&R's out for Eibach's this weekend, but haven't been able to find any DIY's for the E70 or the F15. Does anyone have one handy, would like to review the steps before I get it up on the lift.
Thanks
'14 X5 50i M Sport
MPBK | Meisterschaft GTC exhaust | H&R | V1 | IND | RG Sport | |
03-17-2017, 11:06 AM | #12 |
Rep 93
Anyone?
I'm going to swap springs tomorrow, I'm mostly interested in torque specs.
'14 X5 50i M Sport
